Old 10-31-2001, 01:27 PM   #1
subarurabbit
Member#: 4083
2011 OB 3.6R
Default r-12 to r134a conversion
Is there anybody on this board who has to convert from r-12 to r-134a?
Did you use the Subaru kit or Wal-Mart type?
Thanks,
Roger
subarurabbit is offline   Reply With Quote
Old 10-31-2001, 03:37 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i've done quite a few conversions. Hte factory kits are the best to go with. They usually include a new reciever/drier which you should replace anytime you open up and A/C system. also check your condensor for any oil spots in it. Have noitced that subarus tend to have leaky A/C condensors.
Jeremy
Old 07-07-2003, 09:53 PM   #3
Obin Robinson
Member#: 35121
1993 Impreza
Purple
where is a good place to buy these conversion kits? is it something I can do in a saturday afternoon? i believe my wife's Impreza has totally run out of R12. there doesn't seem to be any pressure at all.
thanks!
obin
Obin Robinson is offline   Reply With Quote
Old 07-07-2003, 10:08 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If your AC system is empty or low due to a leak you can't just buy a conversion kit and charge it up again. The leak must be found and repaired, after which the system has to be evacuated. Only then can it be safely recharged. If the system has been empty and open to the atmosphere for a long time the drier will have to be replaced as well. So, unless you are experienced with AC work and have the proper tools this is not a DIY job. Also it's illegal to vent R12 into the atmosphere, it has to be reclaimed for recycling by a special machine.
Old 07-07-2003, 10:12 PM   #5
Obin Robinson
Member#: 35121
1993 Impreza
Purple
ok, thanks for the info. what is happening now is:
the AC is NOT working at all. it's blowing HOT HOT air and it doesn't matter what happens when you turn the switch.
when i tried to test the pressure, it looks like there is NO pressure at all (unless i tested it wrong).
what is a fair price to pay to convert to R134A?
thanks!
obin
Old 07-07-2003, 10:23 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The price depends on whether major components have to be changed to do the conversion. If so it will be expensive. In some cars it is possible to change over just by evacuating the R12 and recharging with 134 and the proper oil, this is obviously less expensive. I don't know what is involved with your car, perhaps Jeremy will know.
Of course you also have to add the cost of repairing any leaks in the system first.
Legacy A/C conversion - R12 to R134a Tutorial Legacy777 Service & Maintenance 1 08-23-2014 04:41 PM
Single IDQ 10 or 12 to pair with a DSC4125 @ 500w RMS Bridged for SQ? Mike 01Hawk Car Audio, Video & Security 14 06-02-2010 09:25 PM
Legacy A/C conversion - R12 to R134a Tutorial Legacy777 Legacy Forum 0 05-09-2003 06:51 PM
r-12 to r134a conversion subarurabbit Legacy Forum 6 04-04-2002 05:02 PM
('93-'01) r-12 to r134a conversion for older Subaru ?s subarurabbit Impreza Forum 1 11-01-2001 02:43 PM
