09-06-2006, 10:59 PM | #1 |
Member#: 31900
Wiring in AVCS to Hydra
I installed a 04 STi longblock into my 02 WRX that I'm using a hydra to run. I have the Hyrda installed as it should be on an 02, but now I need to know what pins (in the hyrda) the AVCS need to hooked up to. I have the STi manifold wiring harness so I have the right connectors for that end of the wiring but can't a pin out of the hyrda. Also does anyone know what I can get some of the pins that install into the hydra connectors?
ThankS MCL
09-07-2006, 08:12 AM | #2 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
The Element Hydra for the WRX is already wired for AVCS. You just need to wire the AVCS solenoids to the JDM location.
You do not wire in the AVCS sensors, just the solenoids since we run the AVCS in open loop for the WRX units unlike the STI Hydras which are closed loop. Here are the AVCS wiring locations. OEM Connector B84 Pin 6 for RH AVCS Solenoid (+) (Green/Balck Wire) Pin 12 for RH AVCS Solenoid (-) Pin 16 for LH AVCS Solenoid (-) Pin 17 for LH AVCS Solenoid (+) (Blue/Black Wire) What I had my tech do was follow these pins into the Hydra harness and just installed a connector there instead of adding pins into the OEM harness. The US STI units have a combination AVCS/CAM sensor and we run the STI Hydra with closed loop avcs. You just wire up the four AVCS solenoid wires and you’re done. Moving the pins is a waste of time so just add the 4 wires separately. None of these are used in your application: Add Pin 2 for AVCS Sensor (RH +) Add Pin 3 for AVCS Sensor (RH -) Add Pin 9 for AVCS Sensor (LH +) Add Pin 14 for AVCS Sensor (Shield common ground) Add Pin 15 for AVCS Sensor (LH -) Good luck, Phil www.elementtuning.com |
09-19-2006, 11:31 PM | #3 |
Member#: 25413
EDIT:: dan avON7 = the mannnnn
This is the correct harness, yes? Last edited by InfamousDX; 09-19-2006 at 11:57 PM. |
04-15-2008, 01:35 PM | #4 |
Member#: 16087
South East
Vehicle:02 WRSTi World Rally Wooooo |
Well i think i understand this I'm going to keep reading and then ask a question.
Hydra for wire-in solution? | ai42 | Other Engine Management | 5 | 08-17-2007 07:32 PM |
Need to find 04' STi ECU pin diagram to splice in AVC-R | SolidSnake | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 03-28-2006 06:46 AM |
IN: Who wants to help wire my AVCS? | Rizzo314 | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 06-30-2004 06:54 PM |
wire in connector to ECU has bad connection. How do I fix it? | SleeperWRX | Electrical & Lighting | 2 | 03-11-2004 08:17 AM |
non avcs to avcs ej20 | singsing | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 02-01-2004 09:11 PM |
