Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-30-2006, 06:27 PM   #1
LoganM111
Member#: 124546
2001 Forester
Red
Default Error codes cause failure at DMV
Hello, my 2001 Forester S just failed DEQ due to a couple of error codes that popped up. The emission and noise tests passed.
One of the error codes was "P0328 Knock Sensor 1 Circuit High Input (Bank 1 or single sensor)"
The other code was "P1518 Starter switch circuit low input".
Is there a way to fix these on your own and reset the code without having to take it in? Any advice would be greatly appreciated!
LoganM111 is offline   Reply With Quote
Old 08-30-2006, 06:40 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Were they stored codes or do you have a constant CEL? You can go to Autozone and "rent" an OBD-II scanner for "free" with a refundable deposit. It will read them and clear them for you. But if your knock sensor is bad, clearing the code won't do you much good as it will come right back. Replacing the knock sensor is not too hard. It's directly under the throttle body on the driver's side of center. It's the black cylinder mounted to the block with a 12mm bolt.
As for the starter code, I don't know about that one...
Old 08-30-2006, 07:03 PM   #3
LoganM111
Member#: 124546
2001 Forester
Red
Thanks! The knock sensor is definately a place to start. The starter code is a subaru specific code, I dont know where to start with that one.
Old 08-30-2006, 10:24 PM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Always a good idea: Put your location in your profile. There might be someone nearby who would clear those codes out for you.
Further, before you'll pass inspection, you'll need a certain number of (I forget the correct term) conditions to be set to "Ready". When the ECU is reset, they all go blank. After driving in certain conditions, these registers set themselves to "Ready". You need to have a certain number of them good-to-go in order to pass. I think my car would have gotten by with two not ready, but I only had one. You can check the status of the registers with an OBD-II reader, as well.
LetItSnow is offline   Reply With Quote
Will 50/50 water/meth mix degrade synthetic oil, causing failure? skimobile Water/Methanol Injection, Nitrous & Intercooler Cooling 22 08-01-2007 10:00 PM
Here's a new one: MAF Error Code -- Transmission Error scooterforever Transmission (AT/MT) & Driveline 2 10-12-2006 08:06 AM
Help Needed Reading AT Error Code arcsound Transmission (AT/MT) & Driveline 9 03-19-2005 02:40 PM
Need help with Error Codes Brinky Normally Aspirated Powertrain 0 11-17-2000 06:52 PM
