Old 09-02-2006, 12:49 PM   #1
DaKP00r
Member#: 113636
2007 Stg2 STI #277
06 YZ450F
Default How did you guys hook up your Hella horns?
I ordered + got mine the other day, and im not the best with wiring but I was curious how you guys hooked them up? I got the diagram but I thought it would be close to plug and play as the stocker but maybe not?
Any help would be nice....
DaKP00r is offline   Reply With Quote
Old 09-02-2006, 01:03 PM   #2
hocman99
Member#: 110434
2004 04 wrx psm
nyeaa & cuhhh
dont use hella relay in my opinion...just get some wire and some male and female connectors & crimp & connect... ground to a near bolt & ur done... i honesty dont think that the hella relay is needed the factory one is fine... & i no ppl r going to say " im wrong its louder with the hella relay" but u know what even if it is.. which i dont think it is, the 5 dB difference doesnt matter when u unlease the horns on a dumb@ss driver
jared
hocman99 is offline   Reply With Quote
Old 09-02-2006, 01:54 PM   #3
Imprezive_04
Member#: 104591
02 Zed06
08 Evo X
1st search
2nd they wouldn't put the relay in there if you didn't needed, but hey who follows directions anyway
Imprezive_04 is offline   Reply With Quote
Old 09-02-2006, 01:54 PM   #4
DaKP00r
Member#: 113636
2007 Stg2 STI #277
06 YZ450F
so just wire the power tabs together on the horn and ground them and tie the stock wire into the power wire?
*edit* lol its a wiring question i would prefer to not search cause wiring can get tricky, so why not just get a direct answer for the question i need?
Old 09-02-2006, 02:05 PM   #5
Imprezive_04
Member#: 104591
02 Zed06
08 Evo X
it has been answered 10000000000000000 times with diagrams and everything you could possibly want to know for the 3 or 4 different ways people hook them up, not to mention the 2 diagrams that comes in the box with the horns
Old 09-02-2006, 02:15 PM   #6
tacomaprime
Member#: 70572
2005 Tacoma
jared
Please don't give out information that you are obviously not up to date on yourself. The relay is there for a reason. And I am pretty sure that there are multiple threads where people hooked them up without the relay and complained that they weren't loud enough, so they went back and hooked them properly using the relay and said they were louder with it.
tacomaprime is offline   Reply With Quote
Old 09-02-2006, 02:18 PM   #7
tacomaprime
Member#: 70572
2005 Tacoma
This is the diagram you want to use to hook them up. I used them as have multiple people on here. If you do it this way, they will be as loud as they were designed to be.
Old 09-02-2006, 02:49 PM   #8
jk988
Member#: 60959
'03 WRX
^That's the way I wired mine in. Hella provides the relay for a reason.
jk988 is offline   Reply With Quote
Old 09-02-2006, 02:54 PM   #9
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
The relay that came up with mine was not functioning. I just used the stock wiring. I compared it to another person who wired it the relay and they sounded about the same.
dauss is offline   Reply With Quote
Old 09-02-2006, 03:49 PM   #10
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Correct me if I am wrong, but it's possible to just take out the stock horns, connect the supertones right to the existing wiring (without changing the female connectors), ground them, and they'll work. It's that simple.
But mine are hooked up in the same way as the diagram that was posted earlier.
RP31 is offline   Reply With Quote
Old 09-02-2006, 03:52 PM   #11
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
thats the way mine are hooked up, just took off the stockers, and then spliced some more wire so it would reach to my mounting location.
Old 09-02-2006, 04:06 PM   #12
REX8
Member#: 24038
Double post below...
Old 09-02-2006, 04:07 PM   #13
REX8
Member#: 24038
THE RELAY HAS NOTHING TO DO WITH LOUDNESS!!!!!
Do you guys even know a relay works?????
The reason they may be louder with the relay is IF you use thicker wiring then the OEM horn wires....
That has absolutely nothing to do with the relay.
The CHEAP Hella relay is a $2 off the self 12v automotive relay...crapper than the ones used on your factory horns....its the WIRING that can make a difference...
FYI: Hella's POS relay worked for about 6 months....before it blew out...
On the facotry wiring 1 year and counting.....zero sound difference....
So please...lets just keep the information correct...
Old 09-02-2006, 04:09 PM   #14
REX8
Member#: 24038
And what is that reason????
Answer: So you can run your OEM horns with the hella's and not over load your wiring....
If anything....the OEM 12v relay is higher quality than the POS Hella Pep-Boys relay....
Old 09-02-2006, 04:13 PM   #15
REX8
Member#: 24038
You boys and your magic $2 12v relay
Old 09-02-2006, 06:16 PM   #16
jk988
Member#: 60959
'03 WRX
Calm down. And your answer above is my answer.
FYI, I've had my hella relay for over a year and it has not blown. In fact, I liked it so much that I bought another one for my radar detector. It's all in the wiring.
Old 09-02-2006, 06:30 PM   #17
dibblejr
Member#: 94070
73 DL Race Car
WRB/ Yellow SUby Logo
Which model Hella's is everyone using? I have been contimplating and want to install for the next 7 month driving season (snow).
dibblejr is offline   Reply With Quote
Old 09-02-2006, 09:21 PM   #18
crazyGC8
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
Supertones, I think...
crazyGC8 is offline   Reply With Quote
Old 09-03-2006, 09:37 AM   #19
ekw
Member#: 92141
2004 WRB STi TiC,RCE
Kartboy &Cobb-Jorge tuned
the "made in Germany", 118db Supertones
ekw is offline   Reply With Quote
Old 09-03-2006, 05:22 PM   #20
dibblejr
Member#: 94070
73 DL Race Car
Now we are talking i have seen others thats why I asked. Horns will be the final mod to my car until I blow her up.
QUOTE=ekw;15116476]the "made in Germany", 118db Supertones[/quote]
Old 02-10-2008, 05:15 PM   #21
fastlanerex
Member#: 133391
2004 boosted saleen
white
Great diagram should be made a sticky or sent in to scooby mods.
fastlanerex is offline   Reply With Quote
OT Question: How did you guys end up living in Alaska? rice h8r Alaskan Impreza Club Forum -- AKIC 75 01-05-2008 06:20 PM
How did you guys get over the long relationship with your highschool sweet heart Christoff Off-Topic 90 05-02-2005 09:22 AM
How did you guys install your components on the doors? slammedWRX Car Audio, Video & Security 2 02-20-2003 09:33 AM
how much did you guys pay for your WRX? Seung Chun Bay Area Impreza Club Forum -- BAIC 25 07-09-2002 05:51 PM
How did you guys replace your plugs on a MY99??? Xscreamer Normally Aspirated Powertrain 6 03-14-2001 01:57 PM
Message Board Statistics All times are GMT -4. The time now is 08:25 AM.
