Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 04-07-2015, 09:35 PM   #1
BrownStyle
Member#: 345331
2016 STI
Default Rear Seatbelt
Ok, this is really annoying.
The rear middle seatbelt is stuck locked. There is nothing I can do to get it unlocked, and there is no more slack to feed into the belt to try and get it to free up.
Anyone have any ideas here? I could take it to the dealership since it is still under warranty, but I don't really want to go through all that for a stuck seatbelt...
BrownStyle is offline   Reply With Quote
Old 04-07-2015, 11:27 PM   #2
Fiveohmagnet3000
Member#: 280863
2013 Wrx PLS
Wrb
I'd take it back.. For all you know the mechanism may be jammed.. Unless you want to remove the rear deck panel yourself and play with it. Personally I'd use that warranty
Fiveohmagnet3000 is offline   Reply With Quote
Old 04-08-2015, 10:02 PM   #3
BrownStyle
Member#: 345331
2016 STI
Warranty it is....I tried every which way to get it unlocked, it's not cooperating
Old 04-09-2015, 12:12 PM   #4
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
You could remove the lower seat cushion (two bolts) then unbolt the seat belt (one bolt), that would relieve the tension and hopefully fix your problem.
Snowphun is offline   Reply With Quote
