Old 10-29-2001, 11:12 AM   #1
auricom
Member#: 3088
'01 2.5 RS
Default cost of 15K service
is $175 normal for the cost of the 15k service. an oil change i can see paying for but the other maintence should be covered under the warranty.
auricom is offline   Reply With Quote
Old 10-29-2001, 11:53 AM   #2
Julian
Member#: 1182
MY00 RS
BRP
Maintenance is not covered under Subaru's warranty. Defects in manufacturing are covered.
Julian is offline   Reply With Quote
Old 10-29-2001, 12:24 PM   #3
auricom
Member#: 3088
'01 2.5 RS
true dat, good point
Old 10-29-2001, 04:41 PM   #4
FargoRS
Member#: 419
Default Sounds Too Spendy
I don't think there is anything that needs adjusting or replacing at 15K. I think I just had an oil change. I heard that 30K can run up to $300. Ask the dealer what exactly they plan to do and check your maintenence schedule in your manual to see if it jives.
Mike
FargoRS is offline   Reply With Quote
Old 11-01-2001, 09:21 PM   #5
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Yeah, way too much money. All they do is an oil change and check things. Not worth it, IMO. It's in your manual what they do, so if you can handle it, just do it yourself.
redobs is offline   Reply With Quote
Old 11-02-2001, 02:04 AM   #6
smacksube
Member#: 4067
01 2.5 rs
just ask for the maintenance list....it tells what exactly they do at what mileage....30k was something like spark plugs, oil change, belt tension, compression check, check and lube suspension fittings, check lines, etc, etc...stuff that will never ever ever going to need to cost 300 bucks....my dealership wanted 275 for the 15k, I was like, riiiiight, I gottta go.....got the list and did it myself.
smacksube is offline   Reply With Quote
Old 11-02-2001, 03:38 PM   #7
Tobias_Ostapchuk
Member#: 554
2002 Subaru WRX S/W
For the most part, you can do the 30K yourself, too.
Tobias_Ostapchuk is offline   Reply With Quote
Old 11-02-2001, 11:00 PM   #8
tahrndt
Member#: 1315
One thing to remember is that if YOU do all of your maintance your local Soob dealer will not be quite so ready to go to bat for you if something bad actually happens during or after your actual warrenty.
I have done ALL services on my 92 Mercury, up to and including replacing struts and rotors. I have done all oil changes for my Soob including switching out the rear diff to Mobil Syn. But I am leaning to having my local dealer do the 15k and the 30k "check up" I know that I can/could do them but for the price of having Morries do it I look at it as cheap insurance against any bad mojo happening later. ie. after 36k or 3 years.
I was in my service center and they were talking about a customer that needed to have her head gaskets replaced. One of the questions that came up was..."did she have her 30k service done at our shop?". When the answer was "no" the service manager pretty much concluded that they would do what the bare minimum was and end it at that.
I got the distinct feeling that if she had done her major milage checks there the manager would have been more willing to not worry about the car being out of warrenty by xxxx miles.
I have not convinced myself that I will pay for the 15k yet but I am leaning that way.
good luck
TIm
I am not saying what the service manager did/said was wrong or right. You just have to think about it from a viewpoint of the dealer. Remember they do not make the same amount of money when serviceing a problem under warrenty vs. the same problem on a 6 year old car.
tahrndt is offline   Reply With Quote
Old 11-03-2001, 11:09 PM   #9
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
That's right as far as a 15k goes you get a air filter fuel cleaner carriage lube and oil change. And as far as being more willing to warranty something if we do your service then yes we are.
Old 11-05-2001, 07:56 PM   #10
psoper
Member#: 7703
2002 WRX wagon
It isn't black, its blue!
By the way, my 15,000 inspection/service found the brake pads on my WRX worn down to 2 mm in front, 3mm rear- guess what , they're covered under warranty!
So I figure the almost $200 it cost me still isn't such a bad deal, but 175 would have been better
psoper is offline   Reply With Quote
Cost of 30k Service @ Irvine Subaru? RallyImprezive Southern California Impreza Club Forum -- SCIC 41 04-12-2006 04:30 PM
Likely cost of 15,000 mile service? bruticus Service & Maintenance 22 10-24-2003 09:12 AM
about how much should the 15k service cost? CameyDeuce Mid West Subaru Owners Club Forum -- MWSOC 11 06-08-2003 03:10 AM
('93-'01) 15k service....how much should it cost? 4ontheFloor Impreza Forum 11 08-29-2001 06:34 PM
