Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 08-29-2006, 08:25 PM   #1
1FSTREX
Member#: 109348
05 STI
CGM
Default Can you swap a 04 center console with a 05 center console? Details inside!
Hey guys,
I want to swap out my 04 STI center console with a 05 STI center console. But im not completely sure i can so i wanted to make sure. I am swapping the whole AC section, down to the shifter section, all the way back to the center console.
So will the AC controls of the 05 match up with the AC plug in my 04? Next i believe the ebrakes are on opposite sides, can this be swapped? Will everything line up perfectly with the stock bolt pattern on the 04?
Also since i believe the ebrakes are on opposite sides could i just swap out the AC section? That would be the AC controls and the bezels and the lower shift boots sections?
ANy help is appreciated.
THanks
Will
1FSTREX is offline   Reply With Quote
Old 08-29-2006, 08:31 PM   #2
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
The AC is nowhere close to a direct swap. Lots more than what you can see needs to be changed. I believe the general consensus is that it's not worth it... But maybe someone has done it since last we decided that.
RP31 is offline   Reply With Quote
Old 08-30-2006, 03:23 AM   #3
1FSTREX
Member#: 109348
05 STI
CGM
BUMMER! anyone else agree or disagree? Hopefully disagree.
Old 08-30-2006, 05:52 AM   #4
TX_Travis
Member#: 111648
04 wrx
all i know is the 2004 got the shaft on cup holders
TX_Travis is offline   Reply With Quote
Old 08-30-2006, 07:57 AM   #5
SparkysJDMSpeedWagon
Member#: 52530
2004 For Sale:
Silver 04 wagon w/18g
You might be able to swap with lower trim 2005 models. If i remember right, the 2004 STi just had "hot-cold" controls, and 2005 was when they started with the degree's (i believe it's like 60-80 degrees). If that's the case, just find a 2005 WRX or 2.5RS dash, and swap it over. Still have the 2005 look, just without having to swap all sorts of controls inside the dash.
SparkysJDMSpeedWagon is offline   Reply With Quote
Old 08-30-2006, 08:50 AM   #6
ekw
Member#: 92141
2004 WRB STi TiC,RCE
Kartboy &Cobb-Jorge tuned
my 04 STi has degrees.
other issue: i believe in 05 the mirror control moved from the center console to the driver's door (w/ lock & window switches)
so, you are looking at a re-wire & re-locate or cutting your 05 console for the controller.
ekw is offline   Reply With Quote
Old 08-30-2006, 10:58 AM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Old 08-30-2006, 10:42 PM   #8
cleatis
Member#: 70144
05 STi
CGM
Here is my write up of the install
http://forums.nasioc.com/forums/showthread.php?t=930389
and this link has pictures, although it is the same write up
http://www.iwsti.com/forums/showthread.php?t=41293
Nick
cleatis is offline   Reply With Quote
Old 08-30-2006, 11:17 PM   #9
size18boarder
Member#: 118637
2004 Sti w/sr55
jpb
im not a member so i cant see the pics
size18boarder is offline   Reply With Quote
Old 08-31-2006, 12:35 AM   #10
cleatis
Member#: 70144
05 STi
CGM
Ok, like many other 04 STi owners I hated my center console and dash. The problem was fueled more every day when I tried to use the “cup holders”. My hatred for the center console and climate control was compounded when the 05’s came out…. Ever since I have always wanted to convert my console over to the new style.
Well I knew that I would not be able to buy all the parts new, the cost was going to be outrageous. I kept an eye out for a wrecked 05… Well I finally found all the parts that I needed, for the conversion on eBay. I won the auction and paid $180 for all the needed parts to do the conversion. All the parts came out of a totaled 05 STi.
Once I got all the parts I was excited to see that I got the 05 E-brake assembly and some miscellaneous brackets to do the swap. I even got the DCCD switches, climate control and an armrest extension. See the attached picture of all the parts that were sent. They were all in great shape with no major blemishes.
The install was pretty straight forward. I first removed the complete 04 console, radio, center vent all the way back to the e-brake. I then removed the e brake.
The fist step was so see it the 05 brake would bolt in. And it does. It will bolt in with two of the existing bolt holes (note the 04 is only bolted in with 2 bolts). Now to get the e brake in you will have to move all the DCCD sensors. So I unplugged them and took them out for now. I bolted in the e brake and I found that the cable was too long, and I was unable to tighten the e brake enough to hold the car. So I went to Lowe’s and bought a coupler for steel cable in 3/16. I then cut the e-brake cable and shortened it by about ¾ of an inch see pics.
I then had the e brake working properly. I Had to lengthen the e-brake wire, nothing major, I did the swap at home and my soldering iron is at work so I had to use a but connector, but I will solder it in this week.
