Old 08-29-2006, 01:39 PM   #1
BigMikeLV
Member#: 99301
2010 2006 B9 Tribeca
Default Forester coolant issue. Help!
A friend has an '04 Forester 2.5X 5-Speed that sucks coolant -- the entire resovior bottle goes empty every 7,500 Miles. Dealer has done a leak down test, pressure test and a third test and shows nothing wrong. Oil test shows coolant in oil.
Any indeas what it is?
BigMikeLV is offline   Reply With Quote
Old 08-29-2006, 01:47 PM   #2
pleiad7
Member#: 71056
MY04 Forester XT
The mysteriously disappearing coolant is a common issue on the 03+ Foresters. Do a search over on subaruforester.org, there are a number of discussions on this issue, e.g. this thread.
pleiad7 is offline   Reply With Quote
Old 08-29-2006, 02:09 PM   #3
Hayes
Member#: 11808
Coolent in the oil demonstrates a head gasket problem. How do you know coolent is in the oil? Did you have an UOA performed at a lab or are you just guessing? Driving with a hot engine will push coolent out of hoses & water pumps that may not show up with a static pressure test. I'd very carefully look a ALL hose connection, radiator top & drain spigot, and inspect for HG external weepage. I would also check the water pump. Any connection that has a whiteish substance is suspect.
Hayes is offline   Reply With Quote
Old 08-29-2006, 02:19 PM   #4
356cab
Member#: 124384
Is he getting any higher then normal engine operating temperatures? I agree, how do you know coolant is in the oil??
I did have a head gasket leak on my 01 2.5L engine and it was easy to see in operating temperatures, but really didn't show until the car was up to about 200 and then it would just take off, so if they do tests without getting it hot enough some leaks won't show up. Just so you know, you can use Barr's stop leak and fix a head gasket, but there are two different kinds of this stop leak and you want to get the kind that requires a complete flushing out of the coolant and using the product with only water and nothing else in the system. It seems like snake oil, but it works. The stuff that you can use without flushing is a waste of time for any leak that develops under high pressure.
356cab is offline   Reply With Quote
Old 08-29-2006, 10:12 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
So did the dealership find the coolant in the oil? Is the car still under warranty? Have the dealership fix it.
Period.
Tim Sanderson is offline   Reply With Quote
Old 09-04-2006, 08:53 PM   #6
BigMikeLV
Member#: 99301
From what I have been told... The dealership found coolant in the oil but cant find out why. I'll forward this to him.
Old 09-04-2006, 09:03 PM   #7
Nachas
Member#: 108365
Nachas is offline   Reply With Quote
Coolant issues Please Help....Thank you clkoontziii Service & Maintenance 5 06-05-2010 02:09 PM
coolant issues. need help! ImprezivEJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-22-2008 04:38 PM
coolant issues rs_two_five Normally Aspirated Powertrain 3 02-16-2007 06:16 PM
Help: coolant issue?! USF97J4x4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-23-2006 11:53 AM
Coolant issues rhockstra Service & Maintenance 8 12-11-2004 05:55 PM
