Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-30-2001, 04:19 PM   #1
Chubler
Member#: 10521
02 WRX
WRBlue
Question HELP!!! PICS of BPM GT Installed
I just had my bpm gt exaust installed
After 200 miles the CEL went on, the dealer pulled code420 which is catalyst efficency-meaning the cat isn't getting hot enough.
I got it cleared and we checked all fittings
I got a CEL right after I left the dealer for the second time.
I was looking for pics of what the twin dump looks like installed.
Pics of all angles if possible.
Anyone have any suggestions
Chubler is offline   Reply With Quote
Old 10-30-2001, 04:28 PM   #2
SuperFreq
Member#: 3909
2002 Impreza WRX
Platnum Silver Metallic
Make sure your O2 sensor is inserted in the bung AFTER the cat in the midpipe. There are bungs on the downpipe and after the cat in the midpipe. You will get CEL low cat efficiecy code if you have it before the cat. Normally the O2 sensor senses a difference between the sensor before the turbo and after the cat in the downpipe. If you move the O2 sensor after the midpipe cat you will get a resonable difference in the readings and get no CEL. You will need to unhook the wire from it's twisties on the transmission housing and pull out the slack to make it reach. like this:
back of car is this way --->
I don't think that it is your downpipe unless you can see any gaps in the fittings.
SuperFreq is offline   Reply With Quote
Old 10-30-2001, 04:49 PM   #3
Chubler
Member#: 10521
02 WRX
WRBlue
Any one with pics of the front of the downpipe/right after the turbo leading to the mid pipe?
Old 10-30-2001, 04:54 PM   #4
FuZZyLoGiC
Member#: 5970
2004 \/\/|2>< STi
Bp]V[ 97 |_||\|1<|-|1p2.0
Question just a ?
Hey, must be nice to have a GT on you WRX. I've been waiting on mine forever So how do you like to sound? What about the preformance? Any Problems with the fit?
tnx!
FuZZyLoGiC is offline   Reply With Quote
Old 10-30-2001, 04:54 PM   #5
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Are they still selling systems with the wrong config? Damn, thats funny. Yup, thats what you need to do. Even with an up-pipe you still wont get a CEL if you do the fix.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 10-30-2001, 04:56 PM   #6
SuperFreq
Member#: 3909
2002 Impreza WRX
I'm not sure which end you are talking about. where the downpipe meets the midpipe? If so here it is, notice the bung before the cat is not being used:
Here are all my pictures
Old 10-30-2001, 08:54 PM   #7
AutoNthusd
Member#: 10949
2002 WRX Wagon
Default Do you need new gaskets?
Just wondering if BPM supplies all new gaskets with their exhausts? I'm particularly wondering about the gasket between the downpipe and the turbo? If not, it would probably be a good idea to get one for the install.
Ed
AutoNthusd is offline   Reply With Quote
Old 10-30-2001, 09:21 PM   #8
Fast Reggie
Member#: 10625
Black - TXS Stg 4+
Default Picture of Downpipe
Detailed photo avail if you e-mail me. Too large to post.
As mentioned - No CELs with my sensor installed after the cat. Yes, gaskets came with it, but not one between the downpipe and turbo as I recall. Installed it myself, and did have some fitment problems with the downpipe hitting the crossmember. Adjusted everything as much as possible, then shaved very little off the crossmember, sanded, and repainted. No problems since.
Fast Reggie is offline   Reply With Quote
Old 10-30-2001, 11:29 PM   #9
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Default Downpipe
redobs is offline   Reply With Quote
Picss of BPM GT Exhaust / ATR Up Pipe / SPO boost gauge AllenWilson Texas Impreza Club Forum -- TXIC 9 08-20-2002 12:28 PM
**Need Pics Of BPM TT and GT exhausts Redline8k Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 01-30-2002 09:02 PM
Overboosting after BPM GT install mdntridr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 55 12-20-2001 09:12 AM
BPM GT Install Help Fast Reggie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-07-2001 09:47 PM
