Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 08-30-2006, 04:18 PM   #1
ColesSTi
Member#: 99205
2005 Impreza WRX
Default Top mount Oil cooler/tran cooler
Top mount Oil cooler/tran cooler using the hood scoop to give the air to the cooler. Anyone tryed it? On the WRC car it is on the fender well. I know there are ones for my car but would one from summit work?
http://store.summitracing.com/egnsea...839034&NeXID=5
ColesSTi is offline   Reply With Quote
Old 08-30-2006, 05:33 PM   #2
elsanto
Member#: 34832
1989 M3
I'd keep it as far away from the engine as you could. since lag is not an issue with oil it doesnt matter all that much wher eit is, why sit it ontop of your hot engine?
elsanto is offline   Reply With Quote
Old 08-30-2006, 06:02 PM   #3
ColesSTi
Member#: 99205
2005 Impreza WRX
Yea, that's true elsanto. Would these ones work fine they cost what they should, not half of a grand. I would like to extend my oil's shape when I switch to Royal Purple.
Old 08-30-2006, 09:02 PM   #4
DanWRX
Member#: 36963
I remember a thread about someone who put an oil cooler under the hood scoop since they had a FMIC.. something got ingested into the hood scoop (rock?) and broke the oil cooler. Oil went all over the engine and set it on FIRE. He moved the oil cooler after that
DanWRX is offline   Reply With Quote
Old 08-30-2006, 09:56 PM   #5
ColesSTi
Member#: 99205
2005 Impreza WRX
That's what I was thinking but maybe the mesh from Seibon's hood scoop wouldn't protect me from a rock.
Old 08-31-2006, 08:10 AM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the same rock punching through a front mount oil cooler may not have caused a fire, but would the block be any better off?
B-Line top-mount oil cooler installed DroppedClutch Water/Methanol Injection, Nitrous & Intercooler Cooling 23 05-30-2009 08:42 AM
top mount oil cooler setup shwoop_soobie Engine/Power/Exhaust 24 04-14-2009 11:10 AM
Top mount oil cooler? midnightsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 08-14-2006 01:48 AM
Top Mounted Oil cooler stevo2234 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-16-2005 06:35 AM
Top-Mount Oil Cooler? dl337j00 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-27-2005 09:31 PM
