Old 08-30-2006, 09:09 PM   #1
SnellingSubaru
Member#: 123599
Default Valve Adjustment Possibly w/o Manual
I just brought a '97 Impreza OS home. It sounds as if one valve on the left bank needs adjusting (ticking cold much less when running temperature). Parts stores are closed so I cannot purchase a manual until morning. Would anyone be willing to provide the valve adjustment specs or point me to a thread I may have missed. I searched and found some forum confusion on the '97 2.2L having hydraulic lifters or no lifters. My engine is the latter.
Is there a descriptive thread or site that has the necessary specs listed?
Thanks,
Steve
SnellingSubaru is offline   Reply With Quote
Old 09-04-2006, 04:40 AM   #2
SnellingSubaru
Member#: 123599
Intake 0.20mm and exhaust 0.25mm. Easy job, did not require gasket or grommet replacement.
Tried SeaFoam for the first time. Poured it slowly through the brake booster vacuum line until 1/2 can was digested by the warm engine. Shut it off for about a twenty minutes. Started it and took it for a ten mile trip. Smoked for the first couple of miles and now is quite smooth. Since the valve adjustment resulted in a quiet and smooth idle I am not certain if the SeaFoam actually did anything or is just a $9.00 snake oil.
Steve
valve tick or valve adjust? ali dashty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-06-2008 06:15 PM
Valve adjustment w/ solid shimless lifters? scooby5 Service & Maintenance 5 11-11-2001 11:25 AM
Power increase by valve adjustment alone? jazzman Normally Aspirated Powertrain 3 08-11-2001 12:28 AM
Has anyone done valve adjustments MY99 2.5GT Normally Aspirated Powertrain 2 06-27-2001 05:55 PM
Valve adjustment Pinoy Southern California Impreza Club Forum -- SCIC 0 06-13-2001 10:42 AM
