09-08-2006, 06:15 PM | #1 |
Member#: 125409
Hydra Nemesis 2.5 EMS Problems
Hi dudes,
I just installed my new Hydra on my new 2006 Subaru WRX STi 2.5L The car just wont turn on, and on the cranking process it smells a lot of Gas. I'm totally new to this, but the dealer was suppost to send me a bolt on unit!!!!! I'm in Ecuador, South America, and belive there is no one that can tune the car for me!!!! The other things I change Are: turbo gt3582ri waste gate lambda sensor intercoler 850cc injectors Cat back exahust Try to help me here, just totally lost, and with a new useless car. Thanks in advance
09-08-2006, 06:41 PM | #2 |
Member#: 82398
Vehicle:2008 STi 555 Motorsports |
what size injectors did u have b4?
09-08-2006, 08:11 PM | #3 |
Member#: 125409
stock, don't know how many cc
09-08-2006, 08:38 PM | #4 |
Member#: 82398
this is if you have a base map for a stock sti engine already loaded in, i could send u my map if u dont and you can do this process only with the old inj trim being 760 and the new being 850
550cc there's ur problem if u swapped injectors w/o re-programming the ECU its gonna dump way too much fuel and flood it, tahts what it sounds like to me, u'll need to go into tools menu...the easiest way to see if this is the problem would be to go to the injector change trim, and set the new trim setting to 850 and old setting to 550 the output should then be equivilent to the output of the 550cc inj....then if thats ur problem like i think it should start w.o dumping fuel like that feel free to PM me if you have any questions that should be the fix u need to make ur car run til you can get it properly tuned that is this is if you have a base map for a stock sti engine already loaded in i'm giving this advice knowing very litte info about ur situation (what you have given me), and like i stated this is based on the fact you have a base map for a stock sti Last edited by mxturboracer86; 09-08-2006 at 08:59 PM. |
09-09-2006, 09:51 PM | #5 |
Member#: 125409
mxturboracer86
Thanks dude for the tip. On what map do I have is what I really don't know!!! It was suppost to be some for the new injectors and Turbo. But the problem is exactly as you describe, it dumps fuel at start, meaning injector setup is wrong. I'll follow ur procedure and send u a post to see how that worked...thanks again!!! An air question, how much pwer do you think I'll improve over stock with this changes, so far I want to dust all evos of the zone!!!!! Stage1 and 2 evos over here |
09-10-2006, 02:15 AM | #6 |
Member#: 82398
the biggest thing is having it tuned for the set-up and how good of a driver u are but no doubt wit that set-up tuned even the worst of driver's should be able to be beat a lightly modded evo
09-11-2006, 04:59 PM | #7 |
Member#: 125409
mxturboracer86
Great dude, with ur change now the car starts, idles, and acelerates...but I have a weird problem, the boost is too high, it engage at top revs. How can I get boost to lower RPMs? Or is the Turbo to big for the aplication and too much spool? |
09-11-2006, 08:26 PM | #8 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
Without a base map you have a lot of work ahead of you. Did you buy the unit through Phil at Element Tuning?
How big is the turbo? What are you using for boost control? |
09-12-2006, 05:12 AM | #9 |
Member#: 82398
the gt35r probably wont hit full boost til around 4500rpm, just b/c of the side of it, as far as more boost down low, you can check in the setting menu under boost control and see what that is set to... usually want it 1000rpm below where you start to make boost, but that's if ur using the hydra for ur boost controller
09-12-2006, 10:48 AM | #10 |
Member#: 125409
I'll check who's in charge of the boost and post u later dude...thanks
09-13-2006, 09:36 AM | #11 |
Member#: 125409
Spec Profec BII, all fixed, to 1.8 Bar, but still not feel that punch I was hopping
09-13-2006, 02:38 PM | #12 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
The base maps are conservative so you will need to tune for maximum power. Also 35R cars don't have much "punch" but instead have a linear but hard pull.
09-13-2006, 03:07 PM | #13 |
Member#: 113734
South East
Vehicle:2023 FL5 Type R Subaruless |
This all sounds confusing, and just does not seem to make any sense, all the factors just do not add up.
Are you sure what you have is a Hydra(not a fake) how did you come across purchasing it? Are you sure you have the correct wiring harness for the car? Who installed these new parts on your car? any pictures you have or can get will greatly help |
09-13-2006, 05:16 PM | #14 | |
Member#: 125409
Of course dude, I'll place u pics latter night. Did not know there where Fake Hydras!!!!! I bought all on a Miami dealer send here by fastforward. About the maps, how can I get one to get the most of my car!!!!! A mechanic and me install everything...not hard at all in the hardware parts. What don't make sense!!!!!?????? Even bought some gauges with memory for the middle front part Pics latter...help with maps please |
09-14-2006, 01:36 AM | #15 | |
Member#: 113734
South East
09-14-2006, 10:36 AM | #16 |
Member#: 54918
Don't worry about this. The Hydra moved down the line through multiple distribution channels before it made it to him but it was originally an Element Hydra. The map that was orginally installed was removed through "user error" just not sure which user and I had sent them a new base map last week.
This is a highly modified Subaru and it needs to be tuned, it's as simple as that. We don't send out 550 whp base maps so he will need to seek help from someone who can guide him with the tuning process. With that said the base map is very close and only needs minimal adjustments to timing, boost, and fuel to hit 430 whp on pump fuel. I have tuned countless 35R cars with stock motors and they rarely need more than 2 hours of tuning to be optimized for pump fuel with this base map. Thanks, Phil www.elementtuning.com |
09-14-2006, 05:36 PM | #17 |
Member#: 125472
hi,your in ecuador,I know of no dynos in ecuador,only in chile and brazil.I am going to be in ecuador dec.20-jan 8. all over ecuador.I have a tuning background and know how to operate several different dynos.let me know if i can help.p.s i also have a wide band o2 i can bring. sumitomo
fs: hydra nemesis 2.1 ems | ScreaminFast | Engine/Power/Exhaust | 11 | 05-20-2009 09:16 AM |
FS: Element Tuning Hydra Nemesis 2.5 EMS for the 2004 USDM STi | x99percent | Engine/Power/Exhaust | 2 | 01-05-2009 04:37 PM |
FS: NEW Element Tuning Hydra Nemesis 2.5 EMS for 2004-2007 STi | x99percent | Engine/Power/Exhaust | 6 | 09-12-2008 11:20 AM |
04 STi Element Tuning Hydra Nemesis 2.5 | berserksti | Engine/Power/Exhaust | 11 | 10-10-2007 10:54 PM |
FS: Hydra Nemesis 2.5 w/ wideband for 02-05 WRX | jigga | Engine/Power/Exhaust | 5 | 01-10-2007 10:56 PM |
