Old 08-31-2006, 02:30 AM   #1
rallymarty
Member#: 17418
2003 4Runner
OMGHi2U Adjusting Brake Pedal
When I am braking and downshifting, i have noticed that the brake pedal travels a tad further than the gas pedal, approx about .5 or .75 further. When braking hard, my foot tends to hit the gas pedal also, causing an unwanted over rev, and then f#cking up my downshift. I have taken a look at the brake pedal and it is adjustable. Anyone else done this? Just interested to see if anyone else is as irritated by this as i am.
rallymarty is offline   Reply With Quote
Old 08-31-2006, 06:21 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
****retracted****
Last edited by nhluhr; 09-22-2009 at 01:37 PM. Reason: people use this technique incorrectly.
nhluhr is offline   Reply With Quote
Old 08-31-2006, 08:49 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
nice writeup, nick.
Old 08-31-2006, 09:24 AM   #4
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
copy+paste from an old post I made
Old 08-31-2006, 11:08 AM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Thanks Nick!
This should be in a threads of note somewhere... *adds*
Old 08-31-2006, 10:26 PM   #6
rallymarty
Member#: 17418
2003 4Runner
thanks for posting that writeup. i just want my brake pedal so that under threshold braking, the pedal doesn't travel past the throttle's closed height.
i would like it so i can just roll my foot over to blip the throttle.
Old 09-01-2006, 04:49 AM   #7
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Retracted
Old 04-14-2007, 10:47 PM   #8
AnorexicSTI
Member#: 85227
2005 STI
Is there a way to adjust the gas and clutch pedals as well?
AnorexicSTI is offline   Reply With Quote
Old 04-16-2007, 03:44 AM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
The clutch pedal can be adjusted similarly, but be careful as misadjusting this will not just decrease feel but could also cause your clutch to slip, leading to an expensive early failure of the part.
The throttle pedal isn't really adjustable... on the cars with an actual linkage and cable, you can adjust the slack in the cable and with DBW cars you can alter the throttle mapping in the ECU to change the response but neither will get you much change in actual driveability.
Old 05-06-2007, 11:32 PM   #10
ib2qwik2c
Member#: 147890
2007 WRX TR
BLACK
thanks alot!
ib2qwik2c is offline   Reply With Quote
Old 05-24-2007, 06:53 AM   #11
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Is the flare wrench is mandatory? I only have normal wrenches, would a 17mm wrench work with the lock bolt?
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 05-24-2007, 09:35 AM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
No, it's not manditory.
Tony
Old 05-24-2007, 10:43 AM   #13
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Subscribe.
Old 04-26-2009, 05:05 PM   #14
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Were there pics originally?
Superorb is offline   Reply With Quote
Old 04-26-2009, 07:12 PM   #15
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
fixed
Old 04-26-2009, 07:23 PM   #16
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by nhluhr View Post
fixed
Sweet, thanks Nick
Old 08-20-2009, 08:52 PM   #17
Mooneyes13
Member#: 113666
60' all over you
good thread. thanks
Mooneyes13 is offline   Reply With Quote
Old 08-21-2009, 01:24 PM   #18
02wrxRally
Member#: 205994
'02 Bawkeye WRX
'04 tOtaledBS | '68 MGBGT
yep well you turn out the MC rod a bit then turn out the brakelight switch a bit and you will have your desired height.
I'm confused a bit (sorry, noob wanna-be-mechanic here) - The adjustment range of .5mm to 2mm - isn't that what your adjusting when you turn the rod? and that's just for free play before the pedal is depressed? The way I'm interpreting this is that you can only move the pedal 2mm up from the floor? That sounds wrong and I'm sure it is. Can you clarify how it is that I can move the brake pedal to be level with the gas when braking without putting more than the acceptable free play in the pedal before the brakes engage?
Thanks
02wrxRally is offline   Reply With Quote
Old 08-21-2009, 01:33 PM   #19
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
the freeplay is limited by the brake switch. So if you move the pedal out closer to you, you'd be reducing the freeplay. You need to move both the switch and the pedal out in unison to assure no change in freeplay if your only goal is to move the pedal position.
Old 09-22-2009, 12:33 PM   #20
potterspread
Member#: 223769
How do you know if you have dragging brakes? I have a pulsing feel every 2 seconds when I drive the car know. I'm not sure if I went too far. Actually I went almost all the way so that I would stiffen up the pedal.
potterspread is offline   Reply With Quote
Old 09-22-2009, 01:36 PM   #21
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
You went too far.
Old 09-22-2009, 08:17 PM   #22
Butt Dyno
Member#: 17301
is the "dark side"
Check if the wheel is hotter than the others after driving. Obviously be very careful when you do this
Old 08-19-2010, 10:33 PM   #23
02rexxy
Member#: 248044
02 WRX
sorry for the strong bump... can the brake pedal be moved closer to the gas for heal toe down shifting?
02rexxy is offline   Reply With Quote
Old 08-19-2010, 10:44 PM   #24
Turn in Concepts
Member#: 93646
Many Track Records
No, but we have some pedals that will help with that. Check our our SRP racing pedals.
Tony
Old 08-26-2010, 08:37 PM   #25
WRC-STI
Member#: 39707
2004 STI
I was able to move my gas pedal over about an inch towards the brake pedal on my 04 STi. I took a 1/4" thick flat piece of aluminum and drilled holes to go over the existing studs. Using the original nuts to secure the plate to the floor. Then I slid the gas pedal assy as far to the left as I could without hitting the steering column. Then I marked where the holes in the pedal assy were. Then removed the aluminum, drilled the holes out and installed the petal assy using countersunk screws and self locking nuts. Then reinstall the aluminum back over the original studs and secured with the original nuts. Then again wider gas pedals would be nice.
WRC-STI is offline   Reply With Quote
Can Brake Pedal Height be Adjusted? Oldalfaguy Brakes, Steering & Suspension 6 01-25-2007 11:51 PM
How do I adjust the height of my brake pedal? Jag32 Brakes, Steering & Suspension 4 06-23-2006 05:40 PM
WRX brake pedal height adjustment? Darryl Brakes, Steering & Suspension 2 02-04-2004 04:53 PM
How do you adjust accelerator to level w/ brake pedal? codemunky Transmission (AT/MT) & Driveline 3 12-30-2001 04:16 PM
brake pedal adjustment jlyttle New England Impreza Club Forum -- NESIC 7 06-24-2001 02:49 PM
