Old 08-30-2006, 08:09 PM   #1
rides20
Member#: 87246
2007 Leggy Limited
Default Finally, a clutch creek/squeak fix!
Sorry if someone else has found it, but I was excited!...Under the big black box on the RS, and under the intercooler for those of you fortunate enough to have a turbo.......On the top edge of the transmission, there is the slave cylinder....the squeak/creek noise comes from the shaft of the slave pushing on the linkage...grab the linkage and pull it forward (towards the front of the car) to push the slave piston back into the slave cyl.....quickly wipe the grease and crust from between the linkage and piston (before the slave resets itself)...repeat that but install a fresh blob of good grease and BAMMMMM! no noise!!!!!!
rides20 is offline   Reply With Quote
Old 08-30-2006, 10:51 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Yep. That's one of the labeled grease points in the service manual. There's also a few more you can get to in the pedal assembly so if the noise comes back start to look at those as well.
Old 09-13-2006, 09:56 PM   #3
rides20
Member#: 87246
2007 Leggy Limited
Noise came back!!!...I took it in and they replaced the Pressure Plate, release bearing and the friction disc...smooth as silk, silent as hell!
cheap oily dash squeak fix Bluefoton Car Audio, Video & Security 9 06-05-2010 08:43 PM
Finally silenced the creeking.... jigga Interior & Exterior Modification 4 05-02-2006 09:45 AM
('93-'01) Sunroof Squeak Fix? RacerX Impreza Forum 13 10-12-2001 12:26 AM
('93-'01) Anyone have a clutch that squeakes SubaruEJ25 Impreza Forum 6 09-23-2001 08:00 AM
Clutch pedal squeak Texas25RS Texas Impreza Club Forum -- TXIC 2 08-14-2001 10:30 AM
