Welcome to the North American Subaru Impreza Owners Club Wednesday September 17, 2014
Vancouver Impreza Club
Old 09-04-2006, 09:09 PM   #1
Wylde Horses
Member#: 61255
dirty silver
Default Suprisingly, I'm not that frustrated...
After some plans I had for today fell through, I decided to work a little on my mustang (replace an O2 sensor) and then give some attention to the WRX. I decided it was time to replace the sparkplugs, finally install the K&N intake I had sitting in my room for a couple months, and then run down to Canadian Liar for some oil & a filter to do an oil change. So I pull out whats left of the stock intake (I had removed the baffle in the fenderwell some time ago) and get to work on the passenger side sparkplugs.
I felt pretty good with my progress after those two (little did I know they were by far the easiest of the four) and started to work with the K&N Typhoon intake. I had assembled everything pretty much the night I bought it, so I figured it should be just a simple matter of popping it in and moving on. Wrong! The heatshield was not fitting around the powersteering pump (I think? the thing that sits right between the bottom half of the stock air filter box and the headlight). There was no way it would fit in there. After playing with it for ~20 minutes, I went and grabbed the instructions, and right away something jumped out at me that I hadn't noticed before - this intake was for the Legacy GT. I figured to myself, maybe it's just the heatshield that's the problem, so I removed it and tried with just the pipe and filter, and it was still coming in contact with the powersteering pump.
So I gave up, threw in the stock airbox again, and moved on to the driver-side sparkplugs. Even after I had removed the windshield washer tank and battery, the spaces were still so tight it made it really ackward to get at the coils and at the sparkplugs. I will hand it to Subaru though, they have done what they can to make the job easier - it took ~15 minutes of struggling with the rear driverside coil to figure out why they are threaded. Once I clued in and screwed the bolt part way in, it came out much easier.
So now, after spending probably an hour longer then I estimated messing with the car, I've only finished 1 out of the 3 things I originally intended to do. I have to step out shortly so the oil change will have to wait. Surprisingly though, I'm not very frustrated, just a little upset at getting the wrong intake. Speaking of which, have a look at my new add in the classifieds! ===> clicky.
Wylde Horses is offline   Reply With Quote
Old 09-04-2006, 09:13 PM   #2
GlobalWaste
Member#: 74792
Oh well, **** happens... at least the oil change is a snap..
GlobalWaste is offline   Reply With Quote
Old 09-04-2006, 09:14 PM   #3
Dalton
Member#: 90245
2004 STi
Patience ftw!
Dalton is offline   Reply With Quote
Old 09-04-2006, 09:15 PM   #4
Wylde Horses
Member#: 61255
dirty silver
^^^ Yeah, that's pretty much what I'm thinking. Meh, on to other things now.
Feels like I'm in valet mode but I'm not on that map rossl UTEC 0 08-10-2009 02:35 PM
So I put a boost gauge in and to my suprise, I'm running only 7psi gpfan Factory 2.0L Turbo Powertrain 41 05-01-2009 03:44 AM
I'm not that bright, or so i thought i wasn't... Brad Pittiful Off-Topic 23 07-07-2005 07:22 AM
How do i let dumb accords know that i'm NOT a wrx? Handsdown Mid Atlantic Impreza Club -- MAIC 19 07-10-2003 02:42 AM
Haha, I'm not that stupid! ryball Bay Area Impreza Club Forum -- BAIC 3 05-14-2002 09:52 AM
