Old 10-29-2001, 11:57 PM   #1
galevelasco
Member#: 3904
2002 Subaroot WRX
Rally Blue
Default Racing seat with stock seat belt?
I was wondering if you can bolt inthe stock seat belt latch for the WRX/2.5 when you upgrade to a racing seat, or do you have to go all out and get a 4 point or 6 point belt.
thanks
Ryan
galevelasco is offline   Reply With Quote
Old 10-30-2001, 12:02 AM   #2
lethargicman
Member#: 8961
2001 Impreza GM6
Rest In Peace. 2/01-10/04
Yeah, you can still use the stock seat belts. You got new seats, Ryan? Can't wait to see them!
-Jason SDC
lethargicman is offline   Reply With Quote
Old 10-30-2001, 09:08 AM   #3
FatChanceTi
Member#: 274
Default You can use both
My seat mounts/subframes came with a mounting location for the inboard seatbelt connector. Some don't.
The seats work just fine with the stock belts though.
FatChanceTi is offline   Reply With Quote
Old 10-30-2001, 10:56 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
sure you can..
it's not very safe...
the seat belt will not perform as it was intended as it no longer sits where it's supposed to on your body...
but it's better than nothing -
Jamie
www.subiegal.com
Old 10-30-2001, 03:31 PM   #5
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Could you un bolt the lower seat belt anchor, run it through the belt hole, then bolt it back up? Then you could buckle the belt through the hole on the other side, and it would properly. Unless I am missing something.
edit: Tried to add attachment pic..doesn't work like that.New post..
-Andy
RallyImprezive is offline   Reply With Quote
Old 10-30-2001, 03:49 PM   #6
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Just un bolt at the yellow circle, run the part indicated by the red line through the path idicated by the blue line, and re-bolt at yellow circle. Would that do the trick?
-Andy
Old 11-01-2001, 12:56 AM   #7
TeamSUBARU
Guest
Member#:
Arrow
Unless you are a big person...then this idea of Impressives will not work. The seats are too restrictive/forming to work for everyone.
Also. Do not anchor yor seat belts to the same bolt locations as your seats.
Old 11-01-2001, 04:28 PM   #9
Dave T-S
Member#: 8452
2001 Impreza WRX
BBM
Smile
They work fine with my UK model WRX......
PS - Hi Jamie, how ya doin?
Dave T-S is offline   Reply With Quote
BC Racing coilovers with stock tophats? jdm4you Brakes, Steering & Suspension 16 03-17-2009 08:26 AM
Whiteline 27mm race sway with stock mounts p8baller07 Brakes, Steering & Suspension 12 07-24-2007 12:58 AM
Anyone with stock seat sliders/mounting hardware? rogue Mid Atlantic Impreza Club -- MAIC 1 04-22-2005 01:22 PM
Schroth rallye 4 harness picture with stock seats? hangten93 Interior & Exterior Modification 2 05-28-2004 10:55 AM
Racing Harness on stock seats. Dub-Rex Interior & Exterior Modification 11 05-18-2002 11:54 AM
