Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-10-2006, 10:35 PM   #1
wrxxed
Member#: 20567
04 STi
Sil/Sil
Angry STi factory adjustable coilovers
I spent $2300 on these expecting them to be of good quality, thinking theres nothing like OEM fitment and with less than 1500 miles one of the struts is clunking . They are installed on my 04 sti and the car is not abused,tracked or raced!
Anyone know who to contact with some complaints?
Thanks.
wrxxed is offline   Reply With Quote
Old 09-11-2006, 01:34 AM   #2
shemoves
Member#: 80663
2005 STi
take it to your dealership. Those are supposed to allow you to retain all warranty blah blah.
shemoves is offline   Reply With Quote
Old 09-11-2006, 03:03 AM   #3
surfer.tech
Member#: 39842
2003 WRX wannabe
interesting. i was looking at buying these. keep us updated
surfer.tech is online now   Reply With Quote
Old 09-11-2006, 01:32 PM   #4
shemoves
Member#: 80663
2005 STi
Keep in mind, '04 STis are known for having suspension clunking issues. All the bolts...including sway bar mounts, etc torqued properly? Who installed them?
Old 09-11-2006, 01:39 PM   #5
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Check your swaybar endlinks.
Often times people will install the struts and re-install the link in the wrong position. A few good bumps later and the end link is bent.
-Ben
Old 09-11-2006, 03:33 PM   #6
Douginss
Member#: 80727
+1 for endlinks, thought it was a ball joint or bad strut.... 3 hours later I finally found it was just a loose endlink.
Douginss is offline   Reply With Quote
Old 09-11-2006, 06:05 PM   #7
wrxxed
Member#: 20567
04 STi
Sil/Sil
Well after checking all the bolts ,etc.,I brought it in to the local subaru dealer(Metric) and they put it up on the lift and agreed that everything was torqued appropiately. What was clunking was the strut! So I gave it a shot and greased the shaft up with some white lithium grease and viola,no more clunking!
I guess since these are also inverted they are prone to sticking/clunking.
They do improve the ride substantially vs stock,prodrive springs and the JDM pinks,since thats what I previously had. Its just a poor design I guess since they need to be lubed.
Thanks for the input.
Old 09-11-2006, 06:12 PM   #8
shemoves
Member#: 80663
2005 STi
glad it got worked out. U get white lithium anywhere or is it 'specialty?'
Old 09-11-2006, 07:10 PM   #9
Cooter05WRX
Member#: 110567
2009 JK
Sunburst Orange
you can get white lithium greese at any auto parts store.
Cooter05WRX is offline   Reply With Quote
Old 09-11-2006, 07:25 PM   #10
shemoves
Member#: 80663
2005 STi
right on. I'll checka-check it
Old 09-11-2006, 09:33 PM   #11
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
it's not poor design, it's part of the install process. i installed them on a few sti's wheni was a subaru tech, it was in the instructions to lube the shaft . i remeber cuz i was laughing all day that my employer wanted me to lube a shaft
vtecTHIS is offline   Reply With Quote
Old 09-11-2006, 10:00 PM   #12
shemoves
Member#: 80663
2005 STi
good to know.
Old 09-11-2006, 10:32 PM   #13
AlxSti
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
"you gotta remember to lube the customer's shafts dammit!"
AlxSti is offline   Reply With Quote
Old 09-11-2006, 10:44 PM   #14
SubyFi
Member#: 68312
2005 Impreza WRX STi
OBP under a layer of dust
I get the clunking on my stock rear struts. I have to lube my shaft at least once a month
SubyFi is offline   Reply With Quote
Old 09-11-2006, 11:48 PM   #15
IndySTi
Member#: 123539
2004 STi
Question
So.... In you opinion, is the strut shot? Or, are you saying that the strut is fine & the clunk, clunk, clunk is just a byproduct of the design?
Of course, I have the clunk, clunk clunk on my '04.
IndySTi is offline   Reply With Quote
Old 09-12-2006, 12:17 AM   #16
Driving_Miss_Daisy
Member#: 82311
2006 Evolution IX
Electric Blue
I have the clunk on mine and want to take it to the dealer, it drives me crazy. If I lube the shaft am I good?
Driving_Miss_Daisy is offline   Reply With Quote
Old 09-12-2006, 02:30 AM   #17
SubyFi
Member#: 68312
I figure it may save you some time and hassle at the dealer.
Jack up the rear of the car (at the rear diff). Then slather on some white lithium grease (found at your local auto supply store) around the bottom part of the shaft, the shiny part under the dust boot. Kinda tricky because the springs and dust boot get in the way. I wear latex gloves and smear the grease on with my finger while wedging a long screwdriver in to hold back the dust boot.
Good luck!
Old 09-12-2006, 09:52 AM   #18
wrxxed
Member#: 20567
04 STi
Sil/Sil
I dont recall ever hearing that you have to lube your struts in order for them to work correctly,its definately poor design! And to boot the STI factory adjustable coilovers dont even come with the dust boots,so they are exposed to all the road debris and therefore dry out quicker. Knowing what i now know I would have bought a set of bilsteins or ohlins.
STi/WRX Adjustable Coilover Suspension Kit Haven Suspension/Brakes/Handling 11 02-22-2009 09:20 PM
Factory STi / WRX Adjustable Coilover Suspension Kit Haven Brakes, Steering & Suspension 19 01-20-2009 05:37 PM
STI factory adjustable coilovers $1000 wrxxed Suspension/Brakes/Handling 38 11-07-2006 02:56 PM
STi factory adjustable coilovers wrxxed Private 'For Sale' Classifieds 0 05-24-2006 06:51 PM
