Old 08-28-2006, 06:18 PM   #1
SLVRsleeper
Member#: 98663
2002 Built Hybrid
PPG Dogbox WRB
Default Rattle noise under car
I've searched this and other forums, but still haven't found it. I installed my kartboy SS and hardened bushings a WHILE ago. Everything went fine, and i'm sure of everything being correctly installed and tightened, (i think). After I took the car off the jacks and went for a ride, i noticed a rattling/squeaking kinda noise. It's gotten worse now, and it CAN'T be normal. It normally happens when i'm shifting or when i'm under deceleration (i guess because of my exhaust). Sounds like it's coming from the drivers side, but the weird thing is, it sounds like it's more toward the rear of the car. It's almost like someone flicking a spring against the undercarriage of the car repeatedly. Anyone have any ideas? I've gotten used to it, but it still does get annoying.
SLVRsleeper is offline   Reply With Quote
Old 08-28-2006, 06:31 PM   #2
SLVRsleeper
Member#: 98663
2002 Built Hybrid
PPG Dogbox WRB
Default rattle noise under car
anyone?
Old 08-29-2006, 03:49 PM   #3
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
Crawl under the car and move the exhaust around, also try and bounce the car and see if you can hear it. I have also found squeaks by pushing on the rear quarter panel and makeing the car sway back and forth. Basically stand at the quarter panel, and rock it horizontally, hope this makes sense.
mike_b49431 is offline   Reply With Quote
Old 08-29-2006, 04:35 PM   #4
Drnkirishm
Member#: 87386
03 Sonic WRX
02 Blaze 4AT
I have a rattle too. After looking at everything possible I finally found that it's just an exhaust bracket hitting my sway bar.
Drnkirishm is offline   Reply With Quote
Old 09-06-2006, 04:44 PM   #5
SLVRsleeper
Member#: 98663
2002 Built Hybrid
PPG Dogbox WRB
thanks guys i'll check it out.
Old 09-11-2007, 04:36 PM   #6
ripleyj
Member#: 148778
2011 WRX
after crawling underneath my car I still can not find where my rattle is coming from. It sounds up closet to the engine more than anywhere else. I have rattled my exhaust and everything else I can think of. Only rattles when shifting or sometimes at idle.
ripleyj is offline   Reply With Quote
Old 11-17-2007, 12:54 AM   #7
silwrx12
Member#: 108823
my car is making the same noise. did you find out what was it?
silwrx12 is offline   Reply With Quote
Old 03-26-2008, 08:29 PM   #8
mookies
Member#: 168294
2007 WRX
same problem =[
mookies is offline   Reply With Quote
rattling noise under shift boot area stevele13 Interior & Exterior Modification 11 08-10-2009 09:35 PM
rattling noise under shift boot dankEe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-06-2007 11:35 AM
Rattle noise under boost... 4S-TURBO Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-24-2007 02:03 PM
faint noise - rattling from under car of some kind? RodimusPrime Normally Aspirated Powertrain 7 04-05-2005 12:32 PM
Clinging metal noise under car SubZombie Service & Maintenance 8 02-12-2004 01:29 PM
