Old 10-30-2001, 05:26 PM   #1
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Default Can a broken exhaust gasket trigger a CE light?
Some of you may recall a topic / thread "CE code : PO 0420" from a few days ago.
http://www.i-club.com/forums/showthr...hreadid=107055
Well, the dealer cleared the code, and the CE light came back a few days (300 miles) later.
I noticed a broken gasket between the rear-section and the mid-pipe. Now, the CE light with this code apperently triggers because 1) cat. converter is bad 2) exhaust temperature at the catalytic converter is too cool. Can a leaky gasket somehow cause the exhaust air to get out of the system too quickly, thus reducing the overall exhaust temperature?
I have a cat-back Stromung and SAFC which is set to reduce fuel only at high throttle and 4500RPM and higher. So, SAFC is not the cause of the problem.
Any thought is appreciated!
tmat3 is offline   Reply With Quote
Old 10-30-2001, 06:13 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Yes it most posibly could, it would cause a lack of back pressure...could be percieved as a emmsion system malfunction.
Could also cause a drivability concern
fix it, clear the code and see if goes away
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 10-30-2001, 06:16 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Did the technician let you have a look at the "freeze frame data"
it lets you see what code caused the ce light, and the operating conditions at the time the light came on...
such as, mph/rpm, fuel trim, blah blah, that info would be helpfull to me...
Jay McDade
Old 10-30-2001, 06:27 PM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Thanks McDade.
Nope, they didn't show me the freeze frame data. That would've helped me out too because I can pinpoint the cause. They had no clue what caused the CE light, so all they did was clear the CE light.
Any other thoughts?
Where can I buy exhaust gaskets today? miraclemonkeywrx North West Impreza Club Forum -- NWIC 15 09-18-2006 05:54 PM
can stock exhaust gasket be used for 2.5in axleback Jungdragon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-15-2005 07:03 PM
Austin; anyone have a 3" exhaust gasket i can buy or replace? LimeyWRX Texas Impreza Club Forum -- TXIC 2 04-25-2004 01:33 AM
MRT Exhaust Throws CE Light...Huzzah! Julian Normally Aspirated Powertrain 67 09-19-2001 03:39 PM
Borla headers+Intake+Exhaust= CE light MY01 Waltsacura General Forum Archive 4 12-11-2000 08:25 PM
