Old 10-30-2001, 03:32 AM   #1
shogunate83
Member#: 6006
Default whats that ringing noise?
I just bought a wrx and i have all most 300 miles on it. I am driving and i would notice this ringing noise... it comes and goes.. it would ring for a while then would stop and start ringing again later.. i think its coming from outside the driverside
anyone have this problem or might know what it is?
thx
shogunate83 is offline   Reply With Quote
Old 10-30-2001, 08:09 AM   #2
vickerto
Member#: 10673
Sedona Red
Did you leave your cell phone on the roof by accident?
Never noticed a ringing noise, but I'll keep my ears open.
vickerto is offline   Reply With Quote
Old 10-30-2001, 07:50 PM   #3
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Dunno what you mean by ringing exactly.
However if what you hear is a faint siren or whistling noise at 2500-3000 rpm it's your turbo spooling up/down.
Xio is offline   Reply With Quote
Old 10-30-2001, 09:21 PM   #4
T-WRX-02
Member#: 8907
2002 Impreza WRX Sdn
WR Blue Pearl
Try putting your cell phone on vibrate! Sorry, couldn't resist that lead in!
Does the sound change when the window is opened / closed? Is it coming from under the hood (injectors) or from the exhaust area of the car? Thats a tough one to diagnose without more info. What engine RPM, gear, under acceleration, coast or decel?
My WRX makes so many odd sounds ... To fix them, I use the audio mechanic ... I just turn up the radio 'til they go away ... fixed!
T-WRX-02 is offline   Reply With Quote
Old 10-30-2001, 09:45 PM   #5
Luca
Member#: 10725
Black Pearl
I don't get a ringing noise, but from my passenger side when I'm just cruisin down the highway at about 3000rpm I start to hear like a crackle noise. it sounds like rock pebbles, but its not.
I have no idea what it is.
Luca is offline   Reply With Quote
Old 10-31-2001, 01:35 AM   #6
shogunate83
Member#: 6006
Well .. the ringing sounds like scrreching.... I can hardly hear it with the windows up but when there down i hear it pretty good... when i'm adding gas i hear it when i release gas i hear it when i am in neutral and cruising down i can hear it... i dont go over 4krpm.. its not coming from the exhause... i can hear the WOT but i dont think this sound is coming from the turbo...
it seems to be more towards the driverside wheel... could this be wheel bearings or something?
Old 10-31-2001, 08:36 PM   #7
T-WRX-02
Member#: 8907
WR Blue Pearl
First, check under the hood for a partially shredded cat. Cats have an affinity for turbo'd cars during the fall and early winter seasons. If not promptly removed, they may also produce a smell akin to a toasted clutch.
If it is a screeching sound that gets louder with engine RPM, it may be a slipping accessory belt. Check the belt tension and look for shiny spots on the belt or discoloration areas on the pulleys.
If it a squeeling sound, it could be a bearing or joint in your front suspension.
It it was actually a cat and the problem persists, a loud Turboxs or equivalent BOV could rid your car of feline passengers.
If the sound is actually from the trunk area, you may have accidently given your trunk monkey some skunky beer!
[Disclaimer: Trunk Monkey is copyrighted, so sorry!)
Old 11-01-2001, 08:49 AM   #8
GGB
Member#: 8792
Default intake pipe loosen?
Also try to check the hose cramp on the intake pipe, and air filter element to make sure there is a good seal.
GGB is offline   Reply With Quote
What IS that damned noise!?! Spheris Off-Topic 14 12-14-2006 02:59 AM
Whats that noise from koni insert... galacticWRX Brakes, Steering & Suspension 2 03-01-2006 02:58 PM
Whats that Noise? chaco-sit Transmission (AT/MT) & Driveline 2 10-18-2005 12:50 PM
Whats that noise? Its a funny booming noise SubeDonC Tri-State Area Forum 3 03-09-2003 12:28 AM
whats that noise? turbo mofo Newbies & FAQs 4 12-23-2002 02:03 AM
