#1 |
Member#: 50183
W. Canada
Vehicle:1999 2.5RS x2 RBP & BDP |
I have researched the issue, and have a few ideas, but if your car was burning oil, but only seemed to do it when you really stepped on it, what do you suspect would be some of the most obvious causes.
My car is a 5 speed 99RS, 58000 miles. Brullen Headers, and Catback, and an Injen CAI. I suspect it is most likely my valve seals, but i am curious to hear some other opinions... Thanks
#2 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
What weight oil are you using? Have you checked your pcv valve?
#3 |
Member#: 72132
NWIC
Vehicle:2000 Legacy GT White |
will a bad pcv valve cause a car to burn oil?
#4 |
Member#: 50183
W. Canada
I replaced my PCV Valve 2 days ago, i can't tell yet, if the problem is resolved. It seems better, but I suspect that may just be wishful thinking. I cleaned my tail-pipe the other day to see how long it would stay clean for, and so far so good. I am currently using 10w30, since I was wondering if it may last longer than the 5w30 that is recommended. Perhaps a switch to synthetic?
#5 |
Member#: 50183
W. Canada
The package on my PCV valve specifically stated that it should improve oil consumption.
#6 |
Member#: 123139
NWIC
Vehicle:1993 Turbo L Wagon RED |
what makes you think you are burning oil? A big puff of black smoke at WOT? Are you noticing that you are consuming oil on your dipstick? Is there wet oil in your tailpipe or just lots of black carbon buildup?
If all you are seeing is lots of black smoke at WOT, then you are probably just seeing unburnt fuel as you go rich at the top end. This is ok and normal. If you are getting alot of blue smoke then you might just have a loose motor that gets more blow-by at the top end, also ok, unless you are doing a spy-hunter in which case, that is not ok. If you are noticing that you are consuming oil by checking the dipstick, at what intervals are you checking etc. Are we talking a quart every 3000 miles or every 100? If you rail on your car and live near redline, you will use oil and that is fine it does not mean your motor is bad. If you are blinding traffic with your 007 smoke screen at WOT, you might have bad rings or headgaskets etc. in short... <<<<MORE DETAILS>>>> |
#7 | ||||
Member#: 50183
W. Canada
It isn't a smoke screen at all, but still seems to go through a ****load of oil. I am wondering if it could be o-rings??? The car only has 58000 miles, so that is not that many. |
#8 |
Member#: 50183
W. Canada
I drove to the lake this weekend, an hour each way. I get back, my tail-pipe is black, and my oil is no longer at the top. So the PCV valve was not the culprit...What is the next logical thing, my valve seals?
#9 |
Member#: 43602
NESIC
Vehicle:2005 Outback Sport |
Valve seals or piston rings are a possibility.
| Thread Tools | |
| Display Modes | |
| EJ25D re-clocked ECU - 10% higher rev limiter. $50 SHIPPED | Patrick Olsen | Engine/Power/Exhaust | 7 | 05-21-2010 02:42 PM |
| Streettuner Cams and Higher Revs | greysave | AccessPort | 9 | 03-21-2006 03:29 PM |
| 1993 Subaru Impreza burning oil at idle after oil change | Joe Pollock | Service & Maintenance | 3 | 08-15-2005 11:15 PM |
| For a higher rev limit | mistaboosta | Factory 2.0L Turbo Powertrain | 20 | 04-18-2005 06:03 AM |
| Car revs funky in lower gears at higher RPMs | DoctorNick | Transmission (AT/MT) & Driveline | 7 | 08-24-2004 05:23 PM |
