Old 09-04-2006, 10:55 PM   #1
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
Default Who is using Legacy GT intake manifold on their STi?
Saw it posted on a car with a FMIC.
Looks like a good idea to keep temps down since it is plastic. And you can rotate the intake manifold without removing AC compressor.
My question is DOES it work.
Do you think it can be made to work with a Spearco TMIC runnign a custome samco hose to it???
Would like some info from people who have done it...
Tried to search no luck for you flamers
Matt
PA04STI is offline   Reply With Quote
Old 09-05-2006, 12:05 AM   #2
NewSTI
Member#: 104420
05 GarageTuningSTI
BLK/Gold [email protected]
I am using LGT manifold but reversed. Seriously if you want LGT manifold just for reduce the heat(never measure, so dont know if it's really cooler or not).. don't do it ..waste of time and money. The only reason that i am running reverse LGT manifold is cuz the throttle is on the side which allow you to keep your A/C , but yes you'll have to custom IC pipes and for sure you dont want to do that with TMIC, because with TMIC, the piping from TMIC to manifold is actully going be longer than the stock position, which means no point for reverse manifold.
Personally, the whole idea of LGT reverse manifold is for show ..it might help a lil, but i have nothing to compare with..however, with FMIC, compare with STI manifold VS LGT manifold., the piping from IC to manifold is almost the same...which "i think" there's no point change it to LGT.
Moreover, with STI manifold, it does make the piping shorter but then you'll have to lose your AC..
NewSTI is offline   Reply With Quote
Old 09-05-2006, 09:09 AM   #3
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I don't believe you HAVE to lose your AC. But you do have to relocate it.
wcbjr is offline   Reply With Quote
Old 09-05-2006, 08:45 PM   #4
NewSTI
Member#: 104420
05 GarageTuningSTI
probably, but only if you can find a spot for it and make it work , at least b4 i do my reverse manifold , i asked many shops (no luck) and pmed some ppl that are running STI reverse manifold..none of them are running AC with reversed STI manifold just cuz it won't fit.
Old 09-05-2006, 11:21 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Old 09-05-2006, 11:24 PM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Old 09-06-2006, 09:20 AM   #7
happasaiyan
Member#: 37731
thats hot.
if i were ever to do a reverse manifold, that would be my plan of attack. no relocating things and you can put your blow-through maf right in front of the intake...thats nice.
happasaiyan is offline   Reply With Quote
Old 09-10-2006, 03:00 AM   #8
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
Where the hell did you get that FMIC and does the piping on the reverse manifold go over the AC???
Crazy love that setup...How much who makes...I would guess a custom one off job...
Matt
Old 09-10-2006, 03:01 AM   #9
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
Nice saw a pic of a car with it and just wanted to get more info on it especially if there was an advantage other then location for it.
Matt
Old 09-10-2006, 10:29 AM   #10
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Mine (not STi though ):
If you decide to go the LGT manifold route you will also need the LGT TGV housings in order for it to bolt up along with an LGT throttle body as well. The wiring for the Drive By Wire will also need to be extended to reach the new location of the throttle body. And obviously it can only be used with a rotated mount turbo kit.
-Matt
ShaggyGT is offline   Reply With Quote
Socal: vf39, DW topfeed 565s, legacy gt intake manifold etc.. akcel Engine/Power/Exhaust 24 03-26-2010 05:46 PM
FS: (WV) 05 Legacy GT intake manifold w/ throttle body BarryT1982 Engine/Power/Exhaust 0 03-17-2010 04:48 PM
FS: PA Legacy GT Intake manifold (going rotated?) sutter2k Engine/Power/Exhaust 25 12-10-2008 09:52 AM
2004 STi Intake Manifold on 2007 STi i_drank_what Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 12-03-2008 11:08 AM
Anyone is using an Apexi turbo timer in their STi? Does it work with the stock alarm? JDM addict Electrical & Lighting 6 09-17-2003 01:48 PM
