Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 07-05-2007, 09:52 PM   #376
PaulRex
Member Sales Rating: (3)
Member#: 12454
02 ImprezaaWrxxxxx
08 SV650SF
once you get it your gonna kick yourself its so easy, enjoy.
PaulRex is offline   Reply With Quote
Old 07-06-2007, 01:11 PM   #377
servanium
Member Sales Rating: (2)
Member#: 96102
2002 WRX Wagon
STX #13
Originally Posted by Arnie View Post
do you mean you would use the Whiteline bolt in the bottom strut hole? In addition to the OEM camber bolt up top?
do not use the Whiteline bolt in the upper slottetd hole because they will slip. The Whiteline bolt is designed to be used in the smaller 14mm hole, not the large slotted hole of the OEM camber bolt. This type of camber bolt uses the small diameter of the hole and the spacer "tab" to wedge itself solid. Because the upper hole is slotted, the camber bolt has nothing to wedge itself into and only the force of the nut keeping it in place. It will slip, guaranteed.
with that said, because this bolt was designed for the smaller hole and you are using it in the larger hole, you should be able to get close to -2 just using that bolt and having the camber plate at zero! there is so much play with the small camber bolt that you can shove the knuckle quite a ways inwards compared with the OEM bolt. Actually the cam function would have barely any effect because it has nothing to press up against.
In general, I'd say twiSTies has a borked installation. Just -2 using this setup? I'd say his alignment guy is on crack and should pull his head out of that said crack and go back to night school.
The OEM camber bolt will net ca. -.8 to -1 deg of neg camber on the 05+ STi's. Not much compared to a WRX and 04 STi which nets close to -1.5. Using the camber plate correctly, he should easily get to -3 and maybe -3.5.
My suggestion? Go back to the OEM camber bolt, make sure that is indeed maxed, i.e. tug on the bottom of the wheel, push in on the top with the bolt set to max neg camber. then go up top, reset the the allen bolts to allow max neg adjust and go from there.
Arnie- I knew you had the explanation in you. I will try to get max camber with the car in my driveway then take it to the technician with the fancy lasers to check to see if I did any better than him. I will set the plate to center then adjust the cam bolt to max camber then use the plates to get the rest of the camber. Thanks for the tip and I'll give it a shot next week, as I plan on taking sometime off to replace my cobb front sway with a 27mm whiteline before my two races next weekend. Thanks again Arnie!
servanium is offline   Reply With Quote
Old 07-06-2007, 01:41 PM   #378
IMPORTIMAGE
Vendor Sales Rating: (382)
Member#: 79304
2009 Drive to work @
importimageracing.com
this thread sounds like AA for coilover addicts, good to see your all helping eachother out
IMPORTIMAGE is online now   Reply With Quote
Old 07-06-2007, 05:26 PM   #379
deblas66
Member Sales Rating: (15)
Member#: 114096
08 Civic
Paul,
You were so right. It was extremely easy with your instructions.
Thanks a million,
Matt
deblas66 is online now   Reply With Quote
More Hot Topics on NASIOC...
Old 07-06-2007, 07:39 PM   #380
PaulRex
Member#: 12454
02 ImprezaaWrxxxxx
08 SV650SF
my new best friend from my old home town haha im from westchester too man, but im living la vida loca in vermont now. i used to live in tuckahoe/eastchester area.
glad you got the coilovers figured out.
Old 07-07-2007, 12:41 AM   #381
deblas66
Member#: 114096
08 Civic
That's funny. I live in Pleasantville and my relatives live in Crestwood/Yonkers.
It's a small world.
Thanks for the help!
Old 07-07-2007, 03:58 PM   #382
Arnie
Member Sales Rating: (4)
Member#: 1725
02 dentedrustedbug
WRB road grime
The trick to getting max camber yourself at home is:
- to set the bolt to its max setting (making sure the bottom bolt is also loose). rotate the bolt around and watch the rotor move inwards and outwards. when its at is most neg position look at the bolt head. The last tick mark should be straight up and down and aligned with the hash mark on the strut.
- use a 19mm box wrench to hold the camber bolt head in place using your thumb, index finger while simultaneously pressing in the top face of the rotor inwards. Then use your other hand to snug down the nut (with impact or ratchet). tighten lower bolt using same technique.
