Old 09-04-2006, 01:06 AM   #1
willguidry
Member#: 16388
Default strange issue..freaking me out need help asap.
Ok.
So I was on the highway yesterday and ever about a 100 mph give or take drive to my friends house:
When I got back to the house, I noticed the car making a metal on metal vibrating noise. Thought nothing of it.
Driving home, I noticed it every time I first got on the gas after a shift, or when taking the throttle off the engine.
Driving at a normal speed, or speeding up did not make any sound at all. Only when I took off the gas or reapplied it.
At idle it is making a metal on metal knock sound also.
Any ideas? Kinda freaking me out.
Back story, 2005 WRX I DO NOT beat on this car. It has 24k miles on it, timely
Mobile 1 synthetic oil changes, and my daily driver. Just gave alittle gas tonight.
Now, I DID fill up at a somewhat "questionable" gas station today only cause it was WICKED cheap. 93 octane BTW.
Is this bad gas related knock? The turbo is just fine, but the note from the exhaust is FAR from smooth.
Good it just be bad gas?
Or something vibrating in the chasis area? Or is this is a bigger concern that I need to worry about?
Cheers
willguidry is offline   Reply With Quote
Old 09-04-2006, 01:21 AM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
sounds like u have a heat shield or something rattling
rjrutzky is offline   Reply With Quote
Old 09-04-2006, 01:26 AM   #3
hocman99
Member#: 110434
2004 04 wrx psm
nyeaa & cuhhh
+ 1 heat shield
hocman99 is offline   Reply With Quote
Old 09-04-2006, 01:43 AM   #4
'02NBLUE
Member#: 86036
'02 S6 Avant
Ming Blue
Impreza WRX Possibly a flange
I had a similar experience that turned out to be...my up-pipe had come loose of it's lower flange (took forever to figure out, I kept thinking something was wrong with my turbo, cause that was the general direction of the sound, even though there weren't any performance issues) had to remove the up-pipe, and weld it back together. Something to check at least.
John
'02NBLUE is offline   Reply With Quote
Old 09-04-2006, 01:44 AM   #5
whateverwrx
Member#: 99653
05 WRX
i bet the catback hanger walked inwards causing the pipe to rub on the rear diff
whateverwrx is offline   Reply With Quote
Old 09-04-2006, 12:50 PM   #6
willguidry
Member#: 16388
uhmmm
Yeah....so the catback DID move in. I moved it out.
Started up the car, and this horrendous knocking is coming from IN the engine bay. It isn't the heat shield, I held it down, as well as put my hands on everything IN the engine bay.
Nothing stopped rattling. It sounds like it is IN the engine.
Any more thoughts please? Oh, and it's LOUD.
Old 09-04-2006, 12:54 PM   #7
sheikthin
Member#: 77592
* missdawn = MILF
now with 25% less pistons
does it sound like its coming from the center of the engine? possibly rod bearing. i spun a rod bearing at 24k miles. get ready to drop some cash if it is.
sheikthin is offline   Reply With Quote
Old 09-04-2006, 01:02 PM   #8
willguidry
Member#: 16388
Well...
I guess the good news is it's leased.
I'm not paying a damn thing to get it fixed. Though, honestly, IMO....this shouldn't happen.
I would expect it to happen to a Dodge Neon or something....
Am kinda turned off by subarus at the moment.
I've done nothing but babied this car, it's a daily driver I drive on the highway about...30 mins each day. Piss poor if you ask me.
Old 09-04-2006, 01:53 PM   #9
willguidry
Member#: 16388
http://www.youtube.com/watch?v=g05xbyGQRLM
Here is a video with sound. It is coming from underneath the intercooler area.
If that helps any. I did an "ECU" reset, and the knock is quiter now.
Good it be bad gas? I just filled up my tank last night to full, again as I said, from a less reputable dealer than normal. Both because of it's price, and the fact that I was on E with no other choices around.
Thoughts?
Old 09-04-2006, 02:01 PM   #10
520hpsti
Member#: 108965
2005 Subaru WRX STi
check your oil
520hpsti is offline   Reply With Quote
Old 09-04-2006, 02:13 PM   #11
page02wrx
Member#: 124053
Back to BONE STOCK
bad gas sometimes makes your valves tick, but if its loud I doubt its that.... try putting something else in it..... i know for a fact my friends mustang would tick (relatively loud too) if he ever ran 87
page02wrx is offline   Reply With Quote
Old 09-04-2006, 02:14 PM   #12
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
Rod's a knockin! Time for a swap. That happened to me when I had the similar sound that came from "inside" the motor as you say. But then, you say its leased.
