Old 08-31-2006, 04:29 PM   #1
BURTONRIDR
Member#: 72132
2000 Legacy GT
Default Timing Belt tensioner
I forgot to compress it and insert a pin into it before I took it out. Now its like a rock and I dont know if I can compress it back in.... Any ideas? I dont want to break it.
BURTONRIDR is offline   Reply With Quote
Old 08-31-2006, 07:40 PM   #2
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
No biggy. Get a c clamp. It should take you at least a FULL minute to do it, but very slowly tighten it until you can put the pin through.
t3hWIT is offline   Reply With Quote
Old 08-31-2006, 09:26 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
And hold it vertical while you tighten it. If you do it horizontally all the magic falls out.
Seriously, it is supposed to take 3-4 minutes and it is supposed to be held vertically. Very small tightening increments over an insanely long amount of time should do it.
Tim Sanderson is offline   Reply With Quote
Old 08-31-2006, 10:27 PM   #4
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
I use the claps they use to hold wood when you cut it
And put a penny in the end of the shaft.
They compress it really easy and they go slowly.
Guerice is offline   Reply With Quote
Old 09-01-2006, 09:33 AM   #5
Skidd
Member#: 1853
GC6 Supercharged
STM
A bench vice will to the trick also.
Skidd is offline   Reply With Quote
Old 09-01-2006, 10:18 AM   #6
BURTONRIDR
Member#: 72132
2000 Legacy GT
LOL Thanks.... sorry I cant believe I didnt think of a c-clamp, all I could think was "man I was I had a bench clamp"
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
FS: 2.5L dual cam timing belt, tensioner & tensioner adjuster $150 fornetti14 Legacy Specific Parts 0 06-20-2009 08:45 PM
Pay shop or DIY Timing Belt Tensioner and inner drive belt erikkellison Service & Maintenance 23 02-26-2005 02:28 AM
Timing belt tensioner holding tool? spshultz Service & Maintenance 1 12-09-2001 03:24 PM
('93-'01) Resetting timing belt tensioner!?! The Real Oaf Impreza Forum 5 07-12-2001 03:19 AM
