Old 10-30-2001, 05:27 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Varying Idle
My car will idle fine for awhile and the all of a sudden start varying the idle up and down from like 650 to 980 rpm in a nice pattern. I generally does it once warma and idling over 30 seconds. Just for the record I have a MY98 RS.
Joshua
yebokmj is offline   Reply With Quote
Old 10-30-2001, 05:40 PM   #2
Iowannaski
Member#: 8268
00 GM67
BRP me ASAP
Stock ECU?
Iowannaski is offline   Reply With Quote
Old 10-30-2001, 05:51 PM   #3
yebokmj
Member#: 2213
Brilliant Red
Default Yes
Stock ECU it is is.
Thanks,
Joshua
Old 10-30-2001, 06:11 PM   #4
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
whats the temp in georgetown...?
HOK is offline   Reply With Quote
Old 10-30-2001, 07:06 PM   #5
yebokmj
Member#: 2213
Brilliant Red
Default Temp is
The temperature is around 50 to 40 degrees and it will do it either when the car is warming up or has been running for a long time.
Joshua
Old 10-30-2001, 10:24 PM   #6
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: Varying Idle
Joshua
Do you have an Apexi S-AFC? If you do, go into the Deceleration mode and reduce the amount of fuel added. Ex: If it's set at 1.5+, take it down to .5+ or even disable it. Then see if that takes care of the idling problem. Just a guess.
Kevin Thomas is offline   Reply With Quote
Old 10-31-2001, 06:11 AM   #7
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Actually i have the S-AFc and it does this to my idle also... but i also have large injectors... I was just wondering if it was getting cooler there... because i've noticed that this happens here but its into the - C.... so... maybe not such a big problem...
Old 10-31-2001, 08:27 AM   #8
yebokmj
Member#: 2213
Brilliant Red
Default HKS Super AFR
I am Running the HKS Super AFR which is a slightly differant unit th S-AFC but it has an Idle control. I have been fooling around with it with no luck. Any other ideas?
Joshua
Old 10-31-2001, 08:46 AM   #9
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Josh its the idle air control valve on the 98's the same thing that makes the flywheel cause your car to stall
bill harvey is offline   Reply With Quote
Old 10-31-2001, 08:50 AM   #10
yebokmj
Member#: 2213
Brilliant Red
Default Question?
Okay, but why would it go from a pefectly fine idle one moment and then change? It will idle pefectly fine for like 30 seconds or so and the start going nuts with nothing changing.
Thanks,
Joshua
Old 11-01-2001, 12:33 AM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Can a leaking intake manifold gasket do this?
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 11-01-2001, 09:46 AM   #12
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
mine does this too, its the subaru warm up cycle..if you let it sit, it will stabilize....my idle RPM is about 670-720rpm...
My SAFC has no Decel AIr set up, and my lo throttle points are zero'd out...
STiShawn is offline   Reply With Quote
Old 11-01-2001, 11:00 AM   #13
Avenger
Member#: 1234
Check your coolant level.
Avenger is offline   Reply With Quote
Rough idle, need new IAT? graphicsman Service & Maintenance 8 06-06-2010 12:11 PM
Idle varies like vaccum leak but not ! TurboQueef Built Motor Discussion 17 04-27-2009 05:14 AM
Erratic idle @..... idle. SilverBullet2.5RS Normally Aspirated Powertrain 7 06-24-2006 03:07 AM
Help - varying idle AWDBat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-20-2004 10:59 AM
My idle speed is inconsistent at Idle, is this normal? LisaPhish Legacy Forum 17 07-15-2003 02:01 AM
