Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 09-10-2006, 12:14 PM   #1
Shootist
Member#: 117539
2006 B9 Tribeca Ltd
Titanium Silver Metallic
Default tire pressure monitor in spare?
I called the dealer about my TPMS light staying on. I have checked all four tires and they are above 32 psi. The service guy said the spare tire may be low. Does the spare have a TPMS? It appears I can't add air to it unless I take it down.
Shootist is offline   Reply With Quote
Old 09-10-2006, 03:23 PM   #2
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I replied over at www.sb9t.com/ but I'll say it here too. The TPS system is set up to register each tire in it's location (eg front - right, left - rear) and it says noting in the manual about setting up the spare. The spare is a steel wheel and I doubt they put a sensor in that. I suppose it's possible but not likely IMHO.
Peaty is offline   Reply With Quote
Old 09-10-2006, 10:33 PM   #3
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
FWIW My Titan has TPS and a fullsized aluminum wheel spare. The spare has no TPS in it. Most likely because it would drive you nuts if the air got low and set off the sensor and also it is a hassle to remove just to bump up the air pressure 5 psi.
Keith99RS is offline   Reply With Quote
Old 09-11-2006, 10:47 AM   #4
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
My friends Toyota 4Runner has TPS in spare and it really drive him nuts when he need to lower the spare in the cold winter days to pump it.
As for OP, make sure you measure it correctly when tires are COLD. And drive a few miles for the TPMS to work correctly.
Foxbat is offline   Reply With Quote
Tire Pressure Monitoring System - TIRE SPY!! Rallitek.com NWIC Vendor Classifieds 0 09-26-2006 05:43 PM
Tire pressure monitoring systems out there.. Undepelo Tire & Wheel 4 12-21-2004 01:11 PM
2005 VDC/3.0R/LL Bean Tire Pressure Monitor Synx General Community 0 11-02-2004 01:07 AM
Question on new Tire Pressure Monitoring WRSport News & Rumors 13 04-12-2004 10:18 PM
New Legacy has tire pressure monitor biggreen96 Legacy Forum 2 01-20-2004 04:57 PM
