Vancouver Impreza Club
Old 09-08-2006, 03:47 PM   #1
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
Default 2.5L head gasket recall not covered
hey
k well my impreza is at 98,000kms with a blown head gasket. This problem is on all 98-01 2.5L engines and Subaru put an additive in the coolant to help but also extended the head gasket warranty to 8 years/100,000 miles. So i thought i was covered with this issue. Wrong. In Canada, i found out recalls are different for Canada and US and also the recall for the coolant additive happened on both sides of the boarder. The extended warranty is for US only. Iv called subaru of canada and they offered to pay 50%. The only way ill be happy is if the whole thing is covered. If Subaru knows that this is a problem due to their design, it should be covered on either side of the boarder. Anyone have any suggestion on what i should do next? Or had this same problem happen to them????
Thanks
Wojtek
Spy is offline   Reply With Quote
Old 09-08-2006, 04:27 PM   #2
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Does this mean on my 2000 I got about 1.5 years of warranty on my head gaskets? Or at least 50% warranty?
clsmooth is offline   Reply With Quote
Old 09-08-2006, 04:46 PM   #3
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
technically in the US you would.. subaru will help 50% atleast i guess.. but im goin to fight for the 100% cause it is a known problem and it shouldnt matter on what side of the boarder you are on.
ill keep you guys posted on what happens
Old 09-08-2006, 07:19 PM   #4
Cossack
Member#: 124918
2001 Protege
Mica Black
hhmm...interesting...what is gonna happen if you try to change the head gasket in US instead of Canada?
Cossack is offline   Reply With Quote
Old 09-09-2006, 02:31 AM   #5
Tim Quinn
Member#: 16961
2011 Kawi Ninja 400R
Kawasaki Green
yeah, sadly it sa problem with the Phase II engine design itself, even with a new headgasket, you still need to use teh addative or it will leak again. Have you used teh addative? It will stop pretty major leaks, had to use it on a few subys when i was working in the mechanics shop. Worth a try anyways. Good luck on getting it sorted out.
Cheers,
Tim Quinn
P.S. "I am a Banana"
Tim Quinn is offline   Reply With Quote
Old 09-09-2006, 04:48 AM   #6
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
im pretty drunk rite now.casue im finally not driving.. i ALWAYS drive... but no.. the car got towed out today and should be good to go mid week next week. its leaking pretty seriously, it pretty much just poored right out. should have it back mid week next week, we will see what happens, but i will not be happy unless they cover it all.
Old 09-09-2006, 11:26 AM   #7
incontrol
Member#: 104816
2004 D600
Sucks to hear. Maybe I won't keep looking at RS's.
If I see you walking, and I'm also walking, should I still wave??
incontrol is offline   Reply With Quote
Old 09-09-2006, 01:37 PM   #8
tony_subaru
Member#: 22742
So is your car american, or Canadian? Becuase SOA and SOC are two totally different companys in a way. If you car is under the 5 year, 100,000km it should be covered under your subaru warranty. If it's out of warranty, then you should be considered lucky if they'll pay half.
tony_subaru is offline   Reply With Quote
Old 09-09-2006, 01:57 PM   #9
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
98k with blown head gasket? what did u do?
as far as i have seen, a lot of the DOHC EJ25 has blown head gasket but SOHC EJ25 they usually only have a leak head gasket?! and for those who SOHC that has head gasket problem, the information that i collected is they are using 87 gas, never warm up before they drive, never cool down (let the cooling system cycles) after they drive for a longer trip or after going up a hill, and they do drive hard once in awhile too...
also, i found out if the coolant isn't flush often enough it seems pretty easy to clog the radiator (that lower the cooling efficiency)
5 Zigen is offline   Reply With Quote
Old 09-09-2006, 02:33 PM   #10
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
yea i dont no, we will see what happens
car is canadian, i do use 87, and i always warm up the car, the the coolant flush was done 25,000kms ago (or 24 months) and it is reccommended every 50,000(30months) .. so there is no reason for this to have happened. ill be fixed soon enough we will see what hapens after
Old 09-09-2006, 03:40 PM   #11
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Cheers,
Tim Quinn
So what is technical detail on this design problem? Or does anyone else know? Just curious that's all - I got my additive and so far no signs of leaking head gasket
kgb is offline   Reply With Quote
Old 09-09-2006, 04:40 PM   #12
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Is this the factory Subaru head gaskets? How do aftermarket ones perform?
Old 09-10-2006, 03:48 AM   #13
Tim Quinn
Member#: 16961
Kawasaki Green
Well I'm not totally clear on teh details, my understanding it was a problem with the actual engine and not the headgaket. Over time something would shift and the gasket would leak, they fixed it in 2000 I believe when they released teh phase III engine. There must be some suby experts on here somehwere with more info on it.
Tim
Old 09-15-2006, 09:25 PM   #14
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
k well.. got my car back today.. did a time belt aswell... when i got there to pick up my car.. they tell me i have to tow it home.. i was pissed at this.. they told me the coilpack is done and i need new spark plug wires too... take a look.. ok.. wires..i guess they could be replaced... coilpack..i dont no.. its ticking and arching a bit.. i had to have my car back so i was forced to drive it home.. ran semi rough.. but ok.. got it home.. drove to lordco(different car) right away got some new bosch wires.. get those on there and everything is fine.. no ticking no arching, perfect... do you guys still think i should get this coilpack replaced or is it ok?
Old 09-15-2006, 09:30 PM   #15
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
I dunno about the coilpack dude...just glad to hear you got your car back Tek-9
semaj is offline   Reply With Quote
Old 09-16-2006, 12:48 AM   #16
veightkiller
Member#: 78967
2011 335i
did they cover the headgasket 100%?
veightkiller is offline   Reply With Quote
Old 09-16-2006, 12:58 AM   #17
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
i needed my car back asap.. so that was #1, part 2 begins on monday
i dont no.. 50% for now..
Old 09-16-2006, 04:20 AM   #18
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
just thinking.. how does a coilpack go bad? how do you know its bad..stops working??, ticking sounds?? corrosion??mine seemed to have some corrosion on #3... would just cleaning it off be good enough?
thanks
Old 09-16-2006, 05:09 PM   #19
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ticking sound came from the spark plug wires...that's all u need to replace...happened many times before and oddly, seems like #1 is the most popular...
i have only replaced coil pack because the car wouldn't start at all...
Old 09-16-2006, 05:22 PM   #20
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
hmm... i replaced the wires and everything runs fine.. altho since i got my car back, the tone out of the exhaust is noticably louder.. any ideas as to way.. maybe something to do with the new timing belt??? i dont no
i searched around and found this
the little pins on my coilpack have very little resistance so i believe there is a short circut and need a new one.. atleast according to this
the big plugs where the plug wires go into are fine using this test
Phase I 2.5L Head Gasket Failure Question Hovmerlin Warranty Issues & SOA Problems 1 02-12-2007 08:03 PM
Phase I 2.5L Head Gasket Failure Question Hovmerlin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-11-2007 08:20 PM
2.5L head gasket recall not covered Spy Warranty Issues & SOA Problems 9 10-04-2006 02:13 PM
2.5L Head Gasket flynbenny Normally Aspirated Powertrain 5 09-18-2005 04:26 PM
2.5l head gasket info page outback_97 Normally Aspirated Powertrain 0 07-16-2003 05:49 PM