- the idea behind this is that there is quite a bit of play between the knuckle and the strut lower clevis (bracket holes). Loosen both bolts and see how much play there is by shoving the knuckle/rotor assembly back and forth. That play is good for around -.5 degree! So you have to make sure that the knuckle is pushed inwards as far as it will go when you tighten the camber bolt down.
If there aren't any bent of out of alignment components, most people's cars I've worked on have found only a 10th of a degree difference between sides when taking it to an alignment shop.
then make sure that your upper allen bolts are positioned in the "max neg camber" holes. Also make sure you are only using the OEM camber bolt in the top hole. never, ever use the 14mm aftermarket bolt in the top hole.
Good luck!
Arnie is offline   Reply With Quote
Old 07-11-2007, 02:36 PM   #383
joey1313
Member#: 53839
2005 STi
I installed my BC Racing BR coilovers over the weekend. Install was just a simple replace and install. All I have had time to do is install them and set the ride height. I found that I had bent both rear sway bar endlinks....One too many miles with R-Comps I suppose. I have no issues with 9inch wide rims and 275s...no rubbing or clearance problems with these coilovers. All I have to do now is replace the endlinks, corner balance, and do the alignment. After I get that completed I'll adjust the shocks to my liking and test em out. Hopefully i'll have time to complete the job and review them in the next month. We have a new project at the shop that is exciting and going to take up all my time for working on the STi
joey1313 is online now   Reply With Quote
Old 07-11-2007, 10:27 PM   #384
JpiZz0
Member#: 121453
88 Ef Sedan
Paul you slut!!!! When did you move to vermont? School?
I miss you
JpiZz0 is offline   Reply With Quote
Old 07-13-2007, 04:22 PM   #385
PaulRex
Member#: 12454
02 ImprezaaWrxxxxx
08 SV650SF
I miss you
JP!! I moved up here like 8-9 months ago, i opened up a QuiznosSub restaurant.. life has been pretty hectic since then.
Its beautiful, if you ever find a reason to drive this way you always have a place to crash man.. im up in stowe,vt. good skiing/boarding in the winter too ! pm me
So about these coilovers.. i have my settings on 20f/21r and i did some serious work last night on my favorite middle of nowhere roads through a forrest etc. and these setting are wayy too stiff for 90+mph and highspeed cornering, i have to lower them on these unkept roads i use. I dont drive all out, but maybe 8/10ths speed not trying to kill myself, but i think im going to try 16f/16r next time out.
Old 07-16-2007, 03:45 PM   #386
twiSTies
Member Sales Rating: (7)
Member#: 98689
2005 Impreza WRX STi
Crystal Gray Metallic
small update:
I autoxed this past weekend in BSP with these coilovers. The parking lot was pretty bumpy, a Mini driver mentioned that her hands left the steering wheel on some of them. I set the BCs to full stiff and the car got bouncy over these bumps so I turned the settings down to 25 front, 27 rear and went on to win first place in BSP.
Love these things.
twiSTies is offline   Reply With Quote
Old 07-16-2007, 05:11 PM   #387
sjs0433
Member Sales Rating: (17)
Member#: 86061
2005 AP2
not so WRB
I'm pretty sure these are the coilovers I'm going to end up ordering. How many miles do you guys have on these things? How many daily drive them?
sjs0433 is offline   Reply With Quote
Old 07-16-2007, 05:21 PM   #388
Mechie3
Member Sales Rating: (37)
Member#: 120152
2006 WRX, ESP 92
CNY Overall Pax Winner!
I daily drive...have about....5K miles on them?
Mechie3 is offline   Reply With Quote
Old 07-16-2007, 05:33 PM   #389
IMPORTIMAGE
Member#: 79304
Originally Posted by twiSTies View Post
small update:
Love these things.
now thats a story i like to hear!
Old 07-16-2007, 05:34 PM   #390
twiSTies
Member#: 98689
I daily drive these everyday set at 5 clicks from soft. I have about 2k miles on them so far.
Old 07-16-2007, 05:35 PM   #391
twiSTies
Member#: 98689
Best suspension mod I've done and I've done damn near everything else, haha.
