Old 09-05-2006, 12:45 AM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Default The official "Will this part fit my car?" thread
If possible, I would like to compile a list of general rules about part compatibility for suspension and brake bits. I didn't see one in the threads of note, and it seems to be a popular question.
The obvious ones are swaybars, strut tops/camber plates, and struts/springs/coilovers. There's other stuff like lateral links, Payam's STi control arm swap, etc etc. I just want to try to get a list of those things all in one thread.
I don't have a lot to add now, hopefully tomorrow.
john
Old 09-05-2006, 12:58 AM   #2
xS2k
Member#: 85112
After you compile a tread..i vote sticky it!!!
xS2k is offline   Reply With Quote
Old 09-05-2006, 03:11 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Wow, thats going to be a tough one... Great idea though.
Let me know if you need any help
Old 09-05-2006, 03:50 PM   #4
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Hmmm...suspension for WRX / STi
Struts:
'02+ WRX and '04 STi struts and coilovers are interchangable. If you want to use older MY struts w/ a newer topmount you need the 'washer mod'.
'05+ STi has a different knuckle, the bolts have moved.
Springs:
Lower perches are all the same, so you can use newer springs on older struts. You will need to buy the appropriate topmounts.
Swaybars:
WRX sedan and wagon RSB's are interchangable. WRX's can use STi RSB's, but they will mount to the outside of the endlinks. WRX and STi FSB's are interchangable. Wagons use different FSB's than sedans and can't swap.
Topmounts:
For all WRX and STi, the top 3-hole pattern is the same. '04+ topmounts can be use on older struts...see 'washer mod'. Older topmounts can be used on newer struts. In both cases you need the appropriate MY springs.
Camber plates:
Any plate designed for an Impreza will fit any other. As stated above, the 3-hole pattern is the same. The piston diameter for the interface is also the same. Camber plates are darn near universal.
I'm doing this all from memory off mods I've done. If I've gotten something backwards, let me know.
Scooby921 is offline   Reply With Quote
Old 09-05-2006, 04:08 PM   #5
Butt Dyno
Member#: 17301
is the "dark side"
Old 09-05-2006, 09:27 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Good luck! I tried to start something similar with I did my suspension FAQ. I just wanted to limit it to:
JDM Ver 7 fits _______
JDM Ver 8 fits _______
etc.
Everyone pretty much laughed at me and called me a n00b with very little help. Good luck to you though!
EDIT http://forums.nasioc.com/forums/show....php?t=1083037 makes a good arguement for fitment/upgrade for OEM components.
Old 09-06-2006, 08:06 AM   #7
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Yeah...I guess having a desired format would be good. Figure that out and let the rest of us know. I'm more than willing to help out and contribute what I can.
Old 09-06-2006, 10:33 AM   #8
BIGSKYWRX
Member#: 7958
09 GH B+
Fill in the blank would be much easier- I think I have a lot of the answers- just not the questions That's Imprezas mind you- start adding Legacy/Forester it gets even more dicey.
There is also a small caveot to "fit", many parts will "fit", but not fit
Old 09-06-2006, 02:11 PM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ya, we need to set up some kind of format for this first so we can help fill it in...
Old 09-06-2006, 02:46 PM   #10
Butt Dyno
Member#: 17301
is the "dark side"
I'm thinking if we identify the platforms first, it should be straightforward from there.
Basically, something like:
93-01 Impreza (all)
02-06 Impreza (non-STi)
04 STi
05-06 STi
Within each of those platforms, come up with the rules, ex:
02-05 Impreza (non-STi)
Struts:
Any 02-05 Impreza non-STi struts/coilover kits (duh)
Newer topmounts can be used with the washer mod (insert URL here)
Swaybars:
Sedan:
-Any 02-05 Impreza non-STi swaybars
-STi swaybars + endlinks
Wagon: Needs wagon specific front swaybar
-All rear swaybars fit
That's my first crack at it... basically much of what Scooby921's post contained, in more of an outline form...?
john
Old 09-14-2006, 10:02 PM   #11
FujiHeavyFreak
Member#: 5405
Will an 03 WRX wagon rear swaybar fit an 06 2.5i wagon?
FujiHeavyFreak is offline   Reply With Quote
Old 09-15-2006, 09:20 AM   #12
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
This is going to get even more complicated that we thought, because there are so many small items that may work across an entire platform, not just model.
ie...N/A Impreza vs. WRX. Both are Imprezas and share some parts like suspension bits, but yet the way it seems we are planning this list things like that may not have been considered.
Either way, just give me the outline / format you'd like to see and I can start filling in what I know.
To answer the question...I believe so. I haven't done the swap myself, but I don't see a reason why it wouldn't.
Old 09-15-2006, 01:03 PM   #13
Butt Dyno
Member#: 17301
is the "dark side"
I took a crack at it a couple posts up. The problem is, like you said, there will be caveats. I figure we will start out with generalizations that might be wrong and refine them as people fill the exceptions in.
john
Old 10-24-2006, 02:14 PM   #14
the_poser
Member#: 106234
'o8 5.7 Tundra
'07 sv650s
what I would like to know, and so far haven't found a straight answer...
will sedan rear struts and tops fit a wagon [w/wagon specific rear springs]?
the_poser is offline   Reply With Quote
Old 10-24-2006, 02:37 PM   #15
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
john
I was wondering where this thread went.
Ok, so I'm going to take your format above and fill in everything I know for suspension stuff.
Old 10-24-2006, 02:39 PM   #16
Butt Dyno
Member#: 17301
is the "dark side"
One other possibility is to merge everyone's "will this fit" thread in here, and then slowly create a list of questions/answers in the first post. *shrug*
Old 10-24-2006, 03:26 PM   #17
Mark Avery
Member#: 10313
2002 WRX wagon
Yes, but I think they are the same size, 17mm, so what's the point?
Mark Avery is offline   Reply With Quote
Old 06-26-2007, 12:11 PM   #18
RobK0000
Member#: 62230
I have a 00 impreza L, will 04 sti sway bar front and rear fit my car.
RobK0000 is offline   Reply With Quote
Old 06-26-2007, 12:16 PM   #19
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
I remember this thread....
No, the STi swaybars will not fit your car.
- Andrew
RaceComp Engineering is offline   Reply With Quote
Old 07-12-2007, 01:20 AM   #20
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Old 07-12-2007, 06:41 AM   #21
Butt Dyno
Member#: 17301
is the "dark side"
Excellent work! Thanks! I will add it to the threads of note.
john
The "Will this suspension part fit my car?" thread. RaceComp Engineering Brakes, Steering & Suspension 741 04-24-2016 09:31 PM
The OFFICIAL MAIC "Where to get your car tuned" thread. Butt Dyno Mid Atlantic Impreza Club -- MAIC 113 07-14-2012 08:44 PM
The Official "What are you having for lunch?" thread Jeff54 Vancouver Impreza Club Forum -- VIC 41 12-16-2009 07:57 PM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
