Old 09-10-2006, 12:00 PM   #1
O Stylee
Member#: 49746
2007 Cadillac CTS-V
Default ewg just installed. Runs like ass
Just externally wastegated my GT30 and for some reason my car runs like complete ass. It only built about 6lbs of boost. The maps I am using are for an internally wastegated GT30. Even on a base map would it do this? or is there something seriously wrong?
O Stylee is offline   Reply With Quote
Old 09-10-2006, 12:39 PM   #2
WRX Shenanigans
Member#: 101378
I am 99% sure you have to be tuned for an external wastegate setup for it to run decent at all. Get to your tuner asap. Sounds like a nice setup tho. What kind of car do you have?
edit: do you have a 6psi wastegate spring? thats why it won't go above that. Get a good tune and i think you should be good.
WRX Shenanigans is offline   Reply With Quote
Old 09-10-2006, 12:41 PM   #3
brex16
Member#: 78703
2004 WRB STi
+1 you need to customize your map for that. what EM are you using?
brex16 is offline   Reply With Quote
Old 09-10-2006, 12:46 PM   #4
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
it sounds like you don't have any boost control hooked up to it. how do you have the wastegate lines hooked up? The boost values are completely different on an EWG compared to internal. Sounds like you are just running off wastegate spring pressure.
dan avoN7 is offline   Reply With Quote
Old 09-10-2006, 12:50 PM   #5
O Stylee
Member#: 49746
2007 Cadillac CTS-V
it kinda sounds like the wastegate is stuck open a idle. It is the stock 6lb spring. Its just a massive exhaust leak comming from the wastegate.
04 WRX running UTEC
Old 09-10-2006, 12:54 PM   #6
O Stylee
Member#: 49746
2007 Cadillac CTS-V
Port 1 on the Perrin EBCS is going to the the top of the ewg. Port 3 is T'd off between the turbo and the side port of the wg
Old 09-10-2006, 04:50 PM   #7
turd_ferguson
Member#: 114609
My bet is that you forgot to install the firing ring on the wastegate or it's upside down. It's the small ring that presses up against the bottom "plunger" on the wastegate to seal it shut against the WG flange.
turd_ferguson is offline   Reply With Quote
Old 09-10-2006, 05:20 PM   #8
rewt
Member#: 60794
2007 Solstice GXP
It's definitely not due to tuning... your car should still run okay (not optimal), even on the old tune. You've either forgot the ring that seats against the valve, or your boost control lines are connected wrong.
rewt is offline   Reply With Quote
Old 09-10-2006, 06:16 PM   #9
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
it sounds like your lines are hooked up correctly. Although i don't know which ports on the EBCS go where, so you could have them mixed up on that, but your T is correct and the top part is correct, as long as they go to the right ports on the EBCS.
just one question, is your car tuned for the EBCS?
KAX is offline   Reply With Quote
Old 09-10-2006, 08:44 PM   #10
O Stylee
Member#: 49746
2007 Cadillac CTS-V
Yes it is, According to Perrin Jeff thats how the ebcs hooks up to the ewg. I definatly did not remove anything from the wastegate or add a ring? Don't recall anything about that. I dont remember seeing a firing ring to install or anything like that.
Old 09-10-2006, 08:49 PM   #11
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
there most definitely should have been a ring to install. if you didn't get one, you need to. IIRC there was a thread awhile back about it, and the ring fixed the guys problem.
Old 09-10-2006, 09:13 PM   #12
page02wrx
Member#: 124053
Back to BONE STOCK
looks something like this
and it goes between the flanges
page02wrx is offline   Reply With Quote
Old 09-10-2006, 09:21 PM   #13
O Stylee
Member#: 49746
2007 Cadillac CTS-V
yeah that ring is still in the box stuffed at the bottom of one of those slots in the foam. Ill get around to installing it tomorrow. Hopefully that will fix the problem. Ill keep this thread updated for reference.
Old 09-12-2006, 04:39 PM   #14
page02wrx
Member#: 124053
Back to BONE STOCK
outcome?
Old 09-12-2006, 04:47 PM   #15
skiblur
Member#: 48291
02 EJ207RA/JDM6
Still truckin'
I bet the ring fixed it. he just had a massive leak without it.
I'm doing my install saturday. good to know.
skiblur is offline   Reply With Quote
Old 10-07-2006, 04:12 PM   #16
Judge
Member#: 15380
That ring happens to be the seat for the valve LOL....nothing like a massive exhaust leak to ruin your day. They usually tape it to the wastegate with a piece of red tape....
Judge is offline   Reply With Quote
Old 10-07-2006, 05:39 PM   #17
dibblejr
Member#: 94070
05 LGT
If you just threw it on you messed up. Your exhaust housing on the turbo has to be modded either by welding or by the method mentioned above.
You also need to be tuned for it.
Prior, Propper, Planning Prevents Piss Poor Performance.
Jay-R
dibblejr is offline   Reply With Quote
Old 10-07-2006, 05:50 PM   #18
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
you don't NEED to be tuned for it. itll run decent without the tune as long as your spring is the same as stock. but like every other modification, a tune is definitely recommended and you wont get much performance out of the mod without the tune.
EWG just installed ?'s 3g-izzle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-27-2010 06:34 PM
Help just installed ewg and sound like open header Derek C New England Impreza Club Forum -- NESIC 12 08-07-2009 10:13 AM
Someone just made microwave popcorn in the office and it smells like ass... Cjchaps Off-Topic 42 02-02-2007 05:18 PM
This site is really running like ass tonite. Brahmzy Off-Topic 2 08-01-2003 04:30 AM
Car runs like ass.....sometimes ericjames Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-28-2003 10:40 PM
