Old 10-29-2001, 11:51 AM   #1
MarkZ
Member#: 11232
2010 Outback 3.6
Default Wheel offset, what is it?
As per title, what's is wheel offset,
If I buying wheels, how does offset affect my choices, and finally what is the off set for a 2002 WRX Sedan
MarkZ is offline   Reply With Quote
Old 10-29-2001, 12:16 PM   #2
Poseidon
Member#: 4864
2004 WRX
Wheel offset is a measure of how far the hub (where it ataches to the car) is from the horizontal center of the wheel. So if you're looking at your car's wheel head on, zero offset would put the hub right in the center. Positive offset puts it further away from the car. Negative offset puts it closer to the car. I hope that makes sense, because without a diagram, I can't think of a better way to explain it. Subarus have an unusually high amount of positive offset on their stock wheels. I think it's somewhere in the low to mid 50s (+54?). I think the official minimum is +48.
[edit] actually, go <a href="http://www.tirerack.com/wheels/tech/offset.htm">here</a> for a better explanation and a diagram.
Jordan
Poseidon is offline   Reply With Quote
Old 10-29-2001, 01:38 PM   #3
jetfreak
Member#: 3056
2001 Impreza 2.5RS
Blue Ridge Pearl
+53mm offset for Subaru wheels. Try searching in the susp, brakes, rim and tire section. This has been covered many times before in there.
jetfreak is offline   Reply With Quote
Old 10-30-2001, 09:53 AM   #4
MarkZ
Member#: 11232
2010 Outback 3.6
Thanks,
the website and info are all being written down and bookmarked.
Old 10-31-2001, 11:07 AM   #5
redobs
Member#: 1501
2009 WRX wagon
Dark grey
You will be able to get away using wheels with +48 offset.
redobs is offline   Reply With Quote
What is it with wheel bearings? rick-l Service & Maintenance 4 03-20-2007 07:24 AM
What is it about the "Subaru" which made you buy one ? What makes it a great car ? alfriedesq General Community 58 09-11-2006 06:24 PM
machined cut inside wheel, what is it? homer09 Tire & Wheel 7 04-11-2006 10:02 AM
Brake/Wheel Creeking... What is it? AVATAR-X Service & Maintenance 10 03-16-2003 05:45 PM
JIL symbol found on many alloy wheels, what is it? Snappy Brakes, Steering & Suspension 1 12-16-2001 03:40 PM