Now there is a metal dash bracket that is screwed to the 04 console plastic and two 10mm bolts hold it to the metal dash. You will have to take it out and install the 05 bracket. Then I installed the upper portion of the center consol, it screws to the metal bracket that was just put in. It just screws in with a total of 4 screws IIRC, but you will have to take out the glove box and the left under dash trim and metal brace under the steering wheel.
Next to install was my radio. I found that the cheap metal brackets that hold the radio to the dash are different from 04 to 05, so I had to order them from the dealer ($7), so no radio for a week. I guess I will listen to all my rattles instead
The radio trim plate goes in next, and yes the climate control plugs in and every thing works properly. Also the 04’s don’t have the AUTO feature for the vent position but the 05 does, Well it works fine. Plug and play.
I just installed the center console radio trim. It snaps in on the top and two screws hold it in on the bottom.
I then installed the center dash vent. The hazard switch plugs right in and the vent snaps in. No biggie.
I then went to permanently install the e-brake. I used a washer to shim the e brake so it did not lean to the left. I put it around on of the studs that is welded to the body and not used. The brake is bolted down with 2 12mm bolts. There is a provision on the far left side of the brake for a 3rd bolt, but there is nothing on the car to bolt it to. Also it was flat with the bottom of the e-brake and hung over the curved part of the tranny tunnel. So I bent it down to fit flat on the tunnel for more lateral support.
Now for the DCCD sensors. There are three sensors in total. I had to move the two rear ones. I just bolted them to the rear bolt of the front sensor. They cleared everything and all the wiring was good to fit. But there is only one bolt holding them in now but they are secure.
There is a metal bracket that holds the rear portion of the console, is goes behind the e brake. It has one bolt to hold it on in the rear and two in the front. It fits tight with the stock e-brake cable, but with the shorter e-brake cable that I hade, the cable collet, was hitting the front left mounting tab, and I had to cut the tab off for room. I will go back later and fab up a new mount for it so it has all the strength that it can have, although the
console is nice and secure and does not move.
Now screw in the bottom of the center console, two screws on the rear bracket mentioned in the last paragraph, one screw behind the shifter in the floor and two screws up front behind the air bag control unit. The holes are already their in the floor for the screws.
Now install the front sides of the console. They clip in at the rear and two screws on each side up front, but leave the bottom screws out because the glove box and under dash trim have to go on before the bottom screw.
Now I put on the e brake cover. I found that the 05 DCCD adjustment switch was backwards of the 04 switch. When I move it up, it moved the DCCD back. So I had to install the 04 switch. My wiring was already long enough because I relocated the switch a year ago next to the other DCCD switch. I had to trim the ear off for the switch go in the hole but nothing a sharp razor blade could not fix. With the 04 switch the DCCD was working normally. Just plug in the switches and move the wires so they are out of the way and put the cover on. Two screws hold it on in the front and two more in the rear.
Then just snap on the shifter trim plate, the cig lighter plugs in.
I left out the mirror switch because I will be getting 05 door panels some time and rewiring the switch to fit in the panels. For now I left the switch out of the car and tucked the wires in the console.
That’s it.
Here are Cliff’s Notes
Remove complete 04 console, Climate control and e brake
Shorted e brake cable about ¾ inch.
Install 05 ebrake
Trim rear console bracket mounting tab if needed
Relocate DCCD sensors
Lengthen DCCD wires
Reuse 04 DCCD roller switch
Install new metal bracket to dash
Install new console
Here are the only problems I found that made it a little more than a bolt in
E-brake cable to short.
My e-brake leaned to the left, I could not tell if it was bent from the car it came out of being wrecked or if that is how it is. I shimmed it and bent it over to sit normally.
DCCD switch for 05 is different
Need to lengthen DCCD wires
Need new radio brackets
Need metal dash bracket for a 05
Need 05 door panels for mirror switch
I am sure that there is many different ways to get around to shorten the e-brake cable, but that was the best I came up with at the time.
Here are pics of the important parts of the install. As putting the console in after the brackets and e-brake are in is pretty simple. I will post final install pics when I get the radio brackets in from Subaru and the radio in. until then these will have to do.
