Old 10-31-2001, 06:41 AM   #1
JustAnotherSquid
Member#: 11791
Question Doing your own oil changes (WRX)
Hi all,
I'd like to start doing my own oil changes, as paying someone to put in synthetic is pricey.
How far do you have to get the front end off the ground to get at the drain plug? Will those cheap front wheel ramps work? Or do you need a lift? What torque setting should I use for the oil filter? The drain plug / crush washer? Any other tips on changing the oil?
Thanks,
JAS
JustAnotherSquid is offline   Reply With Quote
Old 10-31-2001, 07:31 AM   #2
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
I don't raise my car, I can reach the drain plug and filter just laying (lying?) on the ground in front of the car. I tighten the filter according to the instructions on it, by hand. Regarding the drain plug, everyone here loves the Fumoto valve. Install it and never mess with a drain plug again. Do a search for links and details.
Rocky WRX is offline   Reply With Quote
Old 10-31-2001, 07:32 AM   #3
Buttsy
Member#: 2043
2002 Impreza WRX
WR Blue Pearl
Buttsy is offline   Reply With Quote
Old 10-31-2001, 09:06 AM   #4
JustAnotherSquid
Member#: 11791
OK, you guys have me sold on the oil drain valve. Questions:
With or without nipple?
F-series or T-series?
Valve adapter?
TIA,
JAS
Old 10-31-2001, 09:26 AM   #5
4Runner
Member#: 11096
Valve adapter?
TIA,
JAS
I got F105 (no nipple). I think T-series may be too long.
4Runner is offline   Reply With Quote
Old 10-31-2001, 05:05 PM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
The Fumoto valve is good, but there are downsides.
(For the record, I use one on my car.)
The valve is fragile in comparison to the pan bolt. It is also about 1/4 to 1/2 inch longer than the pan bolt. One hit and oil all over.
The inside threads on the valve tend to extend into the oil pan about 1/8 of an inch. Which leaves about 1/8 inch of used oil still in the pan when you go to drain it.
Other than that, Subaru engineers did a great job in placing the oil filter and drain plug. Just throw down a blanket or the trunk mat in front of the car. Reach underneath the front of the car and unbolt and twist to get the oil filter and bolt off.
Revision is offline   Reply With Quote
Old 11-03-2001, 08:09 AM   #7
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Amen Revision. Even with the coilovers on and a 1.5" drop, I can change the oil in my WRX without even lifting it one bit. It's a little snug under the car for the pan, but I manage.
Kevin
Force[FED] is offline   Reply With Quote
Old 11-03-2001, 07:16 PM   #8
WRXDAN
Member#: 10224
what type of locking mechanism does the Fumoto valve have to keep it form opening up inadvertantly?
WRXDAN is offline   Reply With Quote
Old 11-03-2001, 09:36 PM   #9
FastRedWrx
Member#: 11773
2002 Imprezza WRX
Sedona Red
Default Oil Filter number??
Does anyone know what oil filter to use on the WRX? I went to a local auto parts store to get the oil & filter but their book only listed up 2001 cars.
I'm interested in getting a Mobil 1 or Purolator Pure One filter. Any suggestions?
The guy at the counter said if I could come up with the number, he should be able to cross reference to another brand.
FastRedWrx is offline   Reply With Quote
Old 11-04-2001, 07:12 AM   #10
JustAnotherSquid
Member#: 11791
Default Re: Oil Filter number??
AFAIK it's the same filter as the 2001 2.5RS.
JAS
Old 11-04-2001, 01:52 PM   #11
Rocky WRX
Member#: 9837
7800 ft
Here's a photo of the F105. You can see the handle is dropped into a notch, and has to be raised up before it can rotate to the right.
Old 11-05-2001, 11:03 AM   #12
HomerJay
Member#: 1135
2005 WRX WAGON
If I don't have my front skid plate on, I can do my oil change in 10 minutes because I have a fumotovalve on my car. No need to raise the car. As far as the valve itself, it is considered a OEM grade product by Subaru.
HomerJay is offline   Reply With Quote
Old 11-08-2001, 03:03 PM   #13
4Runner
Member#: 11096
Where did you get this information?
Fumoto Page
Q. Does my Engine Oil Drain Valve protrude into the interior of the oil pan and prevent full drainage of my engine oil?
A. No. The threaded oil drain plug hole is always reinforced to accept the threaded bolt of the drain plug. Your Engine Oil Drain Valve will not extend past this threaded portion of the drain hole and will allow the oil to be properly drained. Your Engine Oil Drain Valve will let you drain your engine oil while it is hot without burning your hands and it is much more effective than trying to pump the oil out from above.
Old 11-08-2001, 03:15 PM   #14
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Post easy!
I've owned ten cars in my life (so far) and have changed my own oil on every one. The WRX is by far the easiest yet. I do not need to lift the car in any way, and I use a fumotovalve so the only tools I need are a drain pan, a couple clean rags and my hands.
Stanley is offline   Reply With Quote
Old 11-11-2001, 09:52 PM   #15
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
http://www.scoobymods.com/mods/impre...drainvalve.php
info and more pics there
As far as the oil filter you are right the same as the RS here is an OEM one:
Peaty is offline   Reply With Quote
Old 11-12-2001, 09:39 PM   #16
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default Humm ...
Is the Fumoto value safe and reliable? I'm afraid that it might come loose on me during off road or heavy driving. I'm being pessimistic but just curious? Which one should I get for my 2002 WRX? Is one type better suited than another? Thanks.
chuglobal is offline   Reply With Quote
Old 11-12-2001, 10:21 PM   #17
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I haven't had any problems in many miles on both cars. Don't get the one with the nipple it's a little too long then I think.
Old 11-13-2001, 12:29 AM   #18
Valien
Member#: 8584
2002 WRB WRX.
04 Honda Odyssey!
i have the fumoto valve and really like it. Fits good, seems secure and tight. I did a lot of reading/research on it before i bought it. Seems that the company has a great track record with this tool. And it's been certified by Subaru and other manufacturers.
~V
Valien is offline   Reply With Quote
Old 11-13-2001, 09:28 AM   #19
chuglobal
Member#: 10041
ISM
Default Humm ...
So I should go with the F150 regular without the nipple for my 02 WRX? Do I need any special tools or pay attention to any special details? Does it come w/ everything I would need? Thanks.
Old 11-13-2001, 10:52 AM   #20
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
http://www.scoobymods.com/mods/impr...ldrainvalve.php
That link should answer your questions, no special tools, no nipple
Old 11-13-2001, 02:50 PM   #21
chuglobal
Member#: 10041
ISM
Default Humm ...
The link was broken, do you have another one?
Old 11-13-2001, 04:10 PM   #22
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
not sure what happened but try this again:
if all else fails go to www.scoobymods.com and go to the impreza performance section and look for the oil drain valve link.
Sorry about that.
Peaty
2008 Impreza, when will you do your first oil change? Joy Driver Impreza Forum 8 11-27-2007 10:56 AM
Why I do my own oil changes the_poser Texas Impreza Club Forum -- TXIC 12 01-23-2007 11:15 PM
if you change your own oil...... michael parisi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 12-31-2001 11:22 AM
Change your own oil? Melody's gets thumbs up. CosmoTheCat North West Impreza Club Forum -- NWIC 2 06-16-2001 12:28 AM
Changing your own oil? sbsnyder Newbies & FAQs 5 01-24-2001 07:05 PM