Old 07-16-2007, 05:37 PM   #392
servanium
Member#: 96102
2002 WRX Wagon
STX #13
I like them for racing so far. I think I finally figured out what settings to use. If they were double adjustable you could tune them a lot better for street driving, but I don't have any complaints. I like a firm ride and don't mind a little bounce. I have the inverted style on an 8k/6k 02 WRX wagon, and have about 5 k on them as well. I live in Bmore and race regurarly when ever there is an event so if you want to ride along your more than welcome. The next races I plan on attending are on the 28th in Bowie, and 29th in Philly. I was at Ripken and FedEx this past weekend. Let me know. I'll PM you.
Jason
Old 07-16-2007, 05:45 PM   #393
wrxgurl06
Member Sales Rating: (1)
Member#: 129733
2006 WRX Limited
World Rally Blue
I autorossed on 7/7. It was awesome and the coilovers did great. They were a wise purchase so far. :-)
wrxgurl06 is offline   Reply With Quote
Old 07-16-2007, 07:14 PM   #394
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
I just ordered a set and hope to have them installed before the auto-x this Sunday! Can't wait!
I'll report back my experience.
boundy3 is offline   Reply With Quote
Old 07-16-2007, 07:19 PM   #395
twiSTies
Member#: 98689
You're going to love them, congrats!!
Old 07-16-2007, 08:22 PM   #396
boundy3
Member#: 54598
2004 WRX Sedan
I've been reading about changing out the allen bolts in the camber plates in order to acheive more negative camber. Does anyone have a picture of their camber plate with the allen bolts rearranged.
I'm just having a hard time imagining it.
Thanks
Old 07-17-2007, 01:42 PM   #397
SnoCoWRX
Member Sales Rating: (5)
Member#: 126499
2003 WRX
PBFL
I've read through pages and pages of this thread, and i think i'm pretty much sold. Just gotta get my paint work done then order some up. I'm going to see if anyone local is running them. They seem like a good bet though.
SnoCoWRX is offline   Reply With Quote
Old 07-18-2007, 04:45 PM   #398
IMPORTIMAGE
Member#: 79304
well if you need any help we'll be more then happy to help out!
Old 07-20-2007, 02:59 PM   #399
IMPORTIMAGE
Member#: 79304
i can finally comment on these, as im now a bc racing (and sti owner) as of 2am this morning it was dropped off...complete with BC coilovers thanks to pete over there. car is pretty damn comfortable and quiet for a car with coilovers...I <3 turns.
Old 07-21-2007, 08:49 PM   #400
boundy3
Member#: 54598
2004 WRX Sedan
I just finished installing my set of BR series coilovers.
Overall the install went really smooth. The hardest part was breaking one of the bolts that someone (TiresPlus) overtorqued to hell. But other than that everything pretty much went as intended.
The one fault I found during the install was that the bracket for the ABS sensor wire on the front struts was just about 1-2mm to long. No biggy though, I was able to just keep torquing down the bolt and forced the plate that hold the ABS sensor wire to the bracket to bend a little.
Also, it seems like the rear brake lines are either touching or are very close to touching the inner fender well. I'm not worried at this time, but I may need to figure out a way to stop them from rubbing.
First ride seemed good, no clunks, squeaks. I took it to get aligned and the car has mega negative camber in the rear, -2.3 and -3. I was expecting them to adjust it since I have camber bolts in the rear but the manager was being an a-hole and wouldn't work with me on it (since there not stock ()). Oh well, I'll get the camber issue sorted out soon.
The front camber was excellent, right where I wanted it, -2.5 with the bolts maxed out and the front plates almost all the way maxed (after moving the allen bolts in).
Ride height is right about 14" from the center of the wheel all round. I have the dampners set at 20 from soft in the front, and 16 from soft in the rear. We'll see how that works out tomorrow at the auto-x.
Overall, the coilovers seem great. Fit and Finish seemed excellent. I can't wait to ride around in them for awhile and get it set to a good stiffness and get the camber issue sorted out.
Big thanks to Import Image and BC Racing who have been very helpful throughout this purchase. There was a delay out of their control and they went above and beyond to make sure I would recieve the coilovers before my race tomorrow.
I'll report back later on my impressions.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 03:13 PM.
