Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 09-11-2006, 05:30 PM   #1
zymurguy
Member#: 119967
2004 Impreza WRX
WR Blue
Default TMIC cooling fans?
I did some searching on this and didn't find anything, but I do apologize if this sort of thing has been covered. A link to a thread would be great if there is one, thanks! I'm a noob here and just as new to WRXs too.
I've read a bit about some of the different modifications used to cool the incoming air into the engine. I was planning on getting an upgraded TMIC for my WRX sometime soon but the otherday I noticed something that had me scratching my head.
I spilled a little oil on the block and after cleaning up as much as I could I took the car out for a spin. When I stopped I noticed a little vapor coming up out of the scoop. Obviously when the car isn't moving forward there is no forced airflow over the TMIC. Heat rising up from the compartment was drawing the vapors up. This is pretty elementary I know but has anyone mounted fans to the underside of the TMIC?
Wouldn't this work much in the way supplementary electric fans work to keep radiators cooler?
I was thinking one could construct some ductwork to keep the flow going out the bottom of the engine compartment and to shield it from the turbo, exhaust, trans, etc.
Thoughts? Am I whack? Is it not worth the trouble?
Thanks for any help!!!
zymurguy is offline   Reply With Quote
Old 09-11-2006, 05:55 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Here's what I've done to combat IC heat soak...It's a little over the top... but it works great. As far as I'm concerened my top mount is as good as a front mount,... of the same size. There's three Albums, wrxdrvr, ICmod, & Info, with some pics of my mod path over 3 years. http://s18.photobucket.com/albums/b111/wrxdrvr/
wrxdrvr is offline   Reply With Quote
Old 09-12-2006, 01:18 AM   #3
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Its been done/discussed. Search for the keyword SPAL in the 2.0L forum and you should find the old threads. Another option is turbo wrap by Thermotec or DEI as the thing that heats your intercooler up the most is the turbo after all.
Old 09-12-2006, 07:46 AM   #4
zymurguy
Member#: 119967
2004 Impreza WRX
WR Blue
I've looked at those photo albums... that is some great work and you've gotten some great results from it too!
I'll take a look at that other forum and read up... THANKS!!!
Need some help with cooling fan + a/c fan operation and wire color codes.. caterpill Electrical & Lighting 1 01-25-2009 12:38 AM
radiator fan / engine cooling fan vvk Normally Aspirated Powertrain 2 05-15-2002 10:05 AM
Cooling fans constantly cycling.... Badluckguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-02-2001 09:14 PM
Cooling Fan Question Rickd Technical Forum Archive 1 10-06-2000 01:11 AM
Hyperactive cooling fans normal?? BlueRidgeRS Technical Forum Archive 3 09-21-2000 08:06 PM
