Old 10-30-2001, 06:26 PM   #1
BADWRX
Member#: 3792
2002 6MT almost GDB
Question 300ZX Twin Turbo Fuel pump Question.
Will it fit into our cars as a simple replacement like the Supra pump?
I do not want to buy it until I am sure.
Thank you very much for all of your help.
Andy
BADWRX is offline   Reply With Quote
Old 10-30-2001, 06:45 PM   #2
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
If we can find out if the 300ZX pump is a straight bolt-in on Supras, then we would know. Any of the Supra boys here care to comment?
Conduit is offline   Reply With Quote
Old 10-30-2001, 07:22 PM   #3
Altered BeasT
Member#: 10062
2002 Ford Explorer
Eddie Bauer-White
I know of some that are using the 300ZX fuel pump, but never looked into it since I already had 1 in all my Zs =). Here is cut and pasted from the Supra forums:
"The Z pump is one of the best stock pumps out there. Clark at Jim wolf says he has seen 750hp with only one with no signs of pressure drop. We have installed two of them in supras, so yes to your question, they do fit. They require a little work on the pick up, but no big deal. Its not hard at all, the pickup on the z is connected to the pump with a hose that just needs to be shortened. Someone already has flow tested it, I saw the results a while back and they were outstanding."
-Sound Performance
Also, one of the pluses some mention is it being so quiet. I know under full boost, my 300ZX fuel pump used to hold a high 60's PSI.
My question: being new to the WRX, how easily does the Supra pump fit the WRX?
I'm sure the 300ZX one would be a better choice since it's easier to get ahold of and cheaper. With an added, probably never needed, bonus of flowing more.
Altered BeasT is offline   Reply With Quote
Old 10-30-2001, 07:43 PM   #4
Conduit
Member#: 6162
I would definetly make sure that the FPR can handle a pump like that. The Sard would seem mandatory at that level. I would love to be able to use this pump, they are very very common!
What we also need is some description of what exact modification is needed to fit either of these pumps. Shortening pickups, etc.
Also keep in mind that the PE is 350, so we need to keep costs below that (it doesn't flow as much, 210). I know the Supra pump is 255, any knowledge of what he Z's pump flows?
Old 10-30-2001, 09:12 PM   #5
Altered BeasT
Member#: 10062
2002 Ford Explorer
Eddie Bauer-White
All the info I have is the following:
at 12 VOLTS and 43 PSI:
VR-4 = 180
RX-7 = 210
Supra = 260
Skyline = 310
All are measured in lph and on the latest models. I have never been able to find what the 300ZX pushes, but theory is that it will do about what the skyline does. All I know for sure is nobody has contested it flowing more than the Supra pump.
It's hard because many are rated at more than 12 volts or a different PSI. Also, people get Liters and Gallons confused.
Old 10-30-2001, 10:51 PM   #6
BADWRX
Member#: 3792
2002 6MT almost GDB
It is only $250! That is krazy cheap!
I guess that I am going to get it and see if I can't get it in there!
Andy
Old 10-30-2001, 11:34 PM   #7
BADWRX
Member#: 3792
2002 6MT almost GDB
Default BTW
How difficult is a Fuel Pump to replace???
I am curious. I really have no clue!
Andy
Old 10-31-2001, 11:51 AM   #8
Conduit
Member#: 6162
It shouldn't be too hard. Unbolt the old one, install the new one. You have to be sure to get the pickup right, or you are out of luck. Oh, and you have to depressurize the fuel system (obvious) but not necessarily straightforward if you have never done it.
Given Nissan's tendencies, I could see it being essentially the same pump as the skyline pump. They always seem to go hog wild on fuel components.
Old 10-31-2001, 03:25 PM   #9
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
It's easier and a much shorter job then say...replacing an up-pipe :monkey: . Hated that job. To depressurize, just take off the gas cap. Take out the bottom section of the back seat. Disconnect the pump electrical connection. Unbolt the top of the pump assembly, it seals the tank and holds the pump. Pull out the assembly. Disconnect the internal connector on the pump. Take the fuel pump off the rail. Installation is the reverse of dis-assembly. Simple.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 10-31-2001, 03:29 PM   #10
Conduit
Member#: 6162
BTW, the fuel pump in the Z is a Bosch unit. It costs 350+ dollars new from CarParts.com
Old 10-31-2001, 03:31 PM   #11
Imprezd
Member#: 3357
Supra owners want that fuel pump so it must be good.
