Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 09-05-2006, 11:35 PM   #1
tmarcel
Member Sales Rating: (10)
Member#: 7555
Default NC: 2002 2.5, DOHC Forester Long Block (LOW MILES)
I've got a low mile Forester motor for sale. My friend found this motor for me as a temporary replacement for my current motor but I decided that I'm going to rebuild the one that I've go immediately. So, this low 40K mile motor is ready to go.
The cylinder walls look great. The outide is pretty clean. New front and rear block seals. New updated DOHC head gaskets (not the leaky ones). New cams seals (all four). The oil pan has been pulled, cleaned, and inspected.
Here's the best part. The heads have about 10 hours of porting to them. The cam journals look perfect as well. The heads will be arriving back from the head shop tomorrow and will get bolted back on. The valves were re-seated as well. I haven't had the heads flow tested but I'm sure they willl help greatly. The porting primarily removed casting flash and smoothed the walls and sharp lips in the port bowls under the valve seats
The motor is from a 2002 model. Comes with oil pump, complete cylinder heads, oil pan and pickup. A long block is what it is. I should have pics of the heads when I get them back from the machine shop tomorrow.
Shipping "should" be about $130 +/- as a shortblock is normally about $100.
Selling price is $700 plus shipping.
tmarcel is offline   Reply With Quote
Old 09-06-2006, 10:53 AM   #2
tmarcel
Member#: 7555
TTT for those that don't know
Old 09-13-2006, 09:05 PM   #3
tmarcel
Member#: 7555
Sold! To me. I'm decided to build an engine out of the block and crank. Thanks for looking.
Old 09-13-2006, 10:12 PM   #4
Storm
Member Sales Rating: (6)
Member#: 5218
96L Most Over-
Developed Beater
The block pictured is not (originally) from a 2002 Forester. The pistons are reverse dished and the oil seperator plate is plastic, aka phaseI.... Someone mighta misinformed your friend or flat out lied. I would change that rear plate to the aluminum one and do something to upgrade the pistons and get back to 10:1 compression.
Jay
Old 09-14-2006, 08:14 AM   #5
tmarcel
Member#: 7555
Jay
Yeah I found that out recently. Apparently there wasn't a NA EJ25 DOHC for the USDM for '02. Not a problem though it was just a miscommunication from one person to the next. The mileage part was correct though You can see this thread and scroll all the way down to the bottom. http://forums.nasioc.com/forums/show....php?t=1076296
2.5 SOHC Engine Long Block, with only 72k miles danverco Engine/Power/Exhaust 3 10-03-2011 08:13 PM
2.5 L Subaru Long block platinum arrow Engine/Power/Exhaust 4 10-18-2009 09:22 PM
CA: (feeler) WTB 2.5 turbo short/long block kbeezy02 Private 'Wanted' Classifieds 3 07-21-2009 06:27 PM
2.5 DOHC Forester Heads on EJ257? tmarcel Built Motor Discussion 5 08-14-2006 06:36 PM
WTB 2.5 DOHC engine or block spdracr00 Legacy Forum 11 01-13-2006 04:24 PM
Message Board Statistics All times are GMT -4. The time now is 08:10 AM.
