Old 10-31-2001, 01:10 PM   #1
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
Question What Does an Empty Rear Differential Sound Like?
Just curious, has anyone ever had a rear diff leak to empty either from a bad seal or a loose drain plug? What does it sound like?
Ginseng is offline   Reply With Quote
Old 10-31-2001, 01:26 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
BOOM! Crunch! tink tink tink....
Julian is offline   Reply With Quote
Old 10-31-2001, 01:38 PM   #3
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
It sounds EXPENSIVE...
Rocky WRX is offline   Reply With Quote
Old 10-31-2001, 01:39 PM   #4
Ginseng
Member#: 3800
2002 WRB WRX Sedan
Julian,
are you serious?
Old 10-31-2001, 03:35 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
it would start to howl around corners...especially if it has an LSD in it. Otherwise you'll get lots of gear whine before the bearings actually run dry and sieze.
jeremy
Old 10-31-2001, 03:37 PM   #6
subarurabbit
Member#: 4083
2011 OB 3.6R
There's a rumor it sounds like Keith's mom...
subarurabbit is offline   Reply With Quote
Old 10-31-2001, 03:54 PM   #7
Julian
Member#: 1182
MY00 RS
BRP
Ginseng, yes, I'm serious. I don't recommend this, but after you drive your car on the freeway and come home, put your hands near the rear diff. It'll be hot, so don't touch it. Now, consider that diff/gear lube is basically same thing and provides the same functions and benefits as the engine's oil. Now imagine your engine with no oil and driving it.
IF the rear diff IS dry and you drive it, it will heat up, sieze, and blow apart (hense the tink tink tink bit).
Old 10-31-2001, 04:19 PM   #8
Ginseng
Member#: 3800
2002 WRB WRX Sedan
Ahh, crap. It also looks like I need some sort of square wrench to open the filler port plug. Any idea what the spec is on the wrench? Looks like I'd better check the level of my rear diff fluid.
Old 10-31-2001, 04:30 PM   #9
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Just use a 1/2 inch square breaker bar.
Revision is offline   Reply With Quote
Old 10-31-2001, 05:02 PM   #10
Julian
Member#: 1182
MY00 RS
BRP
Or, lacking that, a 1/2" socket wrench with no socket.
Old 11-01-2001, 02:31 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
reivision using a breaker bar and torque wrench for everything. I think he sleeps with them under his pillow
Jeremy
Old 11-01-2001, 10:32 AM   #12
Ginseng
Member#: 3800
2002 WRB WRX Sedan
Got it...1/2" breaker bar and torque wrench. I'd assume the filler and drain ports are the same size, no?
Old 11-01-2001, 10:58 AM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
they should be....don't see why they wouldn't be.
jeremy
What does a bad rear bearing sound like? stephan Brakes, Steering & Suspension 4 09-21-2006 09:56 AM
what does an engine knock actually sound like? BlackoutWRX Newbies & FAQs 15 03-25-2005 10:26 PM
what exactly does an up pipe leak sound like??? timmah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 11-12-2004 10:46 AM
What does a dying wheel bearing sound like? remarcable Legacy Forum 5 01-04-2001 06:02 PM
