Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 09-11-2006, 10:40 AM   #1
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Default Can't change VVT map's angle
Hi guys,
I can't change the angle of the 3D VVT map.
Is this normal ?
(I have the 2.50r12 software)
Thanks
WhiteKnight is offline   Reply With Quote
Old 09-11-2006, 09:21 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
You need to have that map unlocked. Much care should be taken when changing that map especially at low RPM. Contact Phil if you wish to make changes in that map.
Old 09-12-2006, 01:13 AM   #3
WhiteKnight
Member#: 56133
2004 Euro spec Sti
I think it is unlocked because i can make changes on the VVT map.
Old 09-12-2006, 05:34 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
Maybe it's a software glitch. I'm able to rotate it in 2.14v11--wish it helped me tune it ;-)
Old 09-13-2006, 12:30 PM   #5
x99percent
Member#: 27108
2004 STi
2004 A4
I am unable to rotate PWM 9 or 11 in version 2.17r6... picking "View" and "Angle" from the menu does nothing. Other maps, like the base fuel and timing maps, rotate without a problem.
The Hydra software not exactly the best. Many common features (e.g. multiply, add, copy/paste) are just not there.
x99percent is offline   Reply With Quote
Old 09-13-2006, 08:42 PM   #6
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The Hydra software is the best ever! You guys just don't know what to do with it
Seriously I have used them all and by far the most practical and functional software available. Simple pull down menus that are in a logical order. Just enough graphical interface but not too much. It's suprisingly similar to Motec.
Don't get me wrong improvements can and will be made over time.
Element Tuning is offline   Reply With Quote
Old 09-14-2006, 12:30 AM   #7
x99percent
Member#: 27108
2004 STi
2004 A4
PMed ya.
Old 09-14-2006, 12:58 AM   #8
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Any solution for us ?
Old 09-14-2006, 12:58 AM   #9
bboy
Member#: 56468
04 Improved STI
Dirty White
Hmmmm I keep wondering how similar the hardware is to Motec. From what I've seen of the Motec software, Hydra's is better!!
Old 09-14-2006, 11:59 AM   #10
Element Tuning
Member#: 54918
673 WHP Element
Anything is possible if the customers are willing to pay more. Iím really hard on Hydra EMS to maintain the price point we are currently at. Also you must keep in mind that companies have to decide where to spend their development resources. For Hydra EMS itís not a priority to add some of these items you seek but instead to develop new plug and play drive by wire applications, CAN interfacing software, USB conversions, fully closed loop AVCS, VVTI, and MIVAC software. What other stand-alone have those features in a plug in application? None of them do.
This is where the resources are going so you understand that development continues just not always on the things that offer a little convenience to the end user. For many of you there wouldnít even have be a stand-alone EMS to offer suggestions for. For the record going to the Hydra EMS forums and offering up suggestions helps the most as itís put in front of the engineerís eyes. They donít visit Nasioc and unfortunately I donít really have time to visit those forums either. I had customers get what they wanted where I had little success.
Thanks,
Phil
http://www.elementtuning.com
BC Racing Coilovers changed the axle angle a lot in the rear is this normal? spoolinsti05 Brakes, Steering & Suspension 10 06-04-2008 06:13 PM
Changing seat-back angle. Subahaulic Interior & Exterior Modification 4 02-07-2004 02:00 PM
I can't change my oil 03WRX83 Service & Maintenance 9 07-07-2003 04:07 PM
I have a problem (@ 4am)...can't change pads Hyper Brakes, Steering & Suspension 8 06-10-2003 10:41 PM
Can't change tranny oil anymore??? dada21 Normally Aspirated Powertrain 28 05-19-2001 01:58 AM
