Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 09-05-2006, 04:25 PM   #1
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
Default CoolingMist Water Injection Group Buy!!! Insane Specials!!!
Back by popular demand, the craziest water injection group buy ever made!!!
THESE PRICES WILL NEVER BE DUPLICATED EVER AGAIN!!!!
All information can be read at www.coolingmist.com
Pricing is as follows-
Standard Kits (Deluxe Kit + tank) $249.95 (Black Pump) Shipped! TONS in stock!
Varicool Standard Controller Kit (stage II) $432 shipped!
Varicool Stage II + Clog nozzel detector is $457 shipped!
4 kits in stock, once the first 4 are gone, the rest ship 1st week of october!
Varicool Stage II trunk mount (NYLON) and Clog Nozzle Detector $539 shipped!!!!!! Retail $650 + shipping
Stainless upgrade is $115 for any kit. If clog nozzle detector is added to
any kit Stainless upgrade will be $128 for that kit because of the upgraded fittings
The new Trunk mount commander kit (nylon hose) $750 shipped. Add Stainless hose $850. We need to presell 4 to get this price!!! so they won't ship until atleast 3 are sold (we'll pick up the other one if need be)
Upgrade to a 1 gallon tank for $20
add a low level indicator for $20
Payment information-
239 540 6385 visa/mastercard
paypal confirmed to [email protected]
Import Image Racing
431 sw 34th terrace
Cape Coral, FL 33914
1. Mr. Lok in tx (1 deluxe kit)
2. Mr. Corry in CO (1 Deluxe kit)
3.
4.
5.
6.
7.
8.
9.
10.
IMPORTIMAGE is offline
Old 09-05-2006, 04:26 PM   #2
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Stage 2 information-
Our controller is the most advanced digital progressive controller on the market. You have the ability to make the methanol/water spray as aggressive or as mild as you want. We have some key features at the bottom of this page. If you are going to buy a progressive controller, dont you want one that actually controls the pump? With ours you have complete control over every aspect of the pump for complete and accurate tuning. Other progressive controllers can say they will get you very close, we can say that ours can get you exact.
# Nozzle Types: Single Nozzle. Use this for MOST applications. NOTE: your kit will ship with our large and Medium nozzle, but you can only use 1 at a time. If you order the dual nozzle you will get 2 nozzles + injector holders + other necessary fittings. If you have dual carbs or dual throttlebodies you will need our dual nozzle system. If you have a 4 cylinder and want a nozzle for each port choose Multiport.
# Tank: Our kits ship standard with a 2 quart tank (1/2 gallon). If you want a 1 gallon tank choose that from the drop down box. The Trunk mount tank is a custom made tank that has the pump in a recessed cavity. This makes it simple, you just strap the tank down and its done. It will prime 100% of the time. The capacity is 1.5 gallons, yet is only 8 inches high by 6 inches by 11 inches. The wall is 3/16 inch thick. Here is a pic
# Clog Nozzle Detector/Status Flow Detector. This is a device that will detect the water flow, it indicates if you have a clog and if the methanol/water is flowing. This is strongly recommended as you will always know if the system is operating correctly.
# Hose Type. Choose nylon or stainless. If you order stainless, you will get 15 feet (call in if you need more than 15 feet). You will need to cut the hose with a dremel to fit. you get re-usable stainless/brass high end fittings. Nylon (the most popular) will ship with 15 feet, has all brass quick disconnect fittings (our quick disconnects are not the cheaper brass/nylon composit).
Our fittings are un-matched by any methanol/water injection company. Made 100% of metal, with NO plastic clips or nylon molding like our competitors carry.
features:
# Serial interface (ability for you to custom tune if you wish, but NOT required)
# Simple to use, ready to use out of the box (no computer necessary)
# Ability to run using your vacuum/boost line, 0-5V (maf/tps) or BOTH at same time (2d mode)
# 1-30 psi adjustment for start boost, 1-30 for full boost. You can run 60 psi boost pressure with this
# 10 position tuning factor will change the duty cycle of the pump. This allows you to add more flow or reduce flow on demand.
# Green Light to show current condition.
# Fully programmable
# Many advanced features including ability to change min pump pressure, max pump pressure, use custom maps, datalogging, etc.
