Old 09-03-2006, 01:07 PM   #1
Eaglesfan2422
Member#: 26445
Default Engine mount problem when jacking up engine
I was changing out my spark plugs yesterday, among doing other things on the car, and I am having a problem lowering the engine back down. It looks like the driver's side drops down into place, but the passenger side has something in the way and the engine mount is not dropping all the way to the subframe.
I can't see any interference problem, but I will keep looking. Does anyone know an easy way to "shift" the engine forward? From my initial inspection, it looks like the engine somehow shifted rearward on the passenger side.
Eaglesfan2422 is offline   Reply With Quote
Old 09-03-2006, 01:15 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A bit late now, but there is no need to jack up the engine just to replace the plugs. It's tight yes, but with the proper tools you can get in there.
Did you unbolt the mounts or just jack it up? If you unbolted them and the engine moved so the mount doesn't line up with the bolt holes it's possible that it wasn't lined up properly to begin with.
Old 09-03-2006, 04:26 PM   #3
kdogae86
Member#: 99139
02 wrx
bluey
use a long bar to persuade the motor into place.keep both sides unbolted till they both line up.just did my spark plugs and didnt jack the motor.what other work did u do to require jacking?
kdogae86 is offline   Reply With Quote
Old 09-03-2006, 06:11 PM   #4
Eaglesfan2422
Member#: 26445
Thanks for the tips, it was a combination of a loose bolt that fell between the subframe and the engine mount, and it needed a slight pull forward.
I was heat wrapping my uppipe and exhaust manifold. I didn't have any trouble with cylinders 1, 2, and 3. But 4 looks pretty tight to get the spark plug out. I have flex ratchets, universal swivel joints, gear wrench ratchet, but it seemed like more trouble than it was worth than to just jack the engine up. Thanks for all the help.
Up Pipe installll helpppp!!! engine mount wont line back up?! WTFJayJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 02-24-2009 05:25 PM
When jacking up a vehicle - remember, safety first. chris619 Off-Topic 33 06-16-2004 03:42 AM
uppipe install: jacking up engine? phasedlife Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-02-2003 11:18 AM
Anything special to do when jacking up car for uppipe that won't crush oil pan? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-14-2003 12:40 AM
help jacking up engine! blaznasn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-09-2002 08:47 PM
