Old 10-29-2001, 03:26 AM   #1
Sauginius
Member#: 277
98 Not a Subaru
BRACK
Default IC welding
Ok, I have an intercooler off of a saab 900 (or I think that's where it's from).
Currently, it's end tanks are on the sides along with the inlet and outlet. Is it possible to modify it so that it can be top mounted? If so, who would provide such a service (any welding shop?)?
Oh yea, I'm in So. Cali so if anyone knows a place in the area, let me know.
Thanks.
Sauginius is offline   Reply With Quote
Old 10-29-2001, 10:32 AM   #2
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
Any welding shop with experience in Aluminum, Have to be kinda careful, as some places may say sure no problem and then completely botch the job, so when you go to a welding shop ask for references on aluminum work they have done and then go talk to those people.
paulnose is offline   Reply With Quote
Old 10-29-2001, 11:01 AM   #3
Aphex
Member#: 146
'16 WRX Limited
you can top mount that IC, Paul Ecklund did it, I'm going to do it, and SubaChad has done it, I'm sure Chad will chime in and link to his website that shows his with a brief writeup.
sorry for not having more info, but it can be done as a top mount with no modifications, that's the main point
Eli
Aphex is offline   Reply With Quote
Old 10-29-2001, 11:07 AM   #4
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
<chiming in>
It's not completly mod free, you do need to trim a little off one of the end tanks to make it fit between the firewall and the TB. You'll also need a little padding on it so the IC doesn't vibrate against the firewall.
Here's that link you were referring to...
http://208.129.213.117/subachad/intercooler.htm
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-29-2001, 07:05 PM   #5
Sauginius
Member#: 277
98 Not a Subaru
BRACK
Thanks guys!
Old 10-29-2001, 08:40 PM   #6
SubaFastR
Member#: 5786
I don't think it will need to be modified to fit an rs. I have one, although it is not mounted yet.
SubaFastR is offline   Reply With Quote
WRX catback on 2.2l OBS catpipe...the weld broke :| Quick dia ?s kaisersouse Normally Aspirated Powertrain 0 06-01-2010 08:20 AM
HR: Need an IC hole welded D_Block Mid Atlantic Impreza Club -- MAIC 37 12-05-2005 11:20 AM
anyone here weld? if so, any good welding forums? friedbbq Off-Topic 7 10-19-2005 09:42 PM
WRX Center diff welded or not welded. joshuagore Private 'Wanted' Classifieds 0 04-19-2005 05:11 PM
Chop chop cut cut weld weld LOUD mexicanpizza Bay Area Impreza Club Forum -- BAIC 4 08-22-2002 02:59 PM
