Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-29-2006, 06:41 AM   #1
UK_SPORT
Member#: 123906
Default Air temperature sensor on 99 UK 2.0 sport
Can anyone tell me exactly where the air temperature sensor is in this picture of my 99 Sport engine:
Thanks
UK_SPORT is offline   Reply With Quote
Old 08-29-2006, 08:21 AM   #2
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
It is located on the front of your airbox, the side that faces you when you stand in front of the engine.
I can't edit the picture to show you but I'll try to explain:
If you look at the front of your airbox you will see a support strap with a bolt in it on the left-hand side, come horizontally across to your right and you will see a raised circular area. That is the recess that your intake air temperature sensor goes into.
I hope this helps!
Ramon_12345 is offline   Reply With Quote
Old 08-29-2006, 08:33 AM   #3
UK_SPORT
Member#: 123906
Hi Ramon, Firstly thanks very much for taking the time to reply. I have as of yet not found anyone else in the UK that could help me locate this part.
Looking at the picture below could you tell me is it the red circle (in which case it appears I don't have one) or the yellow circle?
The reason I need to find it is I am getting the CEL flashing and when I read the codes using the method here:
http://www.saxonfields.freeserve.co....iag%20Page.htm
It gives me 2 long flashes followed by 6 short ones. This comes out as26 which reads:
26 Air Temperature Sensor (Justy)
I really appreciate your help as nobody in the UK (even Subaru themselves) can help me to locate this part!
Old 08-29-2006, 09:38 AM   #4
Ramon_12345
Member#: 72021
WHITE
It is the black raised area to the left of the red circle. This black raised area that I am referring to is located on the airbox itself.
The method that you used to "pull" the codes was indeed correct.
As for fixing the problem, once you find the part I can give you the information regarding the troubleshooting procedure and hope that would help.
Old 08-29-2006, 10:05 AM   #5
redwagon
Member#: 2181
2008 SpecB
It's a little hard to spot with the shadows, but that raised area is blank on that airbox. The air temperature sensor is there on some of the earliest '00 models but on the later cars it's integrated into the MAP sensor. That's the black thing below your yellow circle, mounted on the intake plenum with two bolts, right at the bottom of your zoomed photo.
The thing in the yellow circle is the idle air controller, or IAC.
redwagon is offline   Reply With Quote
Old 08-29-2006, 10:06 AM   #6
UK_SPORT
Member#: 123906
Hi Ramon, I presume you mean the now green circled area? If so then there is definatley no temp sensor there and no wires to or from it.Its just a bump in the plastic moulding and inside is the same, no wires or plugs etc! I can't understand this, it gives me the code 26 but even my subaru main dealer does not know what it means!
Old 08-29-2006, 10:08 AM   #7
UK_SPORT
Member#: 123906
Redwagon thanks very much for your help, would I be correct to presume then that changing the MAP sensor may rectify the problem? I really appreciate your help guys, this thing has had me considering selling the car which I otherwise love!
Old 08-29-2006, 10:26 AM   #8
Ramon_12345
Member#: 72021
WHITE
The green circled area is exactly what I was referring to
Just a thought, but maybe the reason for the code 26 is because you don't have the air intake temperature sensor hooked up. Is there a black two-wire harness connector in that vicinity?
If so it might suggest that the sensor may have indeed been in that location but for some reason may have been removed, which if that were the case, leads me to wonder why didn't the code show up earlier.
With regards to redwagon's suggestion, as far as I was aware I didn't think that the air temperature sensor was incorporated into the MAP, I thought that they were separate, but anyway we are all here to learn and help each other out.
What I typed above are just my suggestions and you can keep us informed UK_SPORT.
Old 08-29-2006, 10:29 AM   #9
UK_SPORT
Member#: 123906
Hi Ramon, No there are no electrical connectors of any type at all in that area. There has never been any hole there either as the plastic moulding is perfect and undamaged. I will go and look at the wiring to the map sensor and see if there is any damage etc.
Old 08-29-2006, 12:51 PM   #10
redwagon
Member#: 2181
2008 SpecB
It's quite well documented that the air temp sensor was incorporated into the MAP sensor and the wiring diagrams reflect this. If it has four wires, it's a dual sensor.
FWIW, the code I have in my book for the air temp sensor is 111, not 26. There is no code 26 for the Impreza since the codes begin at 31... Maybe your tech has read the code wrong and you're barking up the wrong tree?
Old 08-29-2006, 01:02 PM   #11
kaisersouse
Member#: 85900
2001 Forester S
"26 Air Temperature Sensor (Justy)"
Justy = not impreza. Subaru justys were small (3 cyl i think) subies. I think whomever pulled the code screwed up. I'm pretty sure every justy on the planet would be OBD1 whereas the 99 impreza is OBD2. Get a second opinion on that code
kaisersouse is offline   Reply With Quote
Old 08-29-2006, 03:30 PM   #12
UK_SPORT
Member#: 123906
Hi again guys, I read the codes myself using the flashing CEL light method listed abve and shown here:
Old 08-29-2006, 06:18 PM   #13
UK_SPORT
Member#: 123906
here is the code (taken with my crappy P900 phone so poor quality)
It just keeps looping again and again! Is this code 26?
http://media.putfile.com/Code-87
Old 08-29-2006, 08:10 PM   #14
redwagon
Member#: 2181
2008 SpecB
Go borrow a scanner, or buy a cable and scan from a notebook.
Old 08-30-2006, 04:20 PM   #15
Ramon_12345
Member#: 72021
WHITE
Yes that is indeed a code 26.
If you need the information for troubleshooting a code 26 just send me a PM with your e-mail address.
location of the air intake temperature sensor on 02 wrx mac ej20 Service & Maintenance 3 09-02-2006 10:50 PM
so does anyone know where the Air Temperature Sensor is on a 99? Big_Hitter Texas Impreza Club Forum -- TXIC 3 10-20-2005 03:43 PM
P0113 Intake Air Temperature Sensor Circuit Malfunction (High Input) CEL on my STI googe Engine Management & Tuning 5 11-08-2004 02:38 AM
Factory Manifold Air Temperature sensor signal -- can it drive a gauge? mdcatlin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-29-2003 06:42 PM
Intake Air Temperature Sensor PimpinRex Newbies & FAQs 2 08-14-2002 05:25 PM
