Old 09-03-2006, 10:28 PM   #1
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Default Front O2 Sensor Closed Loop Operation Only?
Hey all...got my car back from Protune the other day, was cruising around at 65 with cruise control on, got a CEL...1131 which is O2 sensor short circuit. Got home, reset the ECU to clear the code, made sure the O2 sensor was firmly plugged in and have not been able to replicate it since with a good 20 miles of driving.
I searched around but couldn't find a good answer as to whether the front O2 sensor is only used in closed loop operation ie cruise control and if so could this be why I haven't been able to replicate the problem or if it is used in OL and CL is it more likely that I just have a loose connection? Thanks
JonR is offline   Reply With Quote
Old 09-03-2006, 10:46 PM   #2
hondaeater69
Member#: 60324
yes the front 02 is mainly for closed loop fueling (not used during open loop fueling). during OL fueling the ECU uses a fuel look up table with preset AFR's per load/RPM.
Old 09-04-2006, 08:31 PM   #3
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Thanks that explains the problem...so the sensor is bad, but it just doesn't show up unless I'm in closed loop.
Old 09-05-2006, 12:07 AM   #4
TMessick
Member#: 882
2004 WRX Wagon
very blue
Well, the upstream(front) O2 is used for closed loop operation, but you should be able to get closed loop under "normal" driving as well as in cruise control. Depending on how it was tuned, you may end up going open loop very quickly though, which would potentially keep this diagnostic from running much during normal driving (and would probably make your fuel economy get evil). Poking around, P1131 looks like an "O2 sensor stuck lean" fault, which would be a rationality-type fault and not a "shorted low" fault (I think P0131 would be the sensor shorted low). Could still be wiring, but I wouldn't think so (I could be totally wrong though). I'm sure those with more Scooby experience will correct me...
If you want to have a look, just idle the car for a while -- you should definitely be running closed-loop at idle....
TMessick is offline   Reply With Quote
Old 09-05-2006, 08:40 PM   #5
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Idled for 15 minutes and no CEL...that's why I was wondering what the problem could be. I'll probably replace the sensor anyway just to be sure.
Front O2 sensor vs Rear O2 sensor (MY00 RS) Jewbaru Service & Maintenance 3 07-29-2012 10:14 PM
Hesitation in 1st gear only -- after new front O2 sensor install? bpwatts UTEC 2 08-03-2007 01:15 AM
is the FRONT O2 sensor a wideband sensor ? Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 07-01-2004 04:21 PM
Front O2 sensor and/or EGT sensor (02 WRX) crazyhorse Private 'Wanted' Classifieds 1 11-03-2003 08:35 PM
Running with closed-loop operation at WOT? 8Complex Technical Forum Archive 2 07-11-2000 05:34 PM
