Old 09-03-2006, 06:10 PM   #1
ECUtuneOne
Member#: 77436
1994 SVX
Ebony pearl
Default sti 6 spd clutch &flywheel in 5spd wrx trans
Has anyone used the flywheel and clutch assembly from a sti 6 spd on a car with a 5 spd? I'm trying to find out if it is possible to use it with an 06 wrx transmission.
ECUtuneOne is offline   Reply With Quote
Old 09-03-2006, 08:14 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Reading the Clutch & Flywheel FAQ that is stickied at the top of this forum will net your answer. Read the stickys and stop clogging our forum.
Old 09-03-2006, 08:40 PM   #3
ECUtuneOne
Member#: 77436
1994 SVX
Ebony pearl
Actually I couldn't find the answer in the sticky thread. I did look. I think I've found it after searching many a thread though. I asked directly because there is so much dissagreement and argueing in the regular threads it takes a lot of reading to come up with a conclusion I can be confident in. Sorry, the truth is I'm not an impreza owner so I don't keep current on the goings on here and I need fast information for purchase decisions to be made before store hours on tuesday.
At this point I've come to the conclusion that the 2006 wrx uses a push type clutch so the whole idea of an sti flywheel and clutch is thrown out there.
I also found an Australian subie pdf document saying that the 06 wrx pressure plate has 830Kg clamping force. Now I'm curious what the clamping force on the older wrx pressure plates is. I'll continue searching on my own and I'm sure that spec won't be too hard to find but if anyone who knows wants to throw me a bone and save me some time I would appreciate it.
Old 09-04-2006, 04:27 PM   #4
ECUtuneOne
Member#: 77436
1994 SVX
Ebony pearl
Actually, I haven't been able to find the the clamping force of the stock wrx's pull type pressure plates. Does anyone know and care to help out?
Old 09-04-2006, 05:13 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
My apologies, I thought I linked it in my FAQ.
http://forums.nasioc.com/forums/showthread.php?t=496150
The clamping force won't help you one iota though as clamping force means nothing in terms of how much TQ the clutch will hold. The stock WRX clutch will hold around 300 TQ and the stock STi clutch will hold around 400 TQ, these are rough figures though.
Old 09-05-2006, 01:42 AM   #6
ECUtuneOne
Member#: 77436
1994 SVX
Ebony pearl
Thanks much,
I would probably do the grinding and go with an sti clutch and flywheel if I was using an 05 trans. I'm looking at the 06 now. I have a buttload of torque and don't like cruising at high rpms on the highway so I prefer the 3.70 gears.
Is it possilbe to convert a push type trans to a pull type? That may seem like a stupid question so before I get flamed..I'm not stupid; I've just never actually had a transmission with a hydrauilic clutch mechanism in my pressence. I'm going to guess the pivot location for the clutch fork is in different locations for a pull vs push but I don't know.
I'm curious about the clamping force of the older wrx clutches since it seems like the clamping force was increased significatly with the change over to the push type clutch. OEM clutches are just so nice if they can hold the torque you are producing. I'm trying to find out if or maybe trying to convince myself the 06 wrx clutch will work for me.
Old 09-05-2006, 04:59 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I believe you can, but I'm not a pro on this. If I recall rightly, you have to swap out the pedal box or something like that do swap clutch types. If no one replies, www.gearboxtech.com will know.
Old 09-05-2006, 02:10 PM   #8
ECUtuneOne
Member#: 77436
1994 SVX
Ebony pearl
ya, it sounds like a no on the switching to a pull type on an 06 trans.
It seems agreed that the clamping force of the 06 pressure plate is a good deal more than on the 05 but I still haven't been able to find a # for the stock 05 pressure plate yet. I'm going to call clutch manufacturers and see if I can get a consensus...they should know if the % increases they are giving is correct anyway.
If anyone else knows please do share
Old 09-06-2006, 05:18 PM   #9
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
What I do know is that my clutch seems to be able to hold 400 ft/lbs with ease so far. (06 wrx)
Paintballguy is offline   Reply With Quote
Old 09-06-2006, 07:34 PM   #10
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
not sure...but ive heard from many that the 5pd clutch/flywheel will fit the 6sp with a little grinding..sorry it that was mentioned above, i only skimmed through it.
BuggeyEYED is offline   Reply With Quote
6spd sti clutch/flywheel in 5spd wrx tranny? Benjamin Tang Transmission (AT/MT) & Driveline 71 07-19-2015 10:40 PM
FS: ACT Sti 6 spd clutch - used edkwon SCIC Private Classifieds 0 10-17-2009 03:06 PM
1 STi 6 spd Tranny in Stock! JDM 5th/6th Close Ratio Conversion! Clutches! Gruppe-S Drivetrain 6 10-18-2005 05:58 PM
2004 WRX auto trans. vs. STi 6 spd.???? 04jaxwrex General Community 31 03-15-2005 10:27 AM
Recommendation on STi 6 spd trans/front diff fluid h2o Transmission (AT/MT) & Driveline 12 10-14-2004 06:32 PM
