Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 09-05-2006, 07:47 PM   #1
Shootist
Member#: 117539
2006 B9 Tribeca Ltd
Titanium Silver Metallic
Default low tire pressure light wont go off
Its been on for a couple of weeks now. I just checked the tires, and they aren't low. I read in the manual that you have to go 20mph for the sensor to start working and reset. I drove around and the light is still on. What is the deal? How do I reset it?
Shootist is offline   Reply With Quote
Old 09-05-2006, 09:44 PM   #2
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Could be one of two things.
1) Your pressure gage you checked them with is off.
2) The sensors need to be reset to recognize the correct ppressure by the dealer. IIRC there is a way to adjust them if you have navagation. I'd check your owners manuals.
Keith99RS is offline   Reply With Quote
Old 09-07-2006, 01:57 PM   #3
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Did you check tire pressure while tire is cold or hot? There are about 4 PSI difference! I recently just did that due to the sudden temp change. I found that you need to drive for little while for it to turn off.
Foxbat is offline   Reply With Quote
Old 09-07-2006, 04:03 PM   #4
erik99
Member#: 59930
2006 B9 Tribeca Ltd
Seacrest Green
Had my light go off last week. All tires were at 27psi cold! Pumped them back to spec on the door sticker and everything was fine after that.
erik99 is offline   Reply With Quote
Old 09-10-2006, 06:12 PM   #5
Shootist
Member#: 117539
2006 B9 Tribeca Ltd
I finally broke down and made an appointment with the dealer. Of course the light went off on the way home today. Now I'll take it in and they wont be able to find anything.
New BBS rims and Pressure gauge wont go off?? 08SubieWRX General Community 26 05-29-2008 02:33 PM
Rear Lights And Number Plate Lights Wont Go Off ?! terrenceseet Electrical & Lighting 1 02-18-2006 08:26 PM
Ahh help! Lights wont go off! Dakken General Community 9 10-21-2002 12:53 PM
Reverse light wont go off Burnout Interior & Exterior Modification 4 09-21-2002 11:16 PM
Parking/tail lights wont go off Reflex-Arc Technical Forum Archive 17 07-07-2000 12:21 AM