Nick
MarylandEcstasy is offline   Reply With Quote
Old 09-04-2006, 02:17 PM   #13
CynicX
Member#: 48199
06 WRX
Before you deam it a blow motor do you think you could have cause an exhaust leak moving the exhaust around?
From the video to me it sounds like an exhaust leak or valve tapping. Usually if your low on oil they will all tap but check it anyway even though you probably already have...
What are all your mods? You say you have TBE, up and no EM or did you not mention it? Obviously if you dont have EM on an 05 with TBE you dont really need to beat on it to blow it. Not usually to big of an issue but running it too 100+ you could really lean it out between the 4-5 shift...
Keep us updated...
CynicX is offline   Reply With Quote
Old 09-04-2006, 02:38 PM   #14
willguidry
Member#: 16388
Yeah...checked oil first. No leaks, full oil.
Old 09-04-2006, 03:32 PM   #15
willguidry
Member#: 16388
Old 09-04-2006, 04:19 PM   #16
Rally Time
Member#: 109660
2004 WRX
WR Blue
+1 pull your heat shield and look at the inside I bet you see a spray of dark where the DP to turbo gasket has a leak. Maby
Rally Time is offline   Reply With Quote
Old 09-04-2006, 05:21 PM   #17
willguidry
Member#: 16388
Maby.
Did what you asked, eerything checked ok.
Old 09-04-2006, 05:59 PM   #18
willguidry
Member#: 16388
Which increased with speed and sound the higher the RPM.
I double checked the oil, reads full when car is off.
Opened the oil fill while car was idling, and did NOT notice any smoke, or any other fluctuations in the fill tube.
Felt the uppipe once the heat shield was removed, and felt no obvious movement. Also while car was at idle, felt no exhaust gas.
So the dealership is literally 3 mins from my house. I'm going to limp her in tomorrow, and let them have at her.
Old 09-04-2006, 06:08 PM   #19
Rally Time
Member#: 109660
2004 WRX
WR Blue
I thought that was it. Sorry you are still hearing knock. You will need to replace the gasket. Good luck!!!!
Check the bottom of up-pipe as well (let it cool and start and feel around)
Top of up-pipe is what I ment to say.
Old 09-04-2006, 06:48 PM   #20
nsvwrx
Member#: 122104
wow, it might be that you leand out the engire due to a lack of EM
nsvwrx is offline   Reply With Quote
Old 09-04-2006, 08:57 PM   #21
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
Originally Posted by willguidry View Post
started engine, still LOUD knock.
Alright, so I got to seeing your video clip. That sound is the same exact sound I had when I blew my motor. I had a DP and an UP with no engine management. It wasn't until you said it increased in rpm levels that I have to conclude that it's some kind of internal problem and probably a blown block. Have you checked your dipstick for metal shavings?
Can you make a video clip of the sound increasing the higher the RPM?
Nick
Old 09-04-2006, 09:08 PM   #22
willguidry
Member#: 16388
The oil is perfect.
Nothing in it, I just don't get it.
It must be internal.
We'll find out tomorrow I'm sure.
Old 09-04-2006, 09:15 PM   #23
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
Yeah.. a DP missing a bolt wouldn't make a consistent noise like that, if any.
Old 09-04-2006, 09:41 PM   #24
willguidry
Member#: 16388
Old 09-13-2006, 10:59 AM   #25
willguidry
Member#: 16388
Dealership had to have a new short block shipped in.
Should be getting the car back today.
Any tips on "break in"??
Meaning, how should I drive it etc?
Strange Situation, NEED HELP ASAP sartre311 AccessPort 1 08-27-2009 04:00 PM
Strange Situation, NEED HELP ASAP sartre311 South West Impreza Club Forum -- SWIC 24 08-22-2009 05:51 PM
Strange Situation, NEED HELP ASAP sartre311 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-19-2009 08:47 AM
Strange thing happened over the weekend that freaked me out Bottom Feeder Off-Topic 29 06-21-2007 12:08 PM
UTEC tuning issues need help asap Sharky NRK Engine Management & Tuning 6 11-11-2005 05:23 PM
