Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 09-09-2006, 04:27 PM   #1
SubyWRXSti
Member#: 79008
2006 Blitz STI
WRB INGS+1
Default Wind Noise at freeway speed.
so I took my car in for this loud wind noise while driving on the freeway. It sounded like there is air leaking into the cabin of the car, but there is none, it's just a very pronounced wind noise it almost sounded like the air is getting trapped somewhere in the door or rear view mirror.
So they replaced the triangle thing around the rear view mirror. As soon as i get on the freeway... Bam! noise again. now I have to take it in again for them to find out where the problem is.
Anyone have the same problem? if so, how was it fixed? Maybe i can tip the tech guys a bit, so I don't have to keep going back there for this repair...
Thanks
SubyWRXSti is offline   Reply With Quote
Old 09-09-2006, 05:20 PM   #2
jk988
Member#: 60959
'15 Mazda 3
4DR FWD Miata
It's more than likely normal. Would you rather be heavier and have less noise?
jk988 is offline   Reply With Quote
Old 09-09-2006, 05:33 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
the mirror hinge line whistles under the right conditions. very annoying, sort of sounds like sheet plastic blowing in the wind.
Old 09-09-2006, 06:32 PM   #4
littledrummerboy
Member#: 94408
2006 WRX Stg. 2+
World Rally Blue
if its a high-pitched, reed-like noise, its normal... frameless windows. I tried to get that fixed but they couldn't do anything. they even re-adjusted the hood scoop but that wasn't it. That's about the only thing I wished subaru did: frame the damn windows. I find it only comes on if the wind blows a certain direction.
littledrummerboy is offline   Reply With Quote
Old 09-09-2006, 08:04 PM   #5
SubyWRXSti
Member#: 79008
2006 Blitz STI
WRB INGS+1
if I roll the window all the way up, it's very easy to produce that noise, it's not that high pitched, it sounded like you have a leak somewhere.
This is the thing, this only happen on the driver side window, the passenger side window is perfectly fine.
I found a weird fix where if I don't roll my window up all the way, leaving few mm of space, the noise goes away...
Old 09-09-2006, 08:25 PM   #6
rkramer
Member#: 118209
2015 WRX Limitec
also, did you block the rear air exit vents under the trunk? that will cause the windows to whistle...
Old 09-09-2006, 09:34 PM   #7
littledrummerboy
Member#: 94408
2006 WRX Stg. 2+
World Rally Blue
That fixes mine too... except mine is on the passenger's window. We just have differing amounts of air causing the sound is all.
Old 09-10-2006, 04:28 AM   #8
ilara72
Member#: 24047
2009 STI
Its not the little sticker on the inside of the folding side mirrors?
ilara72 is offline   Reply With Quote
Old 09-10-2006, 08:51 AM   #9
herrjr
Member#: 69981
11 GV STI
PBP
The wind noise is coming from the side mirrors. Air comes through the gap between the mirror and the hinge, which then causes the high-pitched noise at high speed on occasion.
herrjr is offline   Reply With Quote
Old 09-10-2006, 01:42 PM   #10
jefmcc
Member#: 42303
2004 WRX
Rally Blue
Let's me know I'm going too fast. lol
jefmcc is offline   Reply With Quote
Vibration at freeway speeds under part throttle subydude Transmission (AT/MT) & Driveline 4 07-14-2008 01:16 PM
Werid Wind noise at high speed RHSTi Vancouver Impreza Club Forum -- VIC 21 08-12-2007 03:29 PM
Werid Wind noise at high speed RHSTi Interior & Exterior Modification 9 08-11-2007 03:27 PM
Gear whine at freeway speeds.... Silver_03 Transmission (AT/MT) & Driveline 2 09-11-2006 07:13 PM
Wind Noise at Normal Speeds in WRX Mulder Service & Maintenance 3 12-30-2001 10:15 AM