All parts I used
Finished Install
Another finished Install
05 metal dash bracket needed to hold radio bezel section of trim
Difference in e brakes
Modified e brake cable (shortend)
Stock rear console/ arm rest bracket
Modified arm rest/console bracket
05 ebrake assembly in the car
Nick
Old 08-31-2006, 07:25 AM   #11
jtanoyo1
Member#: 102050
2004 JDM WRX STi
Diamond White
Hi Nick,
Thanks for the awesome post. I got a question for you. When you got all that stuff from ebay, for the electronics behind the HVAC, did you transfer your original 2004 one to behind the new 2005 HVAC or did the HVAC you get from ebay already comes with the electronic module behind it and all you need to do is unplug the old one from the cable and just plug the cable to the new HVAC control?
if possible, do you have a picture of the back of the 2005 hvac plate? I wanna see if the old 2004 hvac electronic unit is transferrable to the 2005 one....
Thanks for the reply!
jtanoyo1 is offline   Reply With Quote
Old 08-31-2006, 07:39 PM   #12
SOOB22584
Member#: 82823
AWESOME thread. Gonna do the same thing to my '06 WRX TR. Might not be as difficult for me though...right?
SOOB22584 is offline   Reply With Quote
Old 08-31-2006, 11:23 PM   #13
cleatis
Member#: 70144
05 STi
CGM
jtanoyo1,
To answer your question, I used the 2005 HVAC on the car. The Hvac behind the panel is physically differnt and the 2004 Hvac will not fit on the 2005 dash trim panels. In order to do the sway you will need the complete 2005 HVAC panel. But on the good side all the plugs from the wire harness plug right in.
nick
Old 09-01-2006, 02:05 PM   #14
imprezive one
Member#: 16906
2k3 wrx wagon
That is SICK!
I have an 02 and this makes me wonder how much homology there is between the 04 and 02 consoles... maybe I can put an 05 center console in my 02 using the same principles?
imprezive one is offline   Reply With Quote
Old 03-07-2007, 02:10 AM   #15
veightkiller
Member#: 78967
2011 335i
isnt the 02 wrx using cable type on the dials and the 05 on is powered? oh well if they can do it i dont see any reason why you can't.
veightkiller is offline   Reply With Quote
Old 03-21-2007, 05:40 PM   #16
PSMWRX
Member#: 21030
Just to add to this. You dont have to shorten the ebrake cable. I took the cable off of my 04 e-brake and put it on the 05 e-brake and it work s great. The car holds fine on steep hills.
Also I found that you may want to go ahead and buy the rear mount underneath the back of the center console. The holes on mine from the 04 dash were to far to the right(passenger side) making the 05 console sit up against the passenger seat.
PSMWRX is offline   Reply With Quote
Old 03-21-2007, 08:42 PM   #17
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
Yeah the 02-03 and my 04 wrx are using the manual climate controls. I found out from members on iwsti that when you do the 05+ console swap to buy the 2.5l RS center piece(not the wrx/sti) because it also uses the manual climate.
100_Percent_Juice is offline   Reply With Quote
Old 06-19-2007, 06:00 AM   #18
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
does anyone know the part number for the rs radio bezel (center piece)?
arco is offline   Reply With Quote
Old 08-14-2007, 09:20 PM   #19
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
yeah how much would it be to get the new ebrake and center console new from subaru genuine parts?
i HATE my cupholders. hate them enough to do this.
Handsdown is offline   Reply With Quote
Old 08-14-2007, 10:15 PM   #20
PSMWRX
Member#: 21030
Ebrake = just under $100. Center console (all parts that it consist of) is about $140. That was what I was quoted at my dealership. But I pieced everything together for a lot less between f/s ads here and ebay.
Old 08-15-2007, 03:29 AM   #21
teamslow wrx
Member#: 18986
2002 wrx
sliver i Have 4 cats!!!
i got my ebrake on here for like 10 bucks lol
teamslow wrx is offline   Reply With Quote
Old 10-08-2008, 08:39 PM   #22
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
Hey guys, I bought the 05 manual shift boot but it does not have an opening at the top to go pass the "reverse lift" on the STI shifter. Anyone know how to get the 05 boot to work with the sti shifter?
chanders is offline   Reply With Quote
Can you swap 07 sti seats with 08 sti seats? subaru110 Interior & Exterior Modification 5 07-18-2008 03:08 AM
Trouble with new oil filter 15208AA09A - DETAILS INSIDE SubaruGenuineParts Warranty Issues & SOA Problems 468 04-22-2007 04:41 AM
Can I swap just the cloth parts from an 05 STI door panel to an 04 wrx? xcdhridr Interior & Exterior Modification 4 09-30-2005 10:27 AM
-= 03-22-04 -- 1st West Coast All Subaru Track Day. Details Inside=- joltdudeuc Southern California Impreza Club Forum -- SCIC 41 01-24-2005 02:31 AM
-= 03-22-04 -- 1st West Coast All Subaru Track Day. Details Inside=- joltdudeuc Bay Area Impreza Club Forum -- BAIC 6 03-05-2004 04:19 AM
