Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 09-05-2006, 06:54 PM   #1
Member#: 82153
2016 WRX
Default Easy Question--where to T off Boost for VariCool Controller (coolingmist)
I know I have to T off a boost line to connect it to the nipple on the controller. Can I use the bypass valve line? Also whats the size of Vacuum hose so I can extend it to the controller. Thanks in advance
Rwu00313 is offline   Reply With Quote
Old 09-05-2006, 09:59 PM   #2
Member#: 121945
Tee it into the boost gauge line or the line that goes to your map sensor. The polished stainless steel port on the controller is 1/4 - 3/16. You can use 1/4, 1/8 or 3/16 hose to connect to it as it has a reducing barb. Even the nylon hose that comes with the kit will fit NICELY over the barb. Most likely your hose in your car is 1/4. If so you can connect directly to the controller.
Eitherway, its a piece of cake. Thanks for your purchase.
CMTech is offline   Reply With Quote
**EASY Noob question, where to tap in for a bost gauge**PICS INSIDE** NEED HELP skingfreak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-15-2008 10:25 PM
Where to tap off for oil pressure gauge Tattoo Collector Normally Aspirated Powertrain 2 12-08-2005 11:20 AM
SMC or other ALKY Injection users - where did you tap boost for controller? STI_FFY Engine Management & Tuning 17 09-22-2005 01:08 PM
Where to mount Blitz boost controller in WRX Errance Electrical & Lighting 1 03-12-2005 05:09 PM
Header question - where to add bung for EGT? saint_foo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-03-2004 12:28 PM