# Upcomming coolingmist commander can be attached to this unit to program the unit and display values.
# Laptop/desktop software is included
Commander kit info-
introducing the Vari-Cool Commander Kit. Our commander allows you to program our controller and view all of the important functions such as boost, air intake temps, optional EGT (contact us if you wish to do EGT), duty cycle of pump, etc. With this kit you can run the system off boost, air-intake temp or in 2D mode with boost and intake temps. If you choose intake as primary and boost as secondary,the system will inject on a variable flow from the min temp to the max temp, but only when above what ever boost level you choose by the commander. In that mode the knobs on the controller will relate to intake temps. The screen on the commander will reflect in real time the min/max temperature that the knobs on the controller are set at. By putting boost as primary and intake as secondary, the knobs on the controller will relate to boost and the flow will vary based on boost, but only when above the temperature you choose from the commander. You can also choose to just run the sytem based on boost only. Even if you chooset only run based on boost, you can still view your intake temps. This kit is in stock .
This contains our standard black 150 psi methanol/water injection pump, our TRUNK MOUNT 1.5 Gallon tank, stainless hose and fittings (15 feet), nozzle that install from the outside of the pipe and of course our amazing controller and Commander.
# This kit is the identical kit as our stage II varicool kit but adds the following: Pocket PC (HP rx1955 or equivelant)
# Intake Temp Sender
# Charger for the House
# Sync Cable for use with your PC
# Serial Cable to connect the controller
# Sync Software
# Pocket EXCEL and WORD
# Pocket Internet Explorer
# Coolingmist VARI-COOL Software
The DELUXE 150 psi Methanol/Water Injection kit. It comes with everything you need. This comes with our 150 psi pump, 2.0 quart water tank , water tank taping kit and all the wiring, injectors and other things you need. This also ships with our outstanding brass checkvalve. This is a great deal. The boost switch is adjustable from 1-25 psi. Its a great kit at a great price. choose single nozzle or dual nozzle setup from the drop down box. If you have more than 500 HP or if you have twin carbs/throttlebodies we recommend the dual nozzle setup.
Old 09-05-2006, 07:44 PM   #3
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
to the top!!
Old 09-06-2006, 10:34 AM   #4
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
weds morning bump!
www.importimageonline.com
Old 09-06-2006, 02:21 PM   #5
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
lunch bump!
Old 09-06-2006, 04:48 PM   #6
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
afternoon bump!
Old 09-06-2006, 08:50 PM   #7
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
another deluxe kit sold thats 2 down
Old 09-07-2006, 09:31 AM   #8
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Thursday morning bump!
Old 09-07-2006, 12:05 PM   #9
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
lunch bump!
Old 09-07-2006, 03:28 PM   #10
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
to the top!
Old 09-07-2006, 03:52 PM   #11
Thran
Member Sales Rating: (57)
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
how big are the nozzel that is a medium and a large? because i purchased the kit in ur last group buy and i think i might need to get a bigger nozzel so im just wondering how big are they now
Thran is offline
Old 09-07-2006, 03:53 PM   #12
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
i dont sell just the nozzel, you'll have to contact coolingmist for a new nozzel
Old 09-07-2006, 09:30 PM   #13
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
to the top!
Old 09-08-2006, 10:00 AM   #14
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
friday morning bump!
Old 09-08-2006, 12:55 PM   #15
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
lunch bump!
Old 09-08-2006, 06:29 PM   #16
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
afternoon bump!
Old 09-09-2006, 10:18 AM   #17
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Saturday morning bump!
Old 09-09-2006, 04:08 PM   #18
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
afternoon bump
Old 09-09-2006, 06:16 PM   #19
larry d
Member#: 67951
what is the cost for a complete, everting kit?
larry d is offline
Old 09-09-2006, 06:34 PM   #20
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
which stage? varicool stage 2 is complete
Old 09-09-2006, 10:20 PM   #21
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
evening bump!
Old 09-10-2006, 11:52 AM   #22
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
sunday morning bump!
Old 09-11-2006, 10:58 AM   #23
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Monday morning bump!
Old 09-11-2006, 03:13 PM   #24
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
afternoon bump!
Old 09-12-2006, 09:53 AM   #25
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Tuesday morning bump!
Closed Thread
CoolingMist Varicool stage 2 + Varicool Trunkmount Group buy! Insane prices!! IMPORTIMAGE Vendor 'Group Buy' Classifieds 55 08-01-2007 02:12 PM
73.99 Fuel Pumps shipped, Coolingmist Water Injection specials, Turboxs, SBR, Perrin! IMPORTIMAGE Engine/Power/Exhaust 220 08-05-2006 01:12 PM
CoolingMist Water Injection Group Buy!!! Insane Specials!!! IMPORTIMAGE Vendor 'Group Buy' Classifieds 77 04-26-2006 01:48 PM
Snow Performance Water Injection Group Buy ! F1DYNO Vendor 'Group Buy' Classifieds 8 11-08-2005 05:24 PM
Water injection group buy $300 Shipped! WRXTuner Vendor 'Group Buy' Classifieds 23 01-29-2004 12:07 PM