Imprezd is offline   Reply With Quote
Old 10-31-2001, 03:35 PM   #12
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
That explains it, bosch pumps are the ish, good for what ever PSI you dare to throw at them. And reliable as heck.
Ken
Old 10-31-2001, 03:36 PM   #13
Imprezd
Member#: 3357
Old 10-31-2001, 03:59 PM   #14
GCSUPRAMAN
Member#: 10874
WR Blue
On my supra I used twin stock supra pumps zip-tied together.
Im checking a sourse for a buy on Supra pumps...let me see if I can get the price down below $250 with filter.
Personally..I would never buy a used fuel pump..but thats just me...I dont need any flames ;-)
Greg
GCSUPRAMAN is offline   Reply With Quote
Old 10-31-2001, 04:22 PM   #15
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
I'm with you on that Greg, not down with used pumps.
Old 10-31-2001, 04:26 PM   #16
Imprezd
Member#: 3357
who said used?
Old 10-31-2001, 04:28 PM   #17
BADWRX
Member#: 3792
2002 6MT almost GDB
No, courtesy Nissan quotes 257 for a NEW pump!
Andy
Old 10-31-2001, 04:36 PM   #18
GCSUPRAMAN
Member#: 10874
WR Blue
Andy
No no no andy....i know 257 is for a new pump. I was just saying that in general i would never buy a used fuel pump because some people posted that they are gonna get one from a junk yard
The power is down at the place with the Supra fuel pumps...im gonna see what i can do when the power comes back up. I want the price to be less than $200.00 with a new fuel filter that goes on the pump...i'll try
Greg
Old 10-31-2001, 04:46 PM   #19
Imprezd
Member#: 3357
Just as Long as i get better gas mileage than a 300zx I won't be too upset.
I just want to be able to hit about 350 hp's for now... Hell Al Hit 331 without upgrade any part of the fuel system. But he did have a better Intercooler.
I wonder with a FPR and Fuel Pump running a little more Fuel pressure what can the peak horsepower end up as Until I get my bonus check for those STI or Better Injectors.
little
Old 10-31-2001, 04:49 PM   #20
GCSUPRAMAN
Member#: 10874
WR Blue
Im not sure whats the limits are on the stock fuel pump...but i have been told that it is very weak.
You dont wanna mess around with the fuel :-)
Im on hold right now...i'll post the price under a new thread for anybody who is interested. Maybe the guy who upgraded to the Supra pump could tell us what is involved
Thanks
Greg
Old 10-31-2001, 05:09 PM   #21
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Unless you are raising the fuel prssure, why would do you think there be any benefit to having a higher capacity pump? With the stock pump the vast mjority of the fuel being sent to the fuel rails is being returned to the tank unused. A higher capacity pump will have a tendancy to heat the fuel (and itself) more as well - especially as you get to the bottom of the tank.
rao is offline   Reply With Quote
Old 10-31-2001, 05:11 PM   #22
Imprezd
Member#: 3357
who said anything about fuel pump without raising the Fuel pressure?
Old 10-31-2001, 05:13 PM   #23
GCSUPRAMAN
Member#: 10874
WR Blue
http://i-club.com/forums/showthread....hreadid=108893
Cobb tuning told me that the stock fuel pump/injectors are only good for about 350 crank horsepower. This is why you would want an upgraded fuel pump and injectors.
I have not done any research...this is just what I was told and a few members have already upgraded to a Supra fuel pump.
So, in doing my good deed for the month, im trying to get a good price on the fuel pump for us
Greg
VA: 1994 300zx twin turbo sheepdog Private Vehicle 'For Sale' Classifieds 13 05-21-2006 03:56 PM
F/S: my 300ZX Twin Turbo 66K miles/1993 MR2 NA Dealer Xing Tri-State Area Forum 0 04-10-2004 09:30 PM
300ZX Twin Turbo Engine FLAG_02_2.5RS Private 'Wanted' Classifieds 1 01-07-2004 03:21 PM
Should I buy a 90 300ZX Twin Turbo for $7000 w/65K mile Dealer Xing Off-Topic 15 12-19-2003 06:20 PM
