Old 09-04-2006, 10:56 PM   #1
jamesg602
Member#: 120322
06 WRX TR
Steel Gray
Question How do you convert from kg/mm to lb/in?
How do you convert spring rates from metric to in/lb? I tried a conversion calculator but I am not sure what 6K and 8K mean in terms of units. Are they kg/m, kg/cm or N/m?
Thanks
James
jamesg602 is offline   Reply With Quote
Old 09-04-2006, 11:48 PM   #2
jamesg602
Member#: 120322
06 WRX TR
Steel Gray
Question
Anybody?
Old 09-04-2006, 11:51 PM   #3
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
8k means 8 kg/mm
multiply by 56 or so to get lbs/in
use www.onlineconversion.com if you want to be exact.
- andrew
AndyRoo is offline   Reply With Quote
Old 09-04-2006, 11:58 PM   #4
jamesg602
Member#: 120322
06 WRX TR
Steel Gray
Talking Thanks
I was just about to dust of the old physics book!
Old 09-05-2006, 12:16 AM   #5
littledrummerboy
Member#: 94408
2017 STI Sport-Tech
World Rally Blue
google does a good job... for example just type in "8 kg/mm to lbs/in" (without quotes) and you'll get the answer. google will do any conversion and math equations too!
littledrummerboy is offline   Reply With Quote
Old 09-05-2006, 12:29 AM   #6
jamesg602
Member#: 120322
06 WRX TR
Steel Gray
I was searching before I posted, but wasn't sure of the unit meaurments.
Old 09-05-2006, 09:06 AM   #7
leecea
Member#: 37359
2003 WRX
That is so cool I didn't know Google could do that!
leecea is offline   Reply With Quote
Old 09-05-2006, 09:48 AM   #8
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Adding this to the threads of note
Old 09-05-2006, 10:50 AM   #9
InfamousDX
Member#: 25413
Yup... google conversion is the best. Been using it for a while now. What i didn't know was that you can use multiple units, as in kg/mm or lbs/in... that's very cool.
Old 09-05-2006, 01:02 PM   #10
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Here's the math (1kg/mm)*(25.4mm/1in)*(2.2lb/1kg) => 1 kg/mm = 55.88 lb/in
For quick reference:
5k = 279 lb/in
6k = 335 lb/in
7k = 391 lb/in
8k = 447 lb/in
9k = 503 lb/in
10k = 559 lb/in
11k = 615 lb/in
12k = 671 lb/in
13k = 726 lb/in
14k = 782 lb/in (yes, some people actually use springs this stiff)
Scooby921 is offline   Reply With Quote
how do i convert my 4.11 to 4.44 TurboCharged97L Subaru Conversions 4 07-18-2006 02:31 AM
How do you go from US WRX Wagon to JDM WRX Wagon? yuephoria Interior & Exterior Modification 7 12-24-2004 08:33 PM
How do you get from CSUF to Mission Viejo W/O paying tolls awd_dreamin Southern California Impreza Club Forum -- SCIC 14 01-27-2004 06:15 PM
C++ How do you convert from a float to an integer? Corn-Picker Off-Topic 28 10-04-2002 03:56 PM
