Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 09-08-2006, 02:23 AM   #1
redrex2002
Member#: 118915
2002 wrx
srp
Default help seriously considering an h6 swap
hey guys i keep reading about people running the h6 and considering i just read that with one 30r someone at 13psi was getting like 400 whp that sonds amazing i was wondering how much of a pita it would be to swap an h6 into an 2002 wrx would i have to modify the firewall fromt suspension drive shaft also who makes new internals for the h6 i need as much information as i can
redrex2002 is offline   Reply With Quote
Old 09-08-2006, 07:54 AM   #2
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
pdxtuning has done this .they would have answers to all of you questions
sonic rx is offline   Reply With Quote
Old 09-08-2006, 08:56 AM   #3
readymix
Member#: 59839
2004 WRX
Platinum Silver
Sorry, only people that use proper grammar, capitalization and punctuation are allowed to do H6 swaps.
readymix is offline   Reply With Quote
Old 09-08-2006, 09:39 AM   #4
SPOOLN STI
Member#: 123377
2006 STI
WHITE
Pdxtuning, Perrin, and Kingpin are all great places to start. I'm on the bandwagon myself and want as much info as possible. Just remember speed and power cost money. These builds are not very budget friendly (10k+ correct me if i'm wrong) and are still in the R&D infancy with power potentials. I haven't heard any 800+whp H6's yet but, it's only a matter of time and money. Good luck!
SPOOLN STI is offline   Reply With Quote
Old 09-08-2006, 10:24 AM   #5
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
figured we would get a english teacher telling us how to use proper grammar in an automotive forum. you did provide some great info for this thread thanks . heres you forum you must be lost
http://www.english-forum.net/
Old 09-08-2006, 10:48 AM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
to the OP...make sure you have about $15,000, because that's about what it's going to cost.
SloRice is offline   Reply With Quote
Old 09-08-2006, 12:08 PM   #7
InfamousDX
Member#: 25413
I agree with the first 2 because they have done what... 3, 2 for pdx and 1 for perrin. However, Kingpin seems to be working on at least 1... but still hasn't proved anything in the H6 realm.
Old 09-08-2006, 12:41 PM   #8
redrex2002
Member#: 118915
2002 wrx
srp
where is all this money comming from i am assuming the new internals wiring and getting the damn thing tuned but am i missing sompthing serioud because if it is going to cost 15k just to get the motor put in and running i will stick to my 2.5l swap i just like the idea of having a huge and wide powerband that i can get from the 6 cyl
Old 09-08-2006, 12:52 PM   #9
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
We are indeed working on 3 H6s here. The swap is fairly expensive, and here is why.
You need to put pistons and rods in to lower the compresion, and the rods are way to weak stock. You then also have to fully build the head, (spings, retainers, valves, buckets) becuase the stock h6 head is not up to the task of taking boost. Well, the h6 head will take some boost stock, but we are planning on runnig 35-50 psi via at leat a 40r if not a 42r.
You will also need a custom header to go from the h6 head to the turbo kit. We are working on having these made and jigged for mass production. There are 2 different h6 heads, and thus we will have 2 different headers available.
Then you need an engine management to run an h6. you will have to wire in the two extra coil packs and injectors.
You also need new engine mounts. You can use the engine mounts from the tribecca, but they are plastic ad weak. We are curently in the process of making billet aluminum engine mounts for the h6.
That's what comes to mind. But i may have missed something. All in all, you are not talking all that much more than a fully built 2.65 or something of the like. and the power you can make is far superior to the 4 banger, and well worth it to me.
I have torn down a bunch of the h6's, i'll round up all the pics i have and make a post so you can get an idea of what you are getting into.
For more info, feel free to call or email us here at Kingpin, as always, information is free.
Thanks
Scotty
Kingpin is offline   Reply With Quote
Old 09-08-2006, 05:33 PM   #10
redrex2002
Member#: 118915
2002 wrx
srp
thanks for all the information it is allmost like rebuilding a stock 2.5 for racing only you have to worry about 2 more cylinders the header and the wiring seem like they are the 2 biggest pita that was really helpful thanks
Old 09-08-2006, 06:38 PM   #11
kay95
Member#: 45494
95 impreza L awd
green
The EG33 is a better motor to start with then the EZ30. Sure you have to modify the front to make room for it. The best part is the bore pitch is the same as a EJ22. It has decent internals to start with but off the shelf 2.2 parts fit without a problem.
You could build a EG33 for a little more than a EJ25.
kay95 is offline   Reply With Quote
Old 09-09-2006, 01:49 AM   #12
redrex2002
Member#: 118915
2002 wrx
srp
what engine is the eg33 is that the svx engine and if so how will the 2.2 components fit i dont want to argue but i am confused
Old 09-09-2006, 04:31 AM   #13
SPOOLN STI
Member#: 123377
2006 STI
WHITE
The EG33 is from the SVX . It can be argued which is better (EZ30 vs EG33). The EZ30 will fit easier and won't upset a wrx's balance. In my opinion the EZ30 has plenty more positives than the EG33.
Old 09-09-2006, 09:58 AM   #14
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I thought about going that route in my SVX but then I read this:
http://www.subaru-svx.net/forum/show...highlight=ej22
LiquidForce is offline   Reply With Quote
Old 09-09-2006, 01:48 PM   #15
kay95
Member#: 45494
95 impreza L awd
green
Thats about the only positives the EZ30 has. The eg33 isnt that much heavier though. Even if it was a 100 lbs which it is not. You can move things like the battery to the trunk to help with the weight. The one thing that the EG33 has over the EZ30 is strength. They will handle more power with less work. 400whp is possible on the stock longblock. Though that doesnt mean anything if you are going to build both motors up.
I would say for 6K you could have a nice setup if your willing to put your own time into it.
If you did a full build of the motor I am sure a displacement of 3.5+ could be achieved if you put the right size cylinder liners in because if it is a basic 2.2 casting with two more cylinders and different head you could theoreticly take to 3.75 with just a over bore to 100mm. This is all just my speculation but worth a look into.
Old 09-10-2006, 03:32 AM   #16
redrex2002
Member#: 118915
2002 wrx
srp
allright i am a body man and i am trying to learn motors so i am catching all this it is just taking me some time what your saying is the eg33 is the svx motor which is more robust stock than the ez30 which is the tribeca motor but the ez30 is basically a 6 cyl version of the ej22 so if i was to build the ez30 i could order 6 ej22 pistons and rods and they would work? i think this is right i am confused
Old 09-12-2006, 12:48 AM   #17
redrex2002
Member#: 118915
2002 wrx
srp
bump for more info
Old 09-12-2006, 05:36 PM   #18
kay95
Member#: 45494
95 impreza L awd
green
The SVX 3.3 is from a 2.2. From the Link to the SVX forum tells us that the pistons are different. I could have sworn the pistons in a NA 2.2 are taller than the deck like the SVX. I do believe the rods are the same as a 2.2.
Anyone able to help finish up an ej20g swap? curt North West Impreza Club Forum -- NWIC 35 03-22-2010 02:02 PM
Who wants to help me do an engine swap? Patrick Olsen New England Impreza Club Forum -- NESIC 55 01-11-2007 02:06 AM
Can someone help me with an Engine Swap??? The_Triton Off-Topic 8 09-15-2005 05:26 PM
Considering H6 Swap scoobiegt Subaru Conversions 4 01-04-2005 10:55 AM
can anybody help me do an exhaust swap tonight? phillywrx Tri-State Area Forum 2 07-07-2003 03:23 PM
