Old 08-29-2006, 02:03 AM   #1
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Default 2.5 STi with 02 wrx ecu
I am putting a complete sti motor into my 02 wrx. I want to flash the stock ecu until I can get a real tune or buy a hydra.
I am out of money so what is my cheapest route to get this motor to run with the wrx ecu? I know avcs will not work. I am just stumped with what I am going to do about engine management.
Any help will really be appreciated.
Smoby is offline   Reply With Quote
Old 08-29-2006, 02:08 AM   #2
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
I was thinking something along the lines of having the tables for a stock STi, then changing it to match on the wrx ecu.
Old 08-29-2006, 12:32 PM   #3
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Bump
Anyone alteast have a link to help me?
Point me into the right direction. I have been searching for a couple days now, but still have no solid answers.
Thanks
Old 08-29-2006, 07:57 PM   #4
JRSCCivic98
Member#: 67080
If it's a 2.5L STI it won't work because of the DBW throttlebody. (there are ways arround this, but that involves swapping things arround, not just ECU tuning alone) Do some more research on this... you need it. Go to the engine swap forum... I don't think anyone's going to just hand you the answers on a silver plater.
JRSCCivic98 is offline   Reply With Quote
Old 08-30-2006, 03:18 PM   #5
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
I have done research. I know what is all involved with putting the STi motor into my car. I am not using drive by wire, I am using my intake manifold. I am installing the new cam sensor, blah blah
I just dont have the money to buy engine management, or get a tune at the moment and want a flash to run it until I can.
Old 08-30-2006, 03:49 PM   #6
teiva-boy
Member#: 22825
A "flash," is every bit of capable of making big power as anything else.
It's all in the details.
The man you want to do your work is Clark (AZscoobie) on this board.
teiva-boy is offline   Reply With Quote
Old 08-30-2006, 04:02 PM   #7
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Yea, I know Clark personally
The reason I will be wanting to buy engine management down the line is so I can have AVCS.
I was hoping there was somebody that has flashed the wrx ecu to run the STi motor and would have that map for me to use.
Old 08-30-2006, 04:31 PM   #8
teiva-boy
Member#: 22825
He seriously would be the best person to ask. He's local, and has more experience then most anyone here
Old 08-30-2006, 06:22 PM   #9
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Screw it. I am just using the shortblock.
Old 08-30-2006, 10:12 PM   #10
JRSCCivic98
Member#: 67080
Why not get Clark to use some openecu stuff for the short time... it'll tune your 02 WRX ecu just as well. That way it won't cost you any money for EM, just his time...
Old 08-30-2006, 11:36 PM   #11
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
You talking about having him tune the wrx ecu to run the STi long block?
I spoke with Clark and he advised me that this swap would be more trouble then it is worth. I would never get it to run right.
Is there a hydra system for the wrx that runs avcs? I know there are the hydra avcs for the jdm avcs motors but I read that the cams have different pickups for the sensor so it wouldnt work right.
If I did want to put the whole motor in my car. What would be required to get avcs working right.
Old 08-31-2006, 12:09 AM   #12
Tgui
Member#: 44771
Try this place. There are staged maps for you to dl for free.
http://www.osecuroms.org/
Or do it yourself
www.enginuity.org >for tuning (Im biased here )
http://www.openecu.org/index.php?title=EcuFlash for tuning and flashing
Ohh and you'll need this cable to flash.
http://www.tactrix.com/
Tgui is offline   Reply With Quote
Old 08-31-2006, 06:12 AM   #13
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Thankyou Tgui, that is what I needed.
I have been to that site before but not registered. I registered and now can see what I want.
Old 08-31-2006, 09:08 AM   #14
JRSCCivic98
Member#: 67080
If you want to do it right...
1) Complete engine.
2) STI harness.
3) STI ecu.
There's no reason for it not to run if you do all of those. If you want to cut corners, then you'll have to find workarounds for your issues. I'm surprised Clark didn't state this to you already.
Old 09-02-2006, 09:33 AM   #15
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
not to sound stupid ,but why are you installing a new cam sensor? i am running a forged 2.5l with p&ped wrx heads with 264 cams. ,and i did not need a new cam sensor . did i miss somthing??
sonic rx is offline   Reply With Quote
Old 09-02-2006, 04:31 PM   #16
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
I am talking about running the STi avcs heads
Old 09-02-2006, 04:32 PM   #17
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
1) Complete engine.
2) STI harness.
3) STI ecu.
Clark stated to me that the electrical on the STi is way different and I could not just use the STi harness.
Old 09-02-2006, 04:41 PM   #18
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Has anyone been able to get this motor to run right without avcs and the wrx ecu?
I see a couple people in the process, but can not find any running. Clark said I will never be able to get the motor to run correctly and to not waste my time.
Old 09-04-2006, 02:39 AM   #19
teiva-boy
Member#: 22825
Try Phil From Element Tuning?
Old 10-10-2006, 10:07 PM   #20
k_thaosta
Member#: 20583
I got mines running right now without AVCS, just need to tune my fuel so it runs around the 14.7 AFR, it's about 15-17 right now so it's a little high but it's starts and runs...
I too am here looking for a UTEC map running STI longblock on WRX harness...
k_thaosta is offline   Reply With Quote
Old 10-14-2006, 01:06 AM   #21
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Getting it to run was extremely easy... I used the USDM STI TGV's and the WRX Upper intake manifold for the throttle cables. Used the WRX intake manifold harness, but swapped injector connectors to allow the use of the side feed injectors. Fired up and ran the first time without issue. It's going on the dyno for PDX to tune very soon, so we'll see what kind of power they can get out of it.
I have thought about using the JDM computer to control avcs, but the ver 7 and ver 8 cams are different than the USDM STI cams, and I'm not sure if the JDM computer would read the same cam signal that the usdm motor puts out.
wrx_driver_2002 is online now   Reply With Quote
Old 10-24-2006, 04:13 PM   #22
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
reading all this is making me nervous about my swap! i'm about to swap a 06 legacy gt engine into my bugeye.
domestic_abuser is offline   Reply With Quote
Old 10-24-2006, 04:22 PM   #23
babyblue22681
Member#: 51981
03 fast wrx-e55
blue/desert silver
just use the wrx heads, put some cams in them and voila!~ 400+ whp if done right.. im running 272 cams and ported and polished wrx heads. .
my car puts down over 300 lbs of torque @ 3300 rpm and pulls till 7k with no drop in hp or torque.
babyblue22681 is offline   Reply With Quote
Old 10-28-2006, 09:37 AM   #24
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x10s
I'm just wondering. Is it possible to use an aftermarket VTEC (gasp!) controller to run the AVCS?
bluescoobywagon is offline   Reply With Quote
Old 10-29-2006, 01:39 AM   #25
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
quite simply....no
V-TEC is a simple on/off spool valve, AVCS has a duty cycle that determines the cam position
2001 RS 2.5 sideskirt on 02 WRX? elsuicida Interior & Exterior Modification 1 03-24-2009 10:06 PM
2.5 block with 02 wrx heads slprwgn Engine/Power/Exhaust 3 01-16-2008 08:22 PM
Sti long block with 02 WRX ecu LiquidForce Built Motor Discussion 7 05-20-2006 06:06 PM
UTEC version 4 with 4.2 software compatable with 02 wrx? kx02wr Engine Management & Tuning 4 06-05-2005 10:31 PM
UTEC version 4 with 4.2 software compatible with 02 wrx? kx02wr Tri-State Area Forum 3 06-05-2005 12:06 AM
Message Board Statistics All times are GMT -4. The time now is 01:04 AM.
