Old 09-08-2006, 03:25 PM   #1
east milford wrx
Member#: 102301
Default Custom mounting advice
Alright i got the smc kit that uses the I/C sprayer tank, however since i plan to keep my sprayer i want to mount the alky tank on the opposite side of the trunk. Anyone ever do this or know an easy way to make it look like a clean install.
thanks
east milford wrx is offline   Reply With Quote
Old 09-09-2006, 12:01 AM   #2
east milford wrx
Member#: 102301
thanks for the help
Old 09-09-2006, 12:32 AM   #3
benw
Member#: 103320
1998 swapped
Forester L
color me confused, but won't the methanol injection achieve basically the ultimate intercooler chilling effect by reducing the charge temp? Running 50/50 is cheap enough that you could spray it onto the intercooler if you really need to. The alcohol content will actually help it evaporate quicker as well.
benw is offline   Reply With Quote
Old 09-10-2006, 09:53 PM   #4
east milford wrx
Member#: 102301
if i wanted to do that i would have to tap a new pump into the tank if i wanted to spray the intercooler. I use the sprayer when sitting in staging lanes at the track right before i run so the heat soak is not as bad.
Old 09-11-2006, 03:36 PM   #5
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Well a few options might be to use the 12L subaru tank..
http://forums.nasioc.com/forums/show....php?t=1057969
Or you could relocate the battery to the trunk and add a new washer fluid tank where the battery was. <--- My plan
As for your plan. I've never taken the trunk lining out to see what is back there but from loooking at where the jack it I guess you could get a tank back there.
WRX-ERROR is offline   Reply With Quote
Old 09-12-2006, 11:28 AM   #6
east milford wrx
Member#: 102301
Well i finished the install and turned out alright. I did not mount the injector nozzle yet tho. I dont have directions so ive been searching for info on it. I think im going to mount the nozzle in the rubble hose from the I/C to TB. Any info on this woudl be great.
Custom Exhaust Advice N1KN4K Newbies & FAQs 3 05-02-2008 08:22 PM
First log with my custom exhaust *ADVICE* CenCali07sti Open Source Reflashes 8 01-21-2008 12:24 AM
Looking for custom exhaust adviceÖ xcntrk75 Legacy Forum 19 04-12-2005 06:01 PM
looking for custom tune advice Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-23-2004 02:16 AM
Custom Mounts for Cone filters 98/99? hacman Normally Aspirated Powertrain 19 02-03-2001 01:05 AM
